Question about Kenmore 43142 Front Load Washer
MY WASHER STOPS AFTER EVERY CYCLE. I HAVE TO MANUALLY TURN THE KNOB BETWEEN CYCLES
  • 552 Answers
I suspect your problem is in the timer.
This may have to be replaced.
If you are handy, it would be worth opening the washer and do a visual check of the timer.
Then get back to me and tell me what you see.
If nothing is obvious, then I would recommend having a service man come, because you may have to replace the timer.
Posted on Apr 06, 2008
SOURCE:
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
My washer goes through all the cycles until rinse. the knob stops and nothing happens. I manually move knob a little more through cycle and it starts the process. Again it stops on rinse. I don't think the...
I'm thinking it may be the lid switch that is not operating correctly. It might be that the lid is bent slightly up on one side. Check where the lid presses down underneath into a slot where the switch is located. test with a toothpick to see if the on off clicking sound happens.
If all is OK then I will think harder
Feb 27, 2011 | Indesit W 123 Front Load Washer
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
My machine will just stop after the adgitate cycle.
Manually turn the knob to the spin cycle and turn it on.
If it does not spin, replace the lid switch.
If it does spin, replace the timer.
Feb 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer stops in mid cycle
have a front load mah9700a. Unit will not run door is locked , have found that control board shorted. Still need to open door manually, need a parts scheme to look on how to open????
Sep 03, 2008 | Washing Machines
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
The cycle knob just starts clicking through the cycles
I am having the same problem with mine. Call customer support and was given voice mail.
Dec 13, 2007 | Equator EZ 3612 CEE Front Load...
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Kenmore 43142 Front Load Washer Logo
37 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
