Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
My calculator is frozen how do i get it to stop?
So in class the other day i was playing pong from marage os and i tryed to quit and then it said garbage collect so i asked my teacher and he said to say yes and it was frozen the whole clas and then i took out the batteries and then put them back on and it was on the same screen and it sayed garbage collecting still and so i took the batteries out for 24 hours and then put them back it and the same thing happened. so then i tried taking out the memory batterie and it won't come out what do i do? please help
This problem is in another article HERE
Posted on Apr 09, 2008
TI-89 Screen not Responding
Remove one of the AAA batteries.
Press and hold CLEAR while reinstalling the AAA battery.
Continue holding CLEAR button and press ON.
Release buttons and press CLEAR again.
Jan 29, 2013 | Texas Instruments TI-89 Calculator
TI-89 Titanium screen frozen at apps menu
Remove the small memory battery, and then remove one of the four AAA batteries, then while holding down the APPS button reinstall the AAA battery and then it should say waiting to recieve operating system then hook it up to your computer with the silver connect cable and then on the computer send the operating system to the TI89 Titanium, and wait for it to install completely and it should work.
Sep 12, 2012 | Texas Instruments TI-89 Calculator
Hello, My TI-84 plus crashed some days ago i opend an app, ( hangman) and i tried to close it by pressing DEL what usely does the trick to get out of the app but this time it got stuck and i left it on...
Hi
it look like the Calc is frozen
try to connect to the computer and install the OS again
if it will not help then it need a hardware reset that only a certified technician can do
hope it will help
Jun 20, 2011 | Texas Instruments TI-84 Plus Silver...
TI-84 Plus Silver Edition not responding!
what helped for me is leaving it w/h any battery's (no backup battery either) for a few days. Now miraculously it works!
May 06, 2010 | Texas Instruments TI-84 Plus Silver...
Same as last time
Be reasonable in what you say especially when you seem to infer a blinding truth. If your screen were broken you would not be able to "FIX" it through a connection to another calculator.
I know. Sooner or later you will post another similar question so better learn what the real problem is.
Casino swamps your memory and messes up you calculator. If no more memory is available you cannot get any response from any key.
Play Casino as much as you want. Stop the game before you win that fateful 120000 dollars. Reset the Ram and play again.
Reinstalling the OS by connecting the calculator to another unit effectively reset the RAM and kicks casino out of memory.
To reset the RAM before the calculator is completely frozen, press [2nd][MEM][7:Reset][1:All Ram][2:Reset] [ENTER]
Calculator answers with Ram Cleared. Press the [CLEAR] button to erase that message.
Jan 06, 2010 | Texas Instruments TI-84 Plus Silver...
OS failed now installation screen stuck
I suggest you interrupt the installation with [Esc] or [Diamond][QUIT]. Then download the OS on your computer and drag and drop OS on the open window of TI Connect to transfer it to calculator.
Press the [Diamond][QUIT] several times. If it refuses, all that is left for you to do is remove main batteries and restart the installation as described above.
Hope it helps.
Sep 30, 2009 | Texas Instruments TI-89 Calculator
Stuck on Software Installation screen after failed OS instal
You do not say if the installation proceeded to some degree or did not start at all. It seems to be hung because the website was too slow.
Hope it helps.
TI-83 Calculator RAM cleared
To clear the message press [CLEAR]
If calculator shows message after you turn it [ON], it may be due to drained backup battery. If you have to change it make sure you have main batteries in and in good state, and installed.
If calculator appears frozen, press [2nd] [QUIT] to interrupt what it is doing.
I see you do not have the latest ROM (OS). You should download the latest ROM (1.19) and install it.
Use the education.ti.com link to download the TIConnect software. Install it on your computer. Run the TIConnect software. Connect the calculator to a computer (USB cable or TISilverLink cable or TI Graphlink black cable). Press the ON button, do not worry if you do not see anything on screen (contrast may be too light).
In TIConnect main window, click the TI Device info button. The software will try to detect the calculator. If the answer is NOT FOUND on any of the ports, click the communication settings at the bottom of the window.
Select Device: enter you calculator model
Select Cable: SilverLink, USB,
Select port : USB1 or COMx
and click OK. The TI connect software will give you some messages if communications with calculator cannot be established.
If you establish communications with the calculator, press the Update button in TIConnect main window. Install OS directly to the calculator. You may update other installed applications.
If you cannot communicate with calculator with the computer try to update by cal-to-calc connection with a working calculator/
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-83 Plus Calculator
Random symbols, upside down and on the bottom of the screen
You should reinstall the system which you find here
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=1&paneId=2
Use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there.
Install TI connect on your computer and run it to open the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. Software will try to retrieve the info. If it does your calculator is fine.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and Click OK..
If you are lucky and it works, you should reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the OS of a working calculator. Yous should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator, you guessed exactly right, must be on Send [2nd][Link][SEND][G:SendOS]. (When both calculators hit [ENTER])
If all that does not work, then it may be time to head for a place of worship to pray for its resurection, or look for a repair shop.
Hope it helps
Jun 30, 2009 | Texas Instruments TI-83 Plus Calculator
Screen frozen
When you turn the machine down, it rests where you left it, in the state you left it: In case you wanted to continue with the same program, what you have already accomplished will not be lost.
After you turn it on, Press [2nd][QUIT] or just press the [HOME] button, and it will take you home.
Hope it helps
Jun 15, 2009 | Texas Instruments TI-89 Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
231 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
