Question about KitchenAid KSB5 Professional Stainless Steel Work Top Blender
Rubber drive wheel disintegrated. How do we replace?
  • 145 Answers
The rubber wheel is known as the "coupler." To clarify: the coupler is a black, cylindrical rubber piece that juts out of the top of the motor base and you set the pitcher on top of it.
This part can be replaced through a Kitchenaid certified service center, where they can provide the part for you. It is a low-cost repair.
A listing of certified Kitchenaid locations may be found here:
http://caservice.kitchenaid.com/
Also, if you are interested in self repair, you may order the part and view do-it-yourself instructions here:
http://www.mendingshed.com/kacoupling.html
Posted on Jul 08, 2009
  • QuietRiot Jul 08, 2009
    http://www.mendingshed.com/kacoupling.ht...
SOURCE:
How do I remove the little pin at the base of the shaft so I can attach new rubber drive
That is a roll pin and you need a punch the size just smaller that that little pin. Then you can just tap it out with the punch and a hammer. Remove the drive and replace and tap the pin back into place to hold the rubber drive.
Nov 12, 2014 | For Your Kitchen Bamix Professional Stick...
Blender blades do not rotate
it sounds to me that its riped the drive dog out of the blades i know the black wheel is striped off, i gees the lad put a house brick into it and span it up if thees blenders are left not in use for a time they can seize up and most people never think to turn the rubber wheel to see if the blades still go around first thats how they get striped out, sorry im not much help here
Oct 24, 2009 | Back to Basics 600 Smoothie Plus Work Top...
Krups 239 blender drive gear.
Like you, I am all for repairing and keeping the world free of blenders that only need one part replaced. The rubber coupling was easily ordered online, the challenge I later found was to remove it without losing my sanity. After messing up the side grill of the blender pretty good, I realized there is an opening on the motor casing that allows access to a "gear" that is firmly attached to the axle where our little friend will hopefully screw on and restore the contraption to a working state. In order for you to see (which I must warn you, it's not much of a view) through the grill you will need a flashlight or book light. Towards the top of the aforementioned gear (not the rubber part) there is a groove in which a flat screwdriver can easily fit immobilizing the axle and allowing you to easily unscrew it. Oh, but wait, I forgot this is the faulty part and it will spin without the slightest torque on the axle thus never loosening or getting it unscrewed. My solution to this problem was to surgically remove as much rubber as possible to allow me to attach my vise grip to the nut and finally put this thing out of its misery. Using the same procedure of inserting the screwdriver to immobilize the axle I was able to screw the new part and voila the blender is fixed!!!!
Apr 08, 2009 | Krups 239 Power X Plus Work Top Blender
Krups 243 blender clutch wheel
These little jewels are threaded onto the motor shaft so they tighten up when in operation. To remove, you will have to immobilize the motor shaft. See if you can insert an icepick or screwdriver into the blades of the motor fan on the bottom. Then using a punch and hammer, gently tap the clutch disk in the direction opposite from its normal rotation.
BE CAREFUL not to use so much force that you break either the clutch disk or the motor fan blade.
Mar 12, 2008 | Blenders
How to install replacement part
You need the remove the old gray rubber knob. I did it in a barbaric way just hacking at it with scissors. Once you've removed all the rubber, you can use pliers to remove the remaining metal base. Once that's removed, place the new piece on the post and spin it on. Most important, spin clockwise to loosen, not counter clockwise like most items.
Oct 25, 2007 | Blenders
DeLonghi DBM8150 problem
These instructions disassemble an electrical appliance. You should have some technical/mechanical/electrical experience to attempt this and you do so at your own risk.
See exploded diagram : http://www.kenwoodservice.co.uk/uk-delonghi/exploded/exploded-KF8150M.pdf
This is not a very good diagram to show the disassembly, however, it will at least help me to identify the parts.
Prise out the center insert in the drive wheel (#15 on the diagram) on the top of the base unit (I used a paring knife and worked my way around the circumference to work it loose).
Remove the four rubber feet (#19) from the base by pulling them out.
Undo the 4 phillips head screws in the holes where the feet were.
Remove the base and carefully position it along-side the body of the blender.
Prise off the silver switch knob (#13) - it slides straight off the switch shaft and I used a screw driver to carefully lever it off, working from each side a little at a time.
Undo the drive wheel on the top of the drive shaft by holding the fan on the bottom of the drive shaft and turning the drive wheel CLOCKWISE.
Undo and remove the two screws holding the switch support (#11) and cut the tie wrap that secures the blue cable to this support.
Undo the four screws that secure the motor assembly to the casing and remove the screws and their shake-proof washers.
Remove the internal components as a single assembly. Tilt/angle the motor assembly towards the switch support until the top of the shaft clears the rubber boot in the top and then the whole lot comes out easily.
To replace the switch (Part No. HS1144 - #10 on the diagram):
Carefully lever the white gear wheel off the switch shaft.
Undo the two small screws that hold the dial gear wheel cover in place on the switch support.
Remove the cover and the small gear wheel (noting which way around the gear wheel goes the two ends of the shaft are slightly different).
Undo the nut on the switch shaft that that secures the switch to the support (nut is 14mm diameter and needs a thin wall socket. I used long nose pliers to remove and re-install it).
The wires connect by simple push fit into their slots and the angled brass blades inside the slots grab the wire and lock it in place. To withdraw each wire, use a very thin screw driver (or similar) to depress the brass blades inside the slot. This enables the wire to be withdrawn as you depress the blade.
Re-assembly is the opposite sequence.
When putting the dial back together, remember to check that the dial reading lines up with the switch position (adjust the gears by resetting the teeth if the alignment is not correct.
Here’s the really interesting thing. After I replaced the switch, I pulled the old one apart. IT HAD FAILED BECAUSE THE CONTACTS HAD BURNT OUT. They had obviously been arcing and had completely burnt through. There were burnt off tails of the contacts lying in the switch housing and there was evidence of burning (carbon deposits) inside the switch. In short – the switch is not up to the job and will fail. Poor design and a latent defect.
Aug 17, 2007 | DeLonghi DBM8150 Work Top Blender
How to replace the rubber drive in Krups 572?
it's not easy. you will need a set of pliers, a flathead screwdriver, and a phillips screwdriver. first, remove the 4 rubber plugs from the bottom of the blender (just work them out with your fingers). second, use the phillips screwdriver to unscrew the 4 screws that were under the ruber plugs. the blender should come apart. right in the bottom center on the inside of the blender you should see a steel rod with a groove in it. this rod will run all the way to the top and be connected to the rubber gear drive on top. get a firm grip on the rubber gear drive with your pliers. place the flathead screwdriver into the groove of the steel rod and unscrew. it will be very tight, but eventually, it will give. you will most likely destroy the old rubber gear drive in the process, but the idea is to replace that one anyway. good luck!
Q. Mosley
Jun 09, 2007 | Krups 572 Power Xtreme VI Work Top Blender
KitchenAid KSB5 Professional Stainless Steel Work Top Blender Logo
702 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Steve Allison
Steve Allison
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
