Marantz CDR500 has record bay which no longer opens. I was told some time back that this is not repairable and that Phillips, who made the drive, no longer makes them so it is essentially a total loss. Is this true? Thanks.
  • Jukedoc1 Apr 09, 2008
    Thanks for trying, but if the answer were as simple as a slipping belt I wouldn't be asking. There is a known issue with these drives which Marantz says cannot be fixed. I was hoping someone out there might have some alternate solution other than throwing away a not very old and rather expensive piece of equipment.
  • 4,234 Answers
This is a tricky one, because from the view of an authorized Marantz servicer, the replacement "part" is probably the entire drive which may no longer be available. It is possible that the true problem is that the main drive belt is slipping. In that case, replacing the belt will fix the problem. As long as the unit is not under warranty, any service shop should be able to attempt a repair. They can not make it worse and perhaps can resolve it cheaply.
Dan
Posted on Apr 06, 2008
  • ABRsvcs Apr 09, 2008
    Perhaps you misunderstand. Marantz has no choice but to replace parts as listed. The drive is purchased from Philips and has no replaceable parts from Marantz' point of view. Carefully remove the drive and open it up. These have a small belt that you can purchase on your own. Try replacing this belt. Without seeing the drive itself, I can not state that this will resolve the problem. I can say that I have run into this problem as a warranty shop. the fix was to replace a belt. Because that belt was NOT a field available part (only the entire drive was), I could not fix the customer problem without replacing the drive.
    Dan
SOURCE:
My marantz cd 7300 reads no disc probably needs a new laser, where do i get one, thoes sold on ebay look different, many thanks, Peter.
This sounds crazy but it works for some reasons. Marantz CDR500 would not read and initialise some blank discs but no problem with reading finalised ones and erratic would and would-not work. Tried cleaning lens and even blowing ar through it. Before I wasted money in air I thought why not try hairdryer into open tray and lens area and just for measure across blank CD. I know this sounds weird but it worked every time and machine will read any make of disc like this. I do not have any scientific explanation only the fact that it works!!!
Nov 23, 2013 | Marantz Audio Players & Recorders
I have a Marantz CDR 615 and it won't let me record anything-any help would begreat thanks
What kind of error are you getting? Does it attempt to calibrate then display the entire disc as being full? If that try a blank that will tolerate recording at the 1x speed. Nowadays the only thing you will likely find are discs meant for audio recording or data discs that can record at speeds as low as 1x. If you can find some of the earlier kodak, Ampex/Quantegy, japanese maxells, etc then you will be okay. Also it may not be obvious but the cdr 615/620 will not record on cd-rw's
I bought one of those new and had nothing but trouble out of the phillips cdd2000 module that had to be replaced 3 times (3rd time at my expense of $300) but Superscope in Aurora, IL was good about support. Ironically I seam to remember a class action suit against Phillips over their very flaky cdd2000 drives.
Oct 01, 2010 | Marantz CDR631 CD Recorder
How can I digitize cassette tapes using the Marantz PMD670?
Take a set of RCA Jack cords (4 jacks) and on the tape recorders "out" jacks attach one pair and on the PMD 670's "In" Jacks attach the other pair. Set the tape a few seconds before where you want to record , set your levels to where you want them, start the recorder then start recording with the PMD.
You may need to test record a few seconds to make sure the recording is at the level you want it to be. Plug in a set of headphones to the PMD and listen in from time to time to make sure it's recording OK.
There you go.
Best,
Dan
Jul 01, 2010 | Marantz PMD670 Desktop Digital Voice...
PMD660 Handheld Digital Voice Recorder: I have a Marantz PMD 660 digital audio recorder. T...
This implies that there is not enough current going to the device when running on battery (only back-light but no data) whereas running fine on AC means that the device board is most likely in a good operational condition.
I think maybe once a leaked worn battery which left forgotten inside battery compartment damaged the battery terminals or at least the wires connecting these terminals to the main board, i would recommend you to open and check on that.
Sep 23, 2017 | Marantz PMD660 Digital Voice Recorder
Where can i get belts for my sd 230
To online companies sell spares for Marantz. They are: SEME and CPC.
I also seen belts sold on E-Bay.
Oct 17, 2009 | Audio Players & Recorders
CDR tray
it's more than likely the servo board which is fixed under the mechanism.
this is very common but i'm not sure which component fails on the board but i've always got hold of donor recorders and switched the servo boards and all was fine.
Sep 06, 2009 | Marantz CDR500 2-Disc CD Recorder
CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
Dfsfd
cdr keep open when power it on.
May 29, 2008 | Marantz CDR500 2-Disc CD Recorder
 Grubhead
Grubhead
Marvin
Marvin
