Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 50v500 - the white part of the picture has a yellowish tint
We just changed the lamp and now the white in the screen has a yellow tint. I tried to adjust the video settings and reseated the lamp, but nothing has fixed the problem.
  • 4 more comments
  • Anonymous Apr 23, 2008
    I have the 60V500 (60" version) and just started noticing a yellow tint across the bottom of the screen when watching hockey. Any ideas?
  • Anonymous Apr 28, 2008
    Same issue here. Whites are either yellow or a light shade of green. Pictures of bodies of water or of the sky are green.
    Same issue here. Whites are yellow or have a greenish tint. Skies or bodies of water are green.
  • Anonymous May 02, 2008
    Just changed lamp and my warranty expired one month ago. I have a yellow tint now.
  • stew3003 Nov 30, 2008
    I purchased the 50v500 in late 2003. It has had a GREAT picture. However, about three weeks ago Inoticed a yellowish tint over most of the picture . Any ideas. New bulb of light engine?
  • Anonymous Mar 25, 2009
    12 in by 20 inch yellow/green oval in middle of screen
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Bad light engine
Posted on May 02, 2008
I have the Sony KDS- 60A2020 60 inch TV. Recently, my picture has appeared more yellowish. Everyone on it looks like there dark yellowish or have fairly dark (bronze) sun tans. I changed my lamp yesterday...
I have a older 2006 SXRD rear projection TV. I had the same problem after the TV warmed up this yellow tint started in the corner and crawled its way down the TV. It turned out that Sony had a recall on the optic block of the TV. If you replaced the Lamp and adjusted the color this kinda sounds like the same problem. Here is a link explaining it. In this article it shows up as a green haze and blob, but in my TV it manifested as a yellow tint.
http://www.avsforum.com/avs-vb/showthread.php?t=1086180
Jun 09, 2011 | Sony KDS-60A2020 60" HDTV
We have a new bulb for our 50v720 and now there is a yellow tint!
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, yellowish tint,pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 19, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
The whites are yellow and theres a yellow tint to the picture in general although not real bad. Is this just the lamp # ux21513 needing to be replaced? Thank You
The Lamp would cause the picture to be dimmer but not discolored. I would suspect the Optical Engine is causing the yellowish tint. Due to the cost of replacing, call Hitachi at
1800-448-2244 and see if they would be willing to help with the repair.
Hope this helps,
Skyassoc
Jul 18, 2009 | Hitachi 60V710 60" Rear Projection HDTV
Red circle and yellow tint in our white
If you have RED color that starts from Center of the Screen,(no red color on sides ) 100 % your light engine is deffective..
In order to solve this issue Replace Light Engine Control Board (also called Driver Board ) attached to light engine.
Good Luck
Do not forget to Rate!!
Dals123
Jan 03, 2009 | Hitachi 60V500 60" Rear Projection...
Tv discoloration
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Aug 29, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Yellowish tint on all channels
Hi, bad news guys, from your brief description you have a bad light engine, you both need to have a tech verify this but thats most likely what is causing your symptom. This is NOT a layperson repair, you`ll need a tech, BMW Rider
Dec 05, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue tint on corner of tv hitachi 50v500
simply tease the blue transition patch with a positive charged magnet
Oct 15, 2007 | Hitachi UX21511 Projector Lamp for 50V500
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
726 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
