PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Blue line down monitor screen of laptop
By kevj on Apr 06, 2008
Hi, I have recently noticed that I have a blue single line down the monitor screen of my Sony Vaio VGN-A217M laptop. It runs from the top to bottom.
Same Problem
May 19, 2009
-   well i hvae about a 100 blue line..1 every 1mm.. -   Guest
Apr 25, 2009
-   there is a small line about the depth of a fingernail across the screen of my laptop. the line is vertical
-   Guest
Apr 22, 2009
-   I also have this annoying blue line running down my computer. It comes and goes and sometimes I can tap the screen or bend it up and down and it will go away. But sometimes it just stays there to annoy me. I had once already replaced the screen since I had it even worse before where it looked like I had 2 colour bars on it so it was much worse. Still my 2nd screen and still get this damn line. No more Acer products for me in the future. It's not even worth replacing the screen, might as well just buy another laptop. -   Guest
Apr 16, 2009
-   blue line appeared about 30 min. after cleaning the screen. some 15 minutes later, another parallel blue line appeared but disappeared in about 10 min.
It's Sony Vaio laptop. -   Guest
Apr 11, 2009
-   my dad droped my laptop on my way back from a trip when it fell of the bellcart( which was a good 8 feet in a bag filled with my clothes) and next time i opened it a blue line a pixel thin ran the length down my laptop and would dissapear if the screen was pushed back a little bit but when you stopped it would come back and then my screen would go out with the lightest tap anywhere on the laptop and if the cd/dvd drive was opened it would go outi found out that a connection from the cd/dvd drive to the monitor came lose and is what caused it cost 97 dollars to get it replaced and installed (at jtech) and all the problems went way but the blue line waent away before i got it replace for some reason thenlast night it fell 2 feet off my bed onto carpet and i opened it about 2 hours ago and a RED line appered in the same spot as the blue but luckily the screen didnt go out with a tap will someone please help me-   catynes
Best Solution
posted on Jul 15, 2008
Very Helpful)
eel-man
Rank: Apprentice
Rating: 96%, 13 votes
I have had the same problem
This happens from overheating or from physically abusing the screen
I have an acer, which can take a lot of punishment, but i throw it around and keep it on 24/7 until it gets so hot the plastic starts to smell and melt
Awesome computer, it still works very well for the price (500$)
It developed blue lines on the screen lately and i know from previous experience acer will replace your screen as this may be a factory problem
If you're a freak like me who runs his computer all the time though, they aren't going to listen to you for one second and you have to deal with it
A) Dont use your computer as much (that sometimes fixes it)
B) Buy a better cooling deck
C) Dont abuse the screen (any bending or even the slightest tap can kill it)
D) If the problem doesnt go away, make peace with it and get used to it
E) Replace the screen (i dont want to, so now i have kewl blue lines on my screen)
Comments:
Jul 15, 2008
- I forgot to say ....
Its a line fault and is a problem with the edge connector cable, if you are replacing it say this to the guy
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Jul 05, 2008
Somewhat Helpful)
Knavehart
Rank: Apprentice
Rating: 68%, 8 votes
I have had this fault just develop, i notice if itake top corners of the screen and pull the left corner away slightly and the right corner closer the line vianishes, the line is not visible if the screen on is white or very light blue, but any other color and its there
so I suspect this a loose/damaged connector pin in the color control
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Apr 22, 2008
Somewhat Helpful)
NanaSuziq
Rank: Apprentice
Rating: 72%, 5 votes
I am in Florida but heading back to Maryland soon. I wish someone could just answer my question as to whether it's a pixel or not.. Thanx.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Apr 06, 2008
Somewhat Helpful)
lemon2ade
Rank: Guru
Rating: 89%, 68 votes
you may need a replacement screen. where are you located
Was this helpful?
Yes
No
Solution #5
posted on Nov 01, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a new flat monitor monitor---AFTER CLEANING MY KEYBOARD I NOW HAVE A THIN LINE OWN MONITOR SCREEN HOW DO I CORRECT THIS
Solution #6
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I NOW HAVE A NEW HANNSPREE XM FLAT MONITOR---AFTER CLEANING MY KEYBOARD---I NOW HAVE A THIN LINE DOWN THE CENTRE OF MY SCREEN ALL THE TIME
Solution #7
posted on Aug 07, 2009
Helpful)
dgffhdfhf
Rank: Apprentice
Rating: 88%, 2 votes
i have a blue line is was first just yellow and it turned blue one day and i need an answer on how to get rid of this really bad
Was this helpful?
Yes
No
Solution #8
posted on May 31, 2009
Helpful)
aristo_cena
Rank: Guide
Rating: 64%, 8 votes
Dont leave your compter on for so long,,try to shut down ,, and dont tap the screen if the blue line appears,,it may kill your screen..
handle with care!!!
Was this helpful?
Yes
No
Solution #9
posted on Feb 27, 2009
Helpful)
cwm82
Rank: Apprentice
I experienced the blue line down the middle of my Dell XPS140 laptop screen. I thought all was lost, but I just gave a few firm taps to the face of the screen up and down the line, and it went away! I feel lucky not having to spend any money to fix it!
Was this helpful?
Yes
No
Solution #10
posted on Feb 02, 2009
Somewhat Helpful)
Jodiwoo
Rank: Apprentice
Rating: 75%, 1 votes
There is simply no fix for this really other than replacing the screen when it gets too annoying to put up with. I've had a quote of £180 from a business to do it for me and I've found a 2nd hand replacement on an auction site for £125 if I fit it myself. I'm going to try the latter.
Was this helpful?
Yes
No
Solution #11
posted on Dec 11, 2009
Not Rated)
FixYaNoFixMe
Rank: Apprentice
Rating: 0%, 0 votes
Mhmm i've got the blue line also it was green at first but now went to a blue line i don't take much notice to it but from what i no of what causes this is excessive use of the computer or dropping/abusing it. i havent fixed mine yet nore will i bother. but how to solve this (think of your laptop as your child don't drop your child or abuse your child or don't use your child excessively. hehe =D hope it all works out
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
How to apply this layout on my account?
Answer
i want to bye the best performance laptop on the market, with the state of the art hardware, 15in... (More)
Answer
presario v6000 thes screen will not work
Answer
hello people nice place! my proplem: i have a hp pavilion dv6000 and sometimes i have a smal purple... (More)
Answer
friend trying to speed up comp pres deleted sound card help
15 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 07, 2009
I have not had my laptop hp pavillion dv7 but for two months and i have a thin blue vertical line going down the right side of my screen, My laptop is not abused in anyway so i do not understand why it would be there,
Comment by NatheOveri, posted on Mar 29, 2009
I have exactly the same problem. my blue line is at the left hand side of the monitor but it eventualy goes away (for the momet)
I have the Sony Vaio VGC-LN1M.
It's a built in modem so I cant just replace the monitor.
Does any one have a solution?
Comment by Guest, posted on Mar 18, 2009
I have the same problem =(
Comment by sherriw, posted on Mar 02, 2009
I have a Dell Inspiron 9200 17" and developed a line about 2 months ago. Now I have another line. I DO NOT abuse my screen. I DO NOT leave it on for long periods of time. I dont get it. Is this a flaw w/ Dell?
Comment by Jodiwoo, posted on Feb 02, 2009
I have a Dell Inspiron 9300 17" widescreen and had my first vertical line appear some weeks ago. The number grew by about a line a week and I now have 16 of them across the screen in random places.
Comment by Guest, posted on Dec 19, 2008
I HAVE THE NAME PROBLEM!! HELP ME! i own a Inspiron 1501 laptop and their is this THICK blue line in the middle of my screen, and sometimes the right side of my screen smears and i cant see whats on the right side of my screen! HELP ME PLEASE
Comment by naml, posted on Aug 07, 2008
Hi I have a really thin blue line on the right side of my laptop(top to bottom). Its just come up and I have no idea what it is?? Is this a problem??Please help.My laptop is a toshiba satellite L300-149.
Thank you,
Namira
Comment by dlocke, posted on Jun 08, 2008
I am having the same problem with a toshiba satellite laptop. The screen Has a vertical line one pixel wide. On the left side of the screen It is pink.
Thanks,
Dave
Comment by Guest, posted on May 17, 2008
i gopt the same thing jusd now?
Comment by NanaSuziq, posted on Apr 19, 2008
I also have a thin blue line from top to bottom of my laptop screen. I havre a Gateway, that just had new harddrive installed about 6 weeks ago because of problems with it doing what I asked of it. This is about two days old and doesn't really bother me except it should not be there. I have shut down, restarted, closed out all programs and when I open it, still there. Is it a pixel that is shot and carrying the line.. I am working around it but would love to know how to fix it..
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , CO
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
