Question about Dishwashers
BUILT IN SMEG DISH WASHER ADP8132 FILLS WITH WATER THEN DRAINS AND CUTS OUT. TRYED NEW MOTOR AND PCB NO BLOCKAGE NO LEAKS PLEASE HELP
  • 247 Answers
Does the water just disappear down the drain as fast as it fills, with no obvious pumping sounds?
If so, it might just be that the waste hose is routed wrong after it comes out the back of the dishwasher. It needs to loop up to somewhere near the top of the machine before coming back down to go into the drain. (These machines have no outlet valve - they rely on this high point in the hose to keep the water in, then use a pump to push it "over the hump" when they need to drain).
A.
Posted on Apr 06, 2008
I have smeg built in dishwasher. Acts like running cycle but i don't think it's getting enough water. the soap tables are not dissoved. before if opened door during cycle lots of water but now none
Check water inlet filter, check for blockage at the stop valve .
The rubber washer does come loose and blocks/limits the flow into the dishwasher. The fill cycle is on a timer and any restrictions in the water connection will under-fill the unit.
Hope this helps?
Jun 24, 2017 | Smeg Dishwashers
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Smeg washer dryer not draining
Sounds tricky you may want to try this site, there's loads of help, advice and videos to help diagnose faults.
Give them a try. Hope you get this sorted. How to diagnose draining problems
Jan 31, 2014 | Smeg WDI12 Front Load Washer / Dryer
LG drains and fills at same time.
This is caused by the " the flood" circuit at the bottom of the dishwasher that detects some water leak. Once this circuit detects any water on the bottom of the washer, it immediately switches the pump out circuit on. It consists of a polystyrene float coupled to a micro switch. You need to dry the bottom and then check for leaks (hose or hose clamp).
Jul 03, 2013 | LG LDS4821ST Stainless Steel 24 in....
My washer will not drain...it fills up and then stops no drain no spin
hi
if it fills then stops working,no washing motor action then you may have a motor or pcb fault,check motor brushes and connections.if it works fine upto rinse and dont drain check filter for blockage or drain pipe if plumbed to sink.
Aug 02, 2009 | Indesit W 123 Front Load Washer
Miele dish washer
I have a miele G 643 SCVI Ingognito the re-0cccurring prob is the the drain/intake light comes on quite frequently I have to cylcle the on/off switch twice to clear the fault. I have check the drain line several time w/o any obvious findings what's next
Feb 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
