Question about Philips 32PF5320A 32 in. LCD Television
No sound...no... it is not the mute button
No sound from the t.v. speakers. I only get sound through a surround system. It does not have anything to do with mute. Could it be a blown fuse inside the t.v. or should i take it to get to a repair shop?
  • Ragg01 Apr 09, 2008
    I solved the problem by reconnecting the plug on the circut board inside. The plug went to the audio and video jacks on left side of t.v. After no answer about an internal fuse, I opened the set and found the problem. Thanks to all that tried to help.
  • SJM602 Apr 12, 2008
    I've had my Philips tv now for 3 years and now whenever, I turn on my tv, there isn't any volume. The tv is not on mute and I will turn up the volume and nothing. Then about 3 to 5 minutes later, the volume starts up gradually. Is there something I can do to fix this?
I have a 42' LCD with the same audio problem,TV audio doesn't work but surround sound will. If you unplug the set and plug it back in it comes back on. BUT I called Phillips and my TV had outdated software, after installing new software it has worked fine SO FAR..... If you call customer supprt they will walk you through the steps to install the upgraded software. Just make sure you have a PC with internet, and a blank USB memory stick. I hope I could help someone else.... Good luck!
Posted on Apr 28, 2008
    Scholar:
  • 119 Answers
Did the TV produce sound along with the surround system in the past?
Verify the audio is connected through the TV and not directly to the surround system.
Usually there is an option in the TV setup to disable the internal speakers if the TV has variable audio output or audio pass-through. In Sony TV's this is usually one of the later menus and the option turns the TV speakers on or off, but it depends on the make/model of TV.
Posted on Apr 07, 2008
SOURCE:
NR626 - no sound
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Jul 01, 2014 | Onkyo TX-NR626
Philips HTS3440/37
Please elobrate further your problem.. i'm a bit confuse " If I press mute button it goes to mute,press mute again sound will come back on" This is normal.i.e. that is the function of mute button.
Sep 07, 2007 | Philips HTS3440/37 System
No Sound
Try pressing the volume up button on the right-hand speaker. These units often mute themselves if the power is removed and need to be un-muted by pressing the up volume button.
May 04, 2010 | Harman Kardon Harmon Kardon SoundStick II...
My surround system is playing on the dvd but there is no sound
check your cable settings if its inserted in the correct plug-in....also check if its not muted....also try to play other disc if there is a sound coming from the speakers
Nov 13, 2009 | Logitech Audio Players & Recorders
Error s10
Did it ever work properly? If not, let's get down to basics and set it up for the simplest configuration it can have: FM source in stereo with front left and right speakers, no Surround Mode, no DSP, no Tape Monitor, no Mute, Volume not turned all the way down. Does that work?
Do you have Surround Speakers defined in System Setup A? If not, only Dolby Surround or Off are valid Surround Modes.
Is T2 Monitor indicator lit? Press the Tape-2 Monitor.
Is there acceptable sound other than during Speaker testing? NO? Is MUTE On?
Apr 29, 2009 | Onkyo TX-DS838 Receiver
My insignia 37 inch tv
Press menu and use the up or down arrows to find the audio section adjustments. Press the right arrow and again use the up and down arrows to find tv speakers, Press the right arrow to either turn on tv speaker or turn them off ( This is used only if you are using the output signal from you tv in to you stereo input to have surround sound.) Turn them on to listen to sound from the television speakers only. If this does not solve your problem, Press the mute button on you remote control to release the mute function. If all this does not work the telephone number for Insignia is 1-877-467-4289. Talk to them about you problem and see if your television needs some type of service to restore the sound. Hope This helps you with your problem.
Mar 19, 2009 | Insignia 37" LCD Flat-Panel HDTV
Sound lost in surround sound system
I would look for DC on one of the output IC's.
Apr 08, 2017 | Logitech Z-5300e Surround Sound System...
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
Cant hear out of all speakers at once for my surround sound system
please repeat your speaker setting----confirm from your speaker connection------confirm no mute button is depressed-------confirm from volume control not in low level-------confirm that you select the right input source.
Aug 09, 2008 | Audio Players & Recorders
Surround sound
It must be about the sound quality need of your amplifier. The sound processor simply needs to get clear signals from sources such as fm/am receiver, dvd/cd players etc. in order to manage'em to give you the optimum surround sound. If the fm receiver has an "FM MUTE" option, I recommend that you turn it on. By doing so, you'll receive only good quality fm stations, furthermore your amplifier will let you get surround sound. The second issue you mentioned has its own answer inside. Use a "new" cd player, you can get optical cables, digital coax cables to improve the performance if you like..
Jun 07, 2007 | Onkyo HT-SR800 System
Philips 32PF5320A 32 in. LCD Television Logo
322 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
