Papeer wont load - Office Equipment & Supplies
  • 82 Answers
You might want to let me know what the make and model is of your printer, but if it's your paper pickup tires being dirty here's a quick and simple trick.
pour a very small line of rubbing alcohol on the leading edge of a piece of paper just so it's damp and not soaked then load the paper into the tray and hold sheet while getting the machine to try to feed it. don't let the machine take it. what you are doing is allowing the rollers to turn onto the acohol dampened paper which will clean them easily. once your done remove the sheet wait a minute for rollers to dry and try it.
Thank you,
Mikey
Posted on Apr 06, 2008
SOURCE:
MX870 paper out
find the paper sensor and clean or repair it.
May 05, 2012 | Canon PIXMA MX870 Wireless Office...
A long stripe . looks like film with a small opening on each end came off the inside of the printer.on the right side near the ink cartridges. can't put it back and also can't print . lines are blurry...
Howdy there! It sounds to me that the alligning tape has broke. Is there any way that this printer is older? Maybe not used for a spell? If it is older then it could have dried up and the line will crack and eventually break..... If this is the case, unfortunately, you need to replace the printer as the repair is just about the same cost.... Guy
Oct 16, 2010 | Dell 922 All-In-One InkJet Printer
Reciveing a papeer jam ussually on any fax with a
Try to clean the pick ADF with a piece of soft cloth wet with alcohol
Apr 06, 2010 | Brother IntelliFAX 4100 Laser Fax
Paper jam
take out cartridge and force paper to take out sometimes it is needed to tear paper to take it off but no problem, main sensitive for this type of printers is cartridge, also find if any "jam lock" is presented to ypur printer and unlock.
Aug 01, 2009 | Brother HL-2070N Laser Printer
Re:Minolta copier EP 2151 I am trying to print a stack of documents using SDH mode (semi-automatic document handling). The SDH mode green light comes on and blinks, but the light on the "go' (print) button...
If the green light on the adf is blinking that means that there is a paper jam in the adf. I sure you know that the copier you are using is at least 10 - 15 years old. Has the adf worked recently? Are one of the adf hings broken? If so, line the adf straight on the top of the copy board glass. There is a magnet that needs to be closed to make the adf work. Try to see if there is any small piece of paper in the papeer path of the adf and use a can of air to blow out the sensors and get back to us.
Jan 14, 2009 | Canon imageRUNNER C3220 Color Copier
1999 nissan stagea
Taylor;
I was able to find a service manual for my 97 Infinity Q45 on Ebay. It was in the form of a DVD. A very detained replica of the papeer service manual. What's more it only cost me about $15.00 including postage. Try a general search "Automobile service manuals" and specific search like "Infinity Q45"
There are Ebay "stores" that do nothing but sell manuals, either paper or DVD.
Hope this helps Good luck Loringh PS Please leave a rating if appropriate. Thanks
Nov 14, 2008 | 1999 Nissan Sentra
Paper Jam
hi
open your fuser assembly change your taplon tape or roller
check that taplone tap moves arrond roller.
alwaays papeer jam problem bcuse of bad condition of tapelone tape
try dear u can do this
\bye
Mar 24, 2008 | Dell 810 All-In-One InkJet Printer
Lines across the tail end of small photos
Your printer sounds as if it has a hatred for one type of paper size!!! Seriously, it could be a positional blockage, ie debris in a place that allows large paper no worries, but as soon as it repositions itself to do 4x6 it catches a block. open unit if you can and thoroughly check for debris, ie papeer bits. Hope this helps. Also give your printer some tlc, clean heads, both manually with solution and cotton buds, and run print tests, clear print jobs memory, and try unconnecting and reconnecting cables, and powere supply.
Aug 11, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
146 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
