Question about LG enV VX9900 Cellular Phone
Typing * symbol
When ever i insert the * symbol, it inserts the number 86 after, and keeps adding 86 every time i enter a star(*). I have had the phone for a day and it worked before
Any suggestions?
I have tried shutting off my phone and turning it back on.
  • 2 more comments
  • Anonymous Jul 23, 2008
    When I try to type $ and hit sym 4, hit gives me "$119?" everytime.
  • PretenderNX Jan 04, 2009
    I have the same problem- NOT in T9 Word. Its when I use the text entry in creating a message.
    I hit SYM + K to make " and it types "Eh,
    Also I type SYM + 4 to make $ and it types $30
    Both times with the cursor between the character I want and the stuff I don't. I can remember once typing those values but I never tried saving them in any way. Not sure why my eNv thinks I want them.
  • Anonymous Jan 05, 2009
    I have a very similar problem to the ones noted above.
    When texting (with the QWERTY keyboard), everytime I enter * (SYM+8) - I get *228.
    When I enter $ (SYM+4) - I get $40.
    When I enter " (SYM+K) - I get "143".
    These appear to be the values I entered the first times I texted using these symbols. However, everytime I want to use these symbols, I don't always want to use these values!
    This happens while Texting with the QWERTY keyboard only. When texting using the front keypad, that doesn't happen, obviously.
    WE NEED HELP!
  • Anonymous Feb 18, 2009
    Same problem here, when I enter symbols I additional words or digits.
    " becomes "I'm
    ( becomes (2.2ghz)
    $ becomes $1.50
This is a problem with LG's T9 autocomplete database that affects other LG phones as well.
I have a solution, but it's not for the feint of heart. It requires BitPim (bitpim.org). BitPim is a great app that does a lot more than fix this problem. It can be used to backup the data (calendar, contacts, notes etc) on your fone onto your own computer as well. Be warned though, it's not very user-friendly and it can be a hassle to get it set up at first.
You can learn more about BitPim from here.
Anyway, assuming you have BitPim working and talking with your phone (don't ask me about this part, see the link above)
Open BitPim, and look through the phone's Filesystem. This selection isn't shown by default. On a mac (and probably PC too), go to the view menu, then select "View Filesystem". "Filesystem" with a brown drawer icon will appear in the left hand column of the main window.
After the data is loaded from your phone, scroll down to "t9udb" folder in the second column. In the pane that loads, right click on "t9udb_eng.dat" and delete it. Restart your phone and the problem will be gone, and you can go back to using T9.
You will lose your saved t9 autocompletes, but you'll also get rid of this bug temporarily. This is a recurring problem, so you might have to delete this file every once in awhile. One way I've found to prevent this problem is to always type a space after a symbol. IE To type out "$260", I would type $ - space - CLR - 2 - 6 - 0
As annoying as this is, using this method is better than having to deal with all the weirdness that happens through regular use.
Good luck
Posted on May 21, 2009
If you're typing with T9word enabled as the default text entry, it will auto fill whatever you've typed before.
Put your text entry settings back to the standard ABC and the problem should go away! =]
hope that helps!
cause it happened to me too :p
Posted on Jun 23, 2008
If you are trying to call someone u have to make sure you use the symbol button before you put it in. when you put the star in you are calling your voice mail. If u r trying to txt then try taking out your battery.
Posted on Apr 09, 2008
Unlock password samsung gt-s5230
BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert a half of it,
so it won't ask for network password and shows "Insert SIM" message.
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#(star 7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable network lock By typing: #7465625*638*00000000#(hash 7465625 star 638 star 8zeros hash)
Phone is unlocked (check with *#7465625#)
If you find that SPLock is still on afterwards follow the below
After you do the reset, check and make sure that your network lock is active by pressing *#7465625#. If it isn't active you must use this code to reactivate it, *7465625*638*00000000*00000000#. Then you have to deactivate the sp lock first. To do that you need to input *7465625*77*00000000*00000000#, (this will reset the lock) then you enter #7465625*77*00000000# (to disable the sp lock). Then you disable the network lock #7465625*638*00000000# and the phone is finally unlocked.
Mar 03, 2011 | Computers & Internet
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Tip
How to use Blackberry as a modem to acces internet?
HOW TO ENTER special character like é SYMBOL ON NOKIA
Inserting special characters on Nokia E61 and E70
The most common special characters can be inserted by pressing the 'Chr' key and selecting the one you want from the pop-up grid.
If there are rarer characters that you need, note that ANY Unicode character can be inserted by simply holding down 'Ctrl' and typing the number of the character concerned - it will appear at the current cursos position.
Oct 11, 2010 | Computers & Internet
My samsung mobile GT-c 3053 asks for a password to unlock the phone. what is the unlock code . It appreas with screen Phone lock on the top followed by enter password. options OK and SOS on the left and...
turn off the phone
Jun 06, 2010 | Cell Phones
How do I get dashes inserted into my long phone numbers?
Well it should do it by itself,but if not then when your typing in the number ,switch to symbol mode by using the star key..then you can add your dashes
Jun 01, 2010 | Motorola Mobility RAZR V3
Hi i need a unlock code for my samsung phone do u know where i can get one for free as i have just spent 10 pounds and been conned
try these,
turn off the phone
Sep 27, 2009 | Cell Phones
How to unlock samsung gt c3053 mobile phone
turn off the phone
Sep 08, 2009 | Samsung Cell Phones
Network key samsung e250
unlock it by following...
turn off the phone
Sep 02, 2009 | O2 Samsung SGH-E250 Cellular Phone
I am trying to unlock my samsung u600, i have seen acode that requires entering #pw+.... it says you get "p" and "w" by pressing the * key 3 or 4 times but if I do this I just get 3 or 4 *s!! how can I...
Dear,
check it out...
turn off the phone
3.With out turning off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM"
regards,
hope it will fix the issue so dont forget to rate it...
Apr 18, 2009 | Samsung SGH-U600 Cellular Phone
LG enV VX9900 Cellular Phone Logo
703 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
