Dvd wont work
Rca drc8052dvd player recorder wont open to accept dvds at all and all the display will do is " hello" repeatedly
    Problem Solver:
  • 3 Answers
On my DVD player, the cover on the disk tray was setting too high. I removed the cover, cleaned the glue off and reset it. This time it was flush with the tray. It now opens and closes just fine.
Another possible solution is to unplug and replug-in player. You still may have to do this after using my first solution.
Note: My DVD player also starts showing "hello"
Posted on Aug 28, 2009
  • 81 Answers
Sounds like ejector controler . or it most likely ready to give up on you. Most warn out dvds have that issue.
Posted on Apr 06, 2008
SOURCE:
Does not record from vhs to DVD blanks. Will not accept DVD blanks for recording.
The blank DVDs may be of the wrong type for use with your recorder.
Jan 23, 2015 | Televison & Video
What DVD works with the RCA Model DRC8295N as I triedDVD+R and DVD-R and neither disk can be read by this machine.?
I use Verbatim (DataLifePlus) DVD+RW Rewritable dvds and I have recorded over 35 dvds and never had a problem. If I remember correctly, I bought them at BestBuy.
Oct 19, 2010 | RCA DRC8295N DVD Recorder/VCR
Recorded dvds do not play on my dvd players
DVD+r against DVR-R or DVD RAM or mulitsession not finished by burningapplication
RCA will probably be older and only DVD+R compatible
You burned DIVX's then morre compatibility issues arise.
CBR and VBR sound compression i.e. and codec not provided.
Pls rate me for assisting.
May 07, 2009 | RCA Televison & Video
Unit only displays "hello"
This is a faulty condition caused by lack of error control in the firmware. Try this:
Unplug machine from wall for 5 min. Hold "open/close" button in and then plug machine into mains whilst continuing to hold the open/close button. Keep holding open/close button for about a minute, as these machines are notoriouly slow to "boot". It that doesn't work, repeat the procedure, but hold down the power button instead of the open/close button in an attempt to reset the memory settings of the unit. Good luck.
Feb 08, 2009 | RCA DRC8320 DVD Recorder/VCR
Samsung DVD recorder
did you try a lens cleaner disc?
Jul 30, 2008 | Televison & Video
RCA DRC8030N Problem
This is due to the DVD-RW drive that is in the unit. This is the first to fail and RCA seems to have gone with the lowest bidder on this model. The DVD-RW drive will need to be replaced. If you used the DVR to watch and burn DVDs then you will need to replace it with any computer DVD-RW but you may need to re-drill some holes to have the replacement drive fit exactly aligned with the DVD door. If you only want to use this DVR for the internal hard drive recording and TV viewing, then any CD or DVD computer drive will do, just simply connect the replacement drive and leave it in the case (you wont have access to the DVD or CD drive under this option). If you do replace the drive, make sure you match up the jumper on the back so that it will be in the same position as in the original DVD drive ( the Master setting). I hope I did not scare you with all this information, but unfortunately, the dreaded HELLO issue with the DRC8030N has no easy fix.
Jul 09, 2008 | RCA DRC8030N
Televison & Video Logo
181 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
