Question about Honeywell HT-800 Table Fan
Remove grille on fan fan to clean claimsto be easy not to me
  • MAG04 Dec 10, 2008
    I have the same problem I want to get the dust off the blades of my fan but cannot open the grille..Ive tried numerous of tools but all I ended up doing was stripping the nails on it..All i want to do is clean my fan..can someone help me with this?
I have taken mine outside before and used a leaf blower. Blows all of the dust out and works great on the areas that cant be reached
Posted on Jan 04, 2009
How do I remove the grill to get to the fan blades to clean them?
There's usually a screw or a clip which locks the two halves of the grill together. You need to remove the screw or undo the clip. Then you should find that one half of the grill cage just lifts out of its locating lugs. Once you've got the cage open you have access to the fan impellor. This should be removable. Sometimes by undoing the locking screw or just by pulling it off. You can now get to all parts of the fan assembly to clean it. Here are some links to useful sites:
DIY Home Improvement Information DoItYourself com
YouTube
Breaking News and Opinion on The Huffington Post
Jul 25, 2015 | Dryers
I need to clean the grill in hotpoint refrigerator. When I hope the door to the freezer there two screws hold down grill.The refrigerater is model No. HTS16HBMBRCC HOTPOINT
General Electric (GE) Profile refrigerators have a grille on the bottom of the front of the refrigerator. The grille allows air to be pulled from the kitchen into the lower compartment of the appliance by the condenser fan, which cools the refrigerator's compressor. At times this grille must be removed, such as when you are cleaning the compressor, emptying and cleaning the drain pan or adjusting the refrigerator's leveling legs to level the appliance. The grille is designed for easy removal: It is secured in place using only two screws
  • 1 Open the refrigerator doors to at least 90 degrees.
  • 2 Remove the two Phillips screws securing the grille to the cabinet. They are at the top portion of the front of the grille.
  • 3 Pull the grille away from the front of the cabinet to remove it.
  • Phillips screwdriver
    will be needed
    Dec 21, 2014 | Hotpoint Refrigerators
    I NEED INSTRUCTIONS TO TAKE APART FOR CLEANING
    I have a similar model to this one. It's a little tricky. Everything snaps or twists together. Press a little on the front and back of the fan grills and twist lefty loosy to open. The blades are an easy detachment, just pull them out easily, and take off the back grill. The back grill may have two screws connecting it to the main case of the fan, but mine didn't.
    Aug 17, 2011 | Lasko 2506 16" Table Fan
    Is the best way to clean a tower fan with air? it doesn't disasemble very easy. It does have a cleanable fiter right?
    No filter, what I do is spray tthrough the grill with Mr Clean generously.
    Let sit for 20 mins. Take outside and turn on hi.
    Jun 24, 2010 | Tower Aloha Breeze Fan
    How to clean the fan on a toshiba satellite
    If you do not want to tear the system down, just power the laptop down, remove the battery, push the power button for 10 seconds to bleed off the power . Now go and get some compressed air used to clean electronics,you can get it in cans at an office supply company. Using short bursts, blow air in the laptops ventilation grills, using short bursts will keep condensation from blowing out and onto the laptop and also keeps the fan from free spinning and damaging itself. Blow air in all the grills several times over, that mosts the dust and hair back and forth and works it out of the grills, fins and fan blades.
    Nov 26, 2009 | Computers & Internet
    Trying to remove service grill for Nutone QT140L combo fan/light
    Yeah it takes a good push and a sharp tug to get them off if they've been there for awhile, they get greasy and stick, They sometimes bend a bit coming out but they're easy to staighten after you clean them. and yes they are one part.
    Jun 02, 2009 | Broan-NuTone N-QT140L Combination Light...
    Need to remove gril to clean blade and grill
    You can remove it by pressing the clips. I used a flat screwdriver as there was no way my thumb would fit in there. But it worked like a champ with the screwdriver. I pressed two clips and it popped and then I could simply lift the grill away from the fan blades.
    Apr 24, 2009 | Vornado Circulating Fan
    Removable grilles for easy cleaning?
    We just figured this out ourselves. There are four (4) screws on the back of each fan that when undone it releases the grill for cleaning. But the fun part is getting the screws back in to the little holes. But all in all we got it clean...
    Jul 20, 2008 | Honeywell Dual-Action Air Circulator Fan -...
    Fan does not operate
    Make sure that nothing is obstructing the fan. Try to rotate the fan with your fingers to make sure it is free. If it is, you would be lucky if the fan is at fault because this is rather cheap and easy to find if not it is the main board which is at fault.
    Dec 31, 2007 | InFocus ScreenPlay 4805 Multimedia...
    How do you clean Patton Floor fan?
    The grill is in two halves with the back half attached to the motor. The front with the round patton insignia removes easily by applying leverage with a screwdriver. There are eight spots (at least on mine) where it clips. Be sure to remove any disposable plastic fastener holding the two halves together. Its pretty easy.
    Sep 12, 2006 | Patton Electric U2-20 Box Fan
    Honeywell HT-800 Table Fan Logo
    885 people viewed this question
    Top Honeywell Dryers Experts
    Jay Finke
    Jay Finke
    Tom Chichester
    Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
