Distance over gas fireplace
We want to install a flat screen tv above a gas fireplace. There is a mantel above the glass doors.
How high above the heat source or doors or mantel does the tv need to be mounted?
We are assuming a LCD would be better than a plasma in this situation, is that true?
  • TVhead Apr 07, 2008
    Glad to hear pricey plasma is going out of style.Our power and cabling will be concealed in molding at the ceiling, fireplace is brick so we'll go with the tilt.
    Still need to know the height distance from the heat source!!!
  • TVhead Apr 08, 2008
    That makes sense about items on the mantel not melting and there will be ventilation because of the tilt. Thank you.
    Scholar:
  • 119 Answers
Both LCD TVs and plasma TVs get hot, though plasma TVs tend to be a bit hotter in my experience. Also, plasma TVs are going out of fashion.
A lot will depend on the construction of your fireplace. If it's brick it should insulate fairly well.
Either way, I would recommend a mounting solution that does not put the back of the TV flush with the wall. Get one that tilts. I would avoid the "arm" style ones as that will put additional strain on the mounting.
Remember to think about how you want to run your power and video cabling as well!
Posted on Apr 07, 2008
  • 2 more comments
  • Brandon Higa
    Brandon Higa Apr 08, 2008
    Sorry, don't know enough about gas fireplaces to give you an exact distance, but if I were you and it was my TV....
    I'd mount it where it looks good (so you're not looking too high up or down from your normal viewing position). Seeing as things on the mantle don't melt or catch fire, the TV should be fine as long as it has some ventilation for the rear, which a tilt-type mount should provide.
    Hope you enjoy your TV! I recently helped my friend install her new TV above her fireplace (wood-burning type, they don't use it though) and there actually wasn't a lot of room to position up or down, so the bottom of the TV is just a few inches above the mantle.
    Again, they don't use their fireplace so I can't help on the heat, but what I'm trying to say is that if you get a large TV (46+ inches) you may not have a lot of room to play anyway.
    Definitely take some masking tape (painter's tape is better) and mark out the size of the screen you're looking at. Remember that it's a 16-wide to 9-high ratio for a widescreen TV. What you want to gauge is how big (or small) the TV screen will look with respect to where you'll be sitting, and whether it looks too big or too small compared to the fireplace.
    From there you can narrow down your size choices, if you're choosing a size based on how/where you're mounting it.
  • atifsaleem6 Aug 18, 2010
    Definitely take some masking tape (painter's tape is better) and mark out the size of the screen you're looking at. Remember that it's a 16-wide to 9-high ratio for a widescreen TV. What you want to gauge is how big (or small) the TV screen will look with respect to where you'll be sitting, and whether it looks too big or too small compared to the fireplace.http://central-heating-breakdown-cover.c...">central heating cover
    they don't use their fireplace so I can't help on the heat, but what I'm trying to say is that if you get a large TV (46 inches) you may not have a lot of room to play anywayhttp://central-heating-breakdown-cover.c...
I’d like to see some close up views from various angles. What is it made of? Sounds metallic on the video. Steel? Aluminum? Will they come in various sizes? I have some other questions, but a few closeups at different angles will doubtless answer some and generate others. I’ll check back.
gas fireplaces
Posted on Aug 16, 2010
How to put the mantel and flue parts back on in the fireplace
Fireplace and Chimney Parts: Diagram and Anatomy
https://www.highschimney.com/.../parts-chimney-anatomy-fireplace-chi...
Nov 30, 2011 - A chimney is made up of up to 22 parts. ... Mantle - Also known asmantel piece or mantel shelf, this piece of hardware is more than a .... I have an old Blaze King Fireplace Insert that was purchased back in the mid 1980's.
How to install a wood burning fireplace insert - Hearth.com
www.hearth.com/econtent/index.php/articles/install_insert
A Heatform is a metal firebox which is built into a full masonry chimney. ... The distance to the adjacent wood trim and the mantle. ... All the way back in the fireplace, or out on the hearth? ... Rockford Chimney Supply - We are the best source forChimney liners and Stainless steel chimney liner kits to install your insert or ...
Dec 20, 2015 | Heating & Cooling
Thinking of mounting my sony bravia lcd 45" on the mentel above the gas fireplace. Is it the right thing to do
It should be fine to mount your t.v. above your mantel. As flat screen t.v.s become more popular more and more people have started mounting their t.v.s over the fireplace.
Aug 06, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
WILL BE BUYING LCD TV IN NEAR FUTURE, BUT NEED TO MOUNT IN ON WALL WITH FIREPLACE, SEVERAL FEET ABOVE EYE LEVEL. CAN DO?
Absolutly, I have wall mounted a few dozen above fireplaces in the past 5 years; I can even send you over some pictures and suggestions come time for the install.
What is the wall material? Brick mantel or drywall with wood studs?
Although a TV looks attractive about a fireplace you have to consider that it is fatiguing to watch from such a high height. The optimal average height for a TV is 45" to centre (depending on furniture). If you exceed that by a few feet watching a lot of TV is awkward.
The advantage is it combines the focal point of the room, and instead of having a picture about a fire place, your TV becomes the work of art and can be used as a digital picture frame.
Jan 01, 2010 | Samsung LN52A850 52 in. LCD HDTV
Can I wall mount my Tv above a gas fire?
If your talking about enclosed fireplace with the glass front and the vents from it are facing down. Then yes you can use your judgment though. Just make sure their is enough space between the tv, and the fireplace so their isn't direct heat blowing on the tv. A good 4-5 feet above the fire place or more would be fine.
Sep 29, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Height of tv
2000m = 2km, which is pretty high, and may cause problems at this altitude, probably something to do with pressure and the plasma gas ignition, I guarantee your fireplace is not this high.
May 04, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Black soot on glass and black smoke comes out
Remove the burner and clean all holes ,typically at the end of the burner is a cheep sheet metal valve.This valve adjusts the air to gas mixture by rotating it to increase or decrease the combustible air intake.Air must be sucked into the burner as natural gas is injected into it, this makes for a clean flame,The flame should be blue with small yellow tips.If the flame is long and yellow and sooty increase the air intake on the burner valve.
Jan 26, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
I'm trying to hang my flatscreen tv above fireplace and need help
Wendy,
When attaching your wall mount to the brick you should use a metal lag shield designed for masonry. These can be found at the local hardware store but i would carry the mounting bracket with you so that you can ensure that you get the appropriate size of fastener that will pass through the bracket. As far as the heat goes, it really depends on the amount of heat the system will be subject to. Some fireplaces are more for decoration and produce very little heat above the mantle area. Others that have blowers on them or are left with the doors open genrate considerable heat.
I would not advise the mounting of the tv above the fireplace in my professional opinion. The cooler you can keep electronics - to a point- will greatly increase the service life of the appliance.I hope this is of assistance to you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
Nov 13, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Just a consumer quesstion.
Heat rises and smoke has particulate matter in it. And heat is the enemy of electronics. So personally, I would not mount any expensive TV over a fireplace. However, if you have nice glass doors covering your fireplace opening, good updraft in your fireplace, and a large mantel that projects out over the opening, you will probably get reasonable life out of your LCD TV.
Sep 11, 2007 | Televison & Video
Televison & Video Logo
2,867 people viewed this question
Top Televison & Video Experts
