Question about Zanussi ZWF1440 Front Load Washer
Rubber door seal mouldy
I have noticed a really foul smell coming from my washing machine and on checking notice that inside the folds of the rubber door seal is very marked by mould spots. it seems that the water does not drain from this seal when the machine empties and lies in the folds. is this a problem which can be fixed? can the door seal be taken off and/or replaced?
  • 247 Answers
Wouldn't normallyexpect a few mould spots to leave that bad a smell, so likely you've got two distinct issues.
Starting with the water trapped in the seal: Open the door and very carefully slip your fingers into the seal where the water is gathering (to stop your hand getting trapped between the drum and the outer casing, put your other hand inside the drum and push it up out of the way - just be careful not to let it spring back too fast).
At the very lowest point,of the space inside the seal, either at the very front or the very back (so tucked into the corner between the floor of the seal and it's front or back wall), you'll find a little drainage slot. Once you've cleared the inevitable blockage from this slot, your seal problems should vanish.
If the foul smell is coming from inside the machine, the problem is likely to be grey sludge inside the works of the machine. This is usually caused by modern detergents not being quite as good at working at 30 degrees as they claim to be. The answer is to run a cycle every now and then with no laundry, detergent, or conditioner in the machine, on the longest, hottest programme the machine will support. This should be sufficient to dissolve the rotting sludge and pump it away down the drain.
A.
Posted on Apr 06, 2008
How can I remove, clean and replace the rubber gasket sealing the door on my GE front loading wahing machine?
Scrubbing the gasket in place using a child's toothbrush will accomplish the same end result without removing it.
Jun 30, 2017 | Washing Machines
I have a venus vw 1000 b washing machine and it looks like the rubber door seal has melted and left a smell of burning rubber? how can this happen?
Sometimes the door seal can vulcanise due to reactions from detergents. If you have noticed this then replacement is the only option as there will be water leak from the tub during wash.
check this link: door seal
Jul 05, 2012 | LG Washing Machines
I have a front loader washing machine. The rubber inside is going mouldy. I have tried to clean same without success - any suggestions!
Unfortunately, once the door seal goes mouldy it is impossible to get clean. Only option is to replace seal. Once seal is replaced, you need to wipe it dry after each wash and leave door ajar to prevent reoccurence of mould.
Mar 09, 2010 | Maytag Washing Machines
I have an LG washer that smells like rotten clothes. My clothes come out smelling real bad. I checked inside and noticed that the rubber seal around the door is holding moldy rotton gunk. It's not self...
Run a cup each of baking soda and vineger thru a hot wash. Might have to do this a couple of time if smell really bad.
Take out the unit where the liquid soap, softner, etc goes and clean by hand.
Soak a cloth in vinegar and clean the inside of the rubber around the tub.
And finally DO NOT LEAVE THE DOOR CLOSED IF NOT IN USE.
Oct 31, 2009 | LG WM2688HWM TROMM SteamWasher
Hotpoint WF340 washer machine. I have noticed the rubber seal just as you open the door has gathered water and now begins to smell, can you tell be if i can replace it, how much the part would be and how...
the door seal can be changed from the out side of the washer but its a devel of a job to do
its held on by 2 spring clips, one around the outer door seal you hook this off then you fold the seal inside out and the other spring is on the inner drum
to fit a new door seal first turn it inside out and clip the sealing spring over the inner drum, them pull the door seal over the outer caseing and put the spring round that bit,,,
net easy i sead!!!
if i were you if the old door seal is not leaking leave it be,,, just clean it up with a drop of bleach it should have drain holes in it have a look to see of there not blocked up, when ever its washing it should get flushed out every wash,, unless its blocked up,,,
Oct 26, 2009 | Washing Machines
Mouldy Door Seal
Use tilex to remove the mold. Then see what happens. If the mold comes back right away it may be a problem with the rubber gasket not seating as it should. Let me know. And please rate my solution. thanks.
Feb 02, 2009 | Zanussi ZWF1430W Front Load Washer
WT540 Washing machine has a smell coming from it
Based on the front load picture you included with you description...
This usually comes from a build up of soap and dirt that you cannot get to to clean. It is in the inner wall of the outer tub.
You should run a thorough cleaning with a product called Washing Machine Magic. It is designed to reduce this build up over time.
Another way to reduce it is use a very hot wash and put 1 cup of powder dish detergent in the tub before starting it. (yes I know this is a clothes washer). The dish detergent has ingredients to help reduce the odour.
These methods may have to be repeated several times to be 100% effective, but a large part of the odour should be reduced after the first cycle. If more are needed repeat once every couple of weeks until the odour is not noticeable.
The rubber door seal on this model should not accumulate smell but it may have depending upon the machine's age. This will have to be replaced if it has.
Aug 05, 2008 | Hotpoint First Edition FEW10P Front Load...
Mildew smelling towels and no separate rinse cycle
the problem is your door seal if you close the door after a wash then what happens is the water goes mouldy on the inside of the door seal what you need to do is replace the door seal you will never get rid of the smell without replacing it never close the door after a wash always leave it open to make sure its your seal the easy way is to look at the inner part of the seal and it will be mouldy only thing you can do
Oct 30, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
498 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
