Wireless zero configuration is the feature of Windows XP that allows
Windows to detect the available wireless networks and automatically
connect to the most preferred wireless network.
It is enabled by the
Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to
Start and right click
My Computer. Select and click
Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to
automatic.
4.
If it isn't, double-click the service. If the startup type is not set
to automatic, click on the dropdown arrow and and change it to
automatic. Click
OK at last.
If your
wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
The network adapter does not appear as a wireless network adapter in
Network Connections. It appears as a LAN adapter, similar to an Ethernet
connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To
get the most out of your Windows XP wireless experience, you should
contact wireless adapter manufacturer to obtain the latest version of
the drivers that support this XP feature.
If not, you must
manually configure wireless network settings using the configuration
software supplied with the wireless network adapter.
I'm having the very same problem as usmc85_8. My other notebook computers work just fine via wireless. This (Acer) computer can only connect when directly connected to the router.
