Question about Motorola Mobility RAZR V3
My razor v3
My phone fell into the water it still works now but it keeps dialing the number 7 all the time even when your on the phone
    Brigadier General:
  • 7,752 Answers
You need to have the phone fully service so take it to a mobile service center and have them change the flexcable for you.
Posted on Apr 14, 2008
SOURCE:
Razor v3 problem using keypad durring phone calls "press 1 for this press 2 for that etc...
go to menu/settings/intial setup/DTMF - set it to continous then try the voicemail and try deleting the msgs again.
Oct 25, 2008 | Motorola Mobility RAZR V3
I can't access business phone menus with my V3 cell phone keypad
I have the same issue with an earlier version of the Razor. I haven't found a solution yet but still looking.
Aug 22, 2008 | Motorola Mobility RAZR V3
My V3 Razor won`t dial somtimes unless I power it off and on.
first u change your mobile software. I think after then your problem is 99% solved if problem present u change your network ic in your mobile mostley the problem is held for network ic when network ic disconnect from your mobile your mobile gave call failed in that case u r not recive any incoming call.u change your network ic your problem is solved.
May 16, 2008 | Motorola Mobility RAZR V3
Razor V3
Take it to the service center, the keyboard cable got broken or worn.
May 03, 2008 | Motorola Mobility RAZR V3
Motorola V3 Razor
Guest - you need to take the phone and have the keypad replaced.
nende - you need to replaced the main-board or buy a new phone.
Apr 07, 2008 | Motorola Mobility RAZR V3
Water damaged Moto razor
I know you don't want to here this, so be kind with your rating, but the best solution is a new phone. The reason is this: no matter what you do, water is a conductor and the dried residue it leaves behind will also short things out. And water will get to places that you can't.
Sorry, hope that helped save you some time...
Geno
Apr 03, 2008 | Motorola Mobility RAZR V3
I have moto razor v3
teh best thing for you to do is call your mobile service provider and have them assist you with that.
Feb 17, 2008 | Motorola Mobility RAZR V3
The phone has its own mind!!!
seems like some problem with the keypad if you have warrenty claim it or else look for some one who can fix it for you . and you got a serious problem with you mobile as far as i know this happens when the phone contract with water
Oct 24, 2007 | Motorola Mobility RAZR V3
Phone fell in water
Most likely something got corroded inside of the motherboard, shorting out a component or two. Your only solution will be to open it up and clean it with a soft toothbrush or something similar. If that doesn't work, I guess you'd have to replace specific components on the board and that's no easy task...
Aug 09, 2007 | Motorola Mobility RAZR V3
Motorola V3 Razor screen and key pads don't work
i have that same problem, razrs suck, i hate em!! my screen is black, i can make and recieve calls...but my screen wont turn on, this is the 3rd time its happened...first time just restarted it...second time i let it sit without the battery in for over night...now it wont turn on no matter what...and the shiy silver circle peice on the left of the phone, the smooth one, it broke and fell off the phone, and i lost it at school...cingular is saying that voids the warrenty...
Oct 16, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
