Dvd turns on but i cannot get the menu function to work
  • Anonymous Jun 14, 2008
    Can't get the remote to show any display after hitting setup, enter, the up down arrows never get to a menu.
  • 81 Answers
Menu from the dvd or the remote? it should work of the unit itself
but if it does not then main ckt/board issue.
Posted on Apr 06, 2008
SOURCE:
Remote menu button not working
Sometimes you can enter a code that will work nearly all the buttons, but is not the correct code for your DVD player. You should try other codes. But sometimes a universal remote will NOT work every function.
Dec 22, 2012 | Toshiba SD-V392 DVD Player/VCR
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
Unlock Hand Brake function on Ripseed DVD-733B
Go into the second menu by pressing and holding the volume control for 2 seconds. The last option in the menu says
"Parking". Turn this to off and you'll be good to go.
Jan 17, 2010 | Car Audio & Video
Pioneer dvd player will turn on but will not function - Pioneer name displays on menu screen but that is all
Will turn on but displays no signal across a blue screen. I did have it working but only in black and white for some reason. I need an owners manuel as well. thanks
Oct 21, 2009 | Pioneer DV-260 DVD Player
How do i turn off child lock
Depending on the model of you hardware, you can generally
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Cheers, eiger3970.
Jul 28, 2009 | NEC NDT44 DVD Player/VCR
How do I reset the Cyber Home 300 to defaults?
Check your owners manual. find the function by using the on screen menu, turn this on by pressing the menu button This function is usually in the setting functions and is usually found by using the up and down arrows to find the settings function and then using the right arrow to enter the function. After entering the function you should find the factory reset function among the listed settings.use the up and down arrows to find this setting and place the cursor on it and press enter and it should reset all the functions to the factory settings for you. Hope this helps you with your problem.
Apr 19, 2009 | Cyberhome CH-DVD 300 DVD Player
How do I get to the ''Menu screen'' when playing a DVD movie?
It's likely the remote has the wrong code, so it will only work certain functions. You need to try lots of codes, if you do not know the player's code, till ALL function buttons work, not just some.
Aug 09, 2017 | Logitech Harmony 670 LCD Remote Control
TURN OFF PROGRESSIVE SCAN PD 800
Try with this,with the disc tray empty turn on the dvd then push for 5 seconds the button stop.If this don't work connect to the tv on the video signal the y connector you got signal on black in white but you can see the menu to deactivate this function.Good luck.
May 28, 2008 | Protron PD-800 DVD Player
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
GoVideo DVD/VCR combo
turn on menu function or settings with the dvd remote then look for caption options
Dec 31, 2007 | GoVideo Go Video DVD/VCR Combo
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Ekse
