Question about Maytag MZD2766GES Side by Side Refrigerator
Maytag MZD2766GE Temperature control on refrigerator side does not appear to be operating. As recent as two weeks ago, items on the refrigerator side were frosting. Now the temperature will not cool below 60F. We pulled the refrigerator out and vacuumed out around the motor and underneath; pulled out all the food; and made daily adjustments to the temperature setting (owner's manual states not to move setting more than 1 setting point per 24-hours). The appliance is only 5-years old. I have an old Frigerdare in the basement that is 20 years old or more and still kicking! Any assistance by "The Experts" is greatly appreciated.
  • Kevin Mc Apr 06, 2008
    Do you think the refrigerent may be leaking even if the freezer side is working well?
  • 549 Answers
Apparently, you will need to call a service man.
You may be low on freon.
Sometimes leaks occur and are not serviceable except by a service man.
I recommend that you find a service man in your area. There may be one at this website listed who would be close.
Posted on Apr 06, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Apr 07, 2008
    No,
    If the freezer side works well then you have a problem with either circulation of air or thermostat control. The following is a generic schematic of a refrigerator circuit. This will give you some idea of the controls.
Hello, Problem with Maytag plus Side by Side refrigerator model MZD2766GE.The Freezer part is working fine but the fridge part is not cold at all even after I adjusted the temperature to number 8. I do not...
You most likely have a defrost heater and/or defrost term switch. (switch is built into heater on your fridge).that needs replaced causing your coil to completely freeze up and blocking cool air flow to fridge side. Here is the part you need to order.
http://www.appliancepartspros.com/part_details.aspx?part_id=4069923
Thanks, Randy
Feb 07, 2011 | Maytag MZD2766G Side by Side Refrigerator
Refrigerator side doesn't feel cool but the freezer side is cold for a Maytag refrigerator model # MZD2766GE
Is there ice build-up in the back of the freezer? If so take the panel off the back of the freezer section inside the freezer and replace the heating element.
Jul 21, 2010 | Maytag MZD2766GES Side by Side...
My Maytag MZD2766GE dispenses water but does not make ice
check water valve, also your water line for ice maker could be frosted that happen always, but reason is bad water valve....
appliancesrepairla.com
Jul 01, 2010 | Maytag MZD2766GES Side by Side...
Mzd2766ge, is running but will not get cold. you
You have either a bad start relay/overload combination (12002784 - if the first two numbers in your serial number are from 10 to 26) (12002794 if the first two numbers in your serial number are 27 and higher).....or you have a bad compressor.
Dec 30, 2009 | Maytag MZD2766GES Side by Side...
Ice is forming on the bottom of the freezer side of my MAYTAG MZD2766GE SIDE BY SIDE and water is leaking out of the bottom onto the floor. This happened before and the repair guy said it was a drain...
unplug unit and let sit overnight, the return air ducts are icing up, if you help the defrost process it will take a couple of hours, use your hairdryer to blow warm air in the freezer compartment for a couple of hours , good luck
Nov 07, 2009 | Maytag MZD2766GES Side by Side...
Frigidaire Refrigerator FRS26H5ASB5 side-by-side
Hi, yes, your thermostat could be faulty, yes there should vent( damper), check controls on freezer side, controls amount of cold air going to ref. side, yes could be stuck by ice, yes both adjustment are necessary, check manual, some thermostat are very sensitive, you should adjust gradually, wait for about 40 minutes, before adjusting again. yes there's vent flap (damper) yes that could be your problem, normally they get stuck with ice, remove covers to locate it., you 're smart, you will see, damper, good luck.
Aug 12, 2009 | Frigidaire FRS3R5EMB Side by Side...
Where is drain hole on maytag MZD2766GE side by side refrigerator
in the freezer at the bottom can be seen by removing back panel hot water will open it up if not blow through with small hose
Apr 17, 2009 | Maytag MZD2766GES Side by Side...
Maytag MSD2657HES Refrigerator Side by Side
The air that cools the refrigerator section comes from the freezer. The refrigerator temperature control controls the run cycle. You may have to replace or have the thermostat replaced. The temperature control has failed.
Jul 29, 2008 | Maytag MSD2756G Side by Side Refrigerator
Maytag
on some Maytags if the defrost thermostat in the freezer gets above its setting (around 50 degrees) the fans won't run. It shouldn't be like that very long...10 minutes tops then they'll come on all by themselves.
Dec 28, 2007 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
532 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
