Question about Husqvarna Designer I
Mega hoops I do I attach the clips on the Mega Hoop so it doesn't pop open or come apart. Rosemary Finney rosemary@parkspringscommunities.com
  • R Finney Apr 08, 2008
    worked on first try but need to do it again before I'm sure.
  • 201 Answers
Yes, they are awful to try to get into place at first. I kept trying and gave up but finally got my dealer to show me how, and it was so easy it was embarrassing! However, it is not the sort of thing that can be explained in writing - you really need to see it done - but here goes. You need to find the sort of square "hollows" along the sides of the inner hoop - they are located inside the big triangles, opposite the triangle's apex. The clip goes with the "handle" sticking up, and it faces the inner hoop. The little scooped up bit sits inside the square hollow. It is confusing because you look at it and think that the square hollows are too small to take the clips, but the clip actually slides down the edge of the inner hoop - there is a slot between the edge and the square hollow. The scooped up bit is the only bit that actually sits in the hollow. When you are practicing without fabric in the hoop, it is loose and the clips might drop off but once you actually hoop something, they work fine. To add to the confusion, the picture on the front of the box does not show the same hoop as I have. It must have been the beta version for the megahoop. Hope this helps you. Don't give up!
Posted on Apr 15, 2008
  • 549 Answers
Try this. Click here.
Posted on Apr 06, 2008
    Genius:
  • 1,665 Answers
When I install embroidery hoop light keeps blinking n saying wrong hoop size looked it up n it's saying malfunction
Ok, there are a couple of possibilities, and I'm going to include an image. I"m not sure whether you're trying to use the small or large hoop, but the first thing you should try is turn off the machine, take the hoop off entirely, then turn on the machine without anything and let it reset to its default position, which will be the center. If it has a problem there, make sure the needle it at its highest position.
Next, put the large hoop on, bring up a design, (preferably a design that came with your machine--there are sample designs in the \Library directory where the program is--that's generally in c:\program files\futuraquartet--and is designed for the hoop you're trying to use, and transmit to machine. If it tells you the hoop is the wrong size, download a patch from www.futura-support.com. If it STILL tells you you have the wrong size, reseat your USB cable into the machine and tape it in place with masking or duct tape.
The third possibility--and the one pictured in the photo I'm going to attach--is there is a tab on your hoop which indicates the hoop size, and your TAB may be off. It needs to be dead center of the sensor, which is also pictured. A while ago a BUNCH of hoops were manufactured with the tabs slightly off, and if it's off, your machine can't read the size. What generally happens there, though, is it will indicate that there is NO hoop attached, rather than the wrong size.
You can see the sensors--they're inside the arm where you put your hoop, and they're not covered up. Below it are the large hoop (top), and small hoop (bottom). The hoop tabs have to match up to the sensors exactly, and you'll be able to see if it doesn't by matching up the notch in the hoop that matches the catch in the embroidery arm.
Oct 20, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Use elna mega hoop
Read the instructions. If you don't have any download them from the manufacturers site on line.
Jan 17, 2014 | Sewing Machines
My mega hoop is on, but the screen keeps telling me the color block is not allowed on both sides how do I get it to go???
I have a Designer Diamond, and I experienced the same error message of "color block not allowed on both sides of hoop". I was trying to resume my project a day later, and received this message when I attached the hoop. I made several attempts to fix this problem and get rid of the error message to no avail. Finally I just checked the hoop size on the screen of the machine and noticed it was showing the wrong size hoop attached! I picked the correct size for the hoop I had attached, and viola! - message gone! and I was able to continue on with my project!
Jan 16, 2014 | Husqvarna Designer I
Can i do a large applique with my pfaff 7570 using the large hoop
Both the 7560 and the 7570 will only stitch out to the largest hoop it came with which is a 120 x 115 CM hoop (approx 4 1/4 x 4 3/4 inches). If you are using the Creative Big Fantasy Hoop or a Hoop-it-All you will need to split out the design so that each piece will fit within the 120 x 115 hoop. Transfer both designs to the machine. If using the original hoop, hoop your fafabric and stitch out the 1st design. Unhoop and rehoop again aligning the fabric with the hash marks on the hoop. You will have to move the design around on the screen to make a perfect fit. Stitch out the 2nd design. If you are using the Creative Big Fantasy hoop, you just have to hoop the fabric once, stitch out the 1st design and loosen the side screw on the hoop and slide the hoop into place for the 2nd design. Stitch out the 2nd design. The same process applied to the Hoop-it-All.
livingintx@yahoo.com
Feb 28, 2013 | PfaFF Creative 7570
Jumbo hoop
I assume you mean the clips that attach the hoop to the embroidery unit. You just hold the hoop by means of the two clips, with a thumb and other finger on the outside of each clip - pressing them together allows the hoop to be put onto the two clips on the Y arm of the embroidery unit. When you release the spring pressure, the hoop should be retained in place on the Y arm.
Nov 25, 2011 | Bernina Sewing Machines
My futura ce200 is driving me insane because i have the small hoop selected on the computer but the machine thinks that the large hoop is selected. How do i fix it??
Before attaching small hoop, turn on power switch to
move the carriage to embroidering standby position, and
turn off power switch.
check troubleshooting in manual
user manual link
http://www.futura-support.com/files/CE200-Eng_Fre_Spa040607.pdf
hope this helps and you get it working soon =)
Feb 05, 2010 | Singer CE-200 Quantum Futura Computerized...
Machine says that I don't have an embroidery hoop attached, but I do.
First turn off and disconnect embroidery unit and hoop from the machine. Plug machine back in and connect the embroidery unit only and turn the machine on. Reattach the hoop and test to make sure it's secure. Your hoop might not have been attached snuggly enough or you might need to put on the small hoop.
Dec 22, 2009 | Bernina Artista 180
I'm using the Mega Single Hoop for the Viking Designer SE embroidery machine, because my design is too long for any other hoop. When I try to embroider, however, I get the message "Design outside hoop...
1. If the design came from the internet or a design package, it's possible that it's "center" has not been centered properly. To correct this you need to open the design in the Husqvarna Viking software and click on the "Center in Hoop" icon. That function redefines the center of the design so it will align properly in any hoop that it fits within. If you have 3d software, after clicking on that icon you physically have to put the black crosshair that designates the center in the design, in the very middle of the hoop and then save the design to your computer, then send it to the machine. The 4d software automatically centers the design in the hoop when you click on the icon.
If you have the software and you "combine" any designs together you must always click on the center design icon to recalculate or redefine the center position and then move the design's center to the middle of the hoop before saving the design. This way you center the designs center positoin around the needle position. Meaning that when you hit the start button on the machine, where ever the needle is, is where the center of your design is.
I hope this helps
Oct 15, 2009 | Husqvarna Designer I
Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Nov 16, 2008 | Singer CE-200 Quantum Futura Computerized...
I have a futura 150 and I can't get it to change hoop settings. I will put the small hoop on it but it doesn't recognize it. What do I do to fix it. It will change it on the computer screen but doesn't on...
Do not switch on the machine with the small hoop attached. After changing the hoop reload (close and open again) the design or restart the software or select the small hoop manually from the menu.
Aug 26, 2008 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
247 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Bargain Box
Bargain Box
Natasha Subko
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
