Question about PNY GeForce 7600 GS, (512 MB) AGP Graphic Card
Installed new graphics card and Windows won't start
The error message says primary hard disk failure. Before the error message occurs the new card info (text) is displayed on the screen for a few seconds. I had a radeon 9700 Pro 128MD AGP go bad and replaced it with a PNY 7600 GS 512MB. Running XP on a Dell PC that is 6 years old. I also tried uninstalling the driver to the old graphics card. When I put the old card back in the AGP slot the computer starts up but the display is messed up. Please let me know if there is other things I can try.
Thanks,
DB
    Scholar:
  • 119 Answers
If your new video card has a power connector, make sure it is connected to a power plug. If you already did that, it's possible your PC's power supply doesn't have enough power to run all your connected equipment.
To get your old card running, hit F8 repeatedly during boot-up until you get the boot options. Select VGA mode. It should boot up properly then.
Once booted into VGA mode, set your screen resolution to something simple like 1024x768 or 800x600, then reboot.
If that doesn't work, try hitting F5 repeatedly during boot-up to boot into Safe mode. You can then adjust your settings again there.
Posted on Apr 07, 2008
Laptop won't start up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 12, 2012 | Toshiba Computers & Internet
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
Nvidia boot agent ?
I would state use the Restoration Disk, and perform a Repair. (Non-Destructive Installation)
This will repair the Nvidia settings for YOUR computer.
But more than likely Acer did not provide a Restoration Disk, and it is my understanding it may be hard to get a hold of. (Acer Support)
This makes me think you have installed a new Nvidia graphics card, since specifications indicate it comes with Integrated Graphics that is Nvidia GeForce 7050.
http://reviews.cnet.com/desktops/acer-aspire-m1641-u1521a/4507-3118_7-33234219.html
{Integrated Graphics is also referred as OnBoard Graphics.
ON the motherBOARD. The graphics chipset (GPU) is soldered to the motherboard, and Not to a removable graphics adapter card,
http://en.wikipedia.org/wiki/GPU
IF SO, the software (Installation disk) is installed FIRST, then the graphics card is physically installed.
IF not you get a driver conflict.
When a device is installed on a computer, (Such as a graphics card), Windows 'breaks it's neck' to find matching suitable drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This won't do.
Windows: "Which drivers do I use? These or THESE?"
[Drivers are small pieces of software, that allow the Operating System to 'communicate' with a device ]
Is this what you did? Install the graphics card, THEN use the graphics card's installation disk?
Post back in a Comment.
Regards,
joecoolvette
Feb 12, 2012 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    I cannot play my games after i reformat my computer. its say that i need an directx 8.1 or higher to play my game but i already downloaded directx 11 but is useless. nothing happens. same error message...
    click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
    extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
    If it's a ntdll.dll error the ntdll.dll error only displays when you use a specific software program,
    uninstall the program, reboot your computer, and then install the latest version again from scratch.
    until you know what the problem is you cant fix it or you might try
    you could run the check disk utility
    click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen
    click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
    do not do anything while the chkdsk utility is in progress any input will damage your computer
    hope this helps
    don't forget to vote
    when you restart your computer then defragment your hard drive
    you should not do anything while the chkdsk utility is in progress any imput may damage your computer also do not start if there is a possibility of a power failure (storm lighnining)
    hope this helps
    don
    Feb 20, 2011 | Microsoft Windows 7 Home Premium 64BIT...
    Geforce rivers
    This might be caused by a common conflict between your 7600 series videocard and your computers chipset. Try disabling "write combining".
    To do this, goto the display properties (on the Windows desktop right mouseclick and choose "properties"). Then choose the tab "Settings" and click the "Advanced" button. Now choose the tab "Troubleshooting" and uncheck the checkbox "Enable writecombining" and click the "OK" button afterwards.
    You might need to restart the computer afterwards before testing wether that solves your problem or not.
    If that doesn't fix it, try other/newer drivers. And when that doesn't help things, you might have overheated the card (and damaged the RAM chips on it). You might want to clean any dust from the card anyways.
    When the problem still occurs, please let us know, so we can continue troubleshooting ...
    Aug 14, 2009 | XFX GeForce 6200 Graphic Card
    A disk read error has occured press CTRL-ALT-DELETE to restart.
    check power chord or port of hard drive if u dont find any prob. pleace re insert power cord with card board packing. definetly u solve the problem.
    Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
    When powering up my computer, I get a failure. Primary hard drive 1 not found Strike the F1 to continue F2 to run the set up utility. I think the power supply fan is not working. What do I do?
    your system can not detect your primary hard disk which host the operating systems,so you check the data cable to the hard drive and the power supply to the hard drive for supply
    Jul 19, 2008 | Computers & Internet
    Disk boot failure, insert system disk and press enter
    The drive should be set with jumpers or cable select to be primary master. Some pc & drive combinations don't like cable select, others insist on it. Try both, one at a time.
    Jul 15, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
    Perpetual windows protection error loop!
    use a win ME startup floppy disc. get to DOS and run scandisc.exe on c drive. if still no progress afterward, then repeat but this time, load cd driver and then re-install windows.
    Oct 20, 2007 | Computers & Internet
    PNY GeForce  7600 GS, (512 MB) AGP Graphic Card Logo
    208 people viewed this question
    Top PNY Computers & Internet Experts
    David
    David
    Alun Cox
    Jim Thurston
    Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
