Vertical problem with goldstar gct2556s tv
Picture squashed towards the center of screen.change ic ta8445k but no change to screen. change couple caps in the vertical circuit also. no improvement
  • jasata Jun 06, 2008
    cambie el ic del vertcal ta 8445k cambie filtros de este circuito, y me esta quemando dos diodos zener que van al pin 12 del ic vertical
3 Suggested Answers
SOURCE:
SOURCE: Does the TOSHIBA TA8445K Vertical Deflection IC fails when the Deflection Yoke is Dirty?
hola tengo un tv onwua que no me habre el verticar ya revise los voltajes y estan bien pero en la pata 11 tengo solo 7 voltios en ves de 12 voltios cual puede ser el problema de mi parte muchas gracias.mi email es [email protected].
Posted on Aug 15, 2008
  • 7 Answers
SOURCE: vertical line in center have replaced vertical output ic
If the line is vertical then the problem is no horizontal deflection. The vertical chip is probably fine.
Check connections around yoke (thats the connector with at least four wires that goes up to the coils around the neck of the tube)
Maybe that TV has two horizontal output transistors. One for deflection and one for high voltage? Check both of them. Look for bad solder joints!!!
Posted on May 22, 2009
Curves on TV
You have a bad capacitor off the vertical output I.C..Find the pin off the I.C. that represents the out of the I.C. If you have a capacitor checker, you can check the ESR(equivalant series resistance) to see if it reads high.Look on the internet for a schematic,this will show which pin of the vertical I.C. is output,and the cap. that leads off it..
Jul 07, 2009 | Recoton Advent Advent HT3251A TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Toshiba 27d46 27' TV
Change the vertical IC
Dec 06, 2008 | Toshiba 27D46 27" TV
Top of tv screen has a black line and top of tv pict is squashed
Nothing you can do unless you have knowledge of Solid State Electronics Servicing. Looks like a couple of Capacitors in the Vertical Deflection Circuits have become bad.
Nov 29, 2008 | Philips Televison & Video
Toshiba CE35f15 TV
This is a vertical circuit problem that is either bad connections on the vertical IC or a defective IC. If you can solder, you can fix this yourself. Look for a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC. There may be defective caps in the circuit as well, but those don't usually cause complete vertical failure. If the picture does not return fully, update this and we'll continue on to the next step.
Dan
Sep 29, 2008 | Toshiba Televison & Video
Mar 05, 2008 | Sharp Televison & Video
Vertical section problem? Part of screen is blank
replace cap. 2465, cap. 2561, cap. 2460, and d6460
Feb 23, 2008 | Philips 27MT3305 27" TV
Sylvania 27 in tv picture
It sounds like your vertical has shrunk, causing the picture to look squashed. Most likely a bad component in the vertical output stage.
Dec 19, 2007 | Sylvania 6413TC 13" TV
Picture vanished
The problem might have started because of loose conections in the vertical circuit,if the vertical circuit fails completly the screen blanks out to prevent a line being burnt in the picture tube so that part is normal but the problem is still in the vertical circuit.Maybe the IC just went bad all the way and it might have taken a fusible resistor. If you are familiar with tv service you have a place to check but if you are not too familiar be safe and call for assistance from a servicer,is a straight forward problem and it should not be expensive.Let US know how it goes or if you need more information.
Oct 30, 2006 | Philips TS2754C 27" TV
Vertical rolling in t.v.
Kamal, You need to find the sawtooth waveform which is generated by the vertical oscilator. There will be a pin on the IC that should show the waveform. If it is not there, then the IC is bad. If it is there, then there is probably an amplifier stage prior to the deflection yoke that has a problem. Either way, the sawtooth wave is not getting to the deflection coil which is why it is rolling. Ther might also be a coupling capacitor which has opened up. Hope this helps.
Sep 13, 2006 | Goldstar GLV-B1000 4 in. Television
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
Ekse
