Question about iLO 2600 Television
Ilo 2600 need help to hook up cable & rca vcr
No manual- No info- Please help
  • Anonymous Apr 13, 2008
    lost remote trying to set tv up for direct tv
Go in to the menu and then keep pressing it until u get to vedio 2 and try that
Posted on Apr 09, 2008
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
Aug 25, 2010 | Toshiba Televison & Video
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Apr 13, 2010 | iLO DVDR05 DVD Recorder
Vcr hooked up, no audio
From the VCR to the tv if you have RCA cables its kind of hit and miss where the audio cord goes. Only one of the jacks are for sound but it has to be plugged in to the right input. Audio is usually the white one. Just keep touching it to inputs until you hear sound start to come out of the speakers. Hope it helps.
Jun 27, 2009 | Insignia Digital-to-Analog Converter for...
We need a new remote for our ilo TV in order to hook up a DVD-VCR player!
First off you will need a remote that has the ability to operate your ILO TV. www.remotes.com has a replacement that will work for you. As you will need to access the inputs for your TV to receive the signal from your Philips unit
Oct 10, 2008 | iLO 2600 Television
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Hooking up to audio out
try a rca y spitter that ma work for u
Jan 20, 2008 | iLO 2600 Television
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
Ilo 42"widescreen lcd tv
I hooked a sylvania 220sl8 dvd/cd/vcr, The vcr works, the dvd does not. Why?
Oct 27, 2007 | iLO 2600 Television
Televison & Video Logo
77 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
