Question about HP Officejet 7130 All-In-One InkJet Printer
HP Officejet 7130 xi all in one say Bad Print Head
This printer has never been used for about 2-3yrs
I loaded some paper and tried to print the menu settings
First I was getting error that the cartridges were bad
Bought new and replaced them
Now getting error that Cyan Print head is bad
None the less it still feeds the paper and sounds like it is
printing but the paper comes out blank.
In trying to trouble shoot the problem I removed all print heads
to inspect them.Possibly I damaged the cyan but should something
still print on the other colors when Im trying to print menu settings
  • 3 more comments
  • Anonymous Oct 18, 2008
    I have the same problem....The printer has not been used for about 2 yrs
    I loaded some paper and tried to print.
    I got an error message that the cartridges were bad
    Now getting error that Black, Magenta, Cyan and Yellow Print head are bad
    It still feeds the paper and sounds like it is
    to inspect them. Should I invest money to replace all four print heads?
  • Anonymous Dec 01, 2008
    I have the exact same problem. Didn't use it for a year or so and the cyan printhead is not working. I've tried replacing all the print cartridges and cleaning them with a que tip but it's still not working right. It will print, but without cyan. Black doesn't print right either.
  • Anonymous Dec 22, 2008
    I put in new ink black and color.  Now it prints faint splotchy black only and tells me that the cyan print head is bad and need to replace.  What and where is a print head?  Help!!
  • info68 Dec 25, 2008
    i did the same thing but it is printing 1/2 the letters. it also says replace the print head on the cyan.
    how do i replace the print head?
  • slsmith1021 Apr 03, 2009
    I have the same issue except all of my printheads are bad. I've cleaned them several times as well as preforming the "clean printheads" option on the actual printer. I just got off the phone with HP and was told my all-in-one officejet 7130 was too old and replacing the printheads would cost all most as much as getting an "upgrade" through them. Also, if I chose to replace the printheads I was guaranteed the problem would reoccur. I was given four options ranging from $179.99 to $272.99 for an upgrade. I'll have to do some research to see if I can find a better price else where. Good Luck to All!
    Problem Solver:
  • 3 Answers
Printer flashes lightes and instructs to turn off and on. When ask to print
Posted on Dec 19, 2008
Remove the cyan printhead and clean the back surface that makes electrical contact - use a qtip and rubbing alcohol this worked for me ;>)
Posted on Oct 09, 2008
SOURCE:
Error Oxc19a0035 on HP 6830
hp-printer-error-0xc19a0035-c4udjl4xbcqpooeoecbjxv3r-3-5.jpeg HP is the best brand that brings most outstanding services for its users. Among several amazing services being enhanced in HP, users also face error, due to which they are not able to access HP Printer Error 0xc19a0035 easily. One or the errors interrupting might cause major trouble; hence it is necessary to connect for help and support.
Users can contact HP Printer Customer Service to rectify any error that persists in user's printer. Hence, taking immediate help is important, dialing the technical support number for receiving support and services can make work much better and easier. Along with the improved features, properties and services it has indeed helped users in many aspects.
Fixing Error Code 0xc19a0035
• Open the lid of your HP Printer so as to reach to the cartridges.
• Clean the lower part of the chip that connects.
• Once done, print a test page to have a look at the color quality.
• If the problem still remains, try to reset your HP Printer.
• Remove the printer cartridge head.
How to Reset the Printer to Fix 0xc19a0035?
• Unplug the power cable and wait for few seconds
• Press # and 3 buttons from the front of the printer
• Turn on the printer after releasing the buttons
call us at
Printer Customer Service Number +1-866-231-0111 or email us instead of wasting your time. Use our Live Chat option to talk to our specialists about the problem.
Aug 10, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Hp7130 printing blank pages
Clean the printer head or check the cartridge, try to print a test page. Let us know the result.
Good Luck
Feb 24, 2011 | HP OfficeJet 7130 All-In-One Printer
On my HP Officejet 4215, my black cartridge doesn't print. The cartridge is nearly full.
If you haven't used the black print option, as in to print without using the color cartridges, then the black print head may be 'gummed up'.
You can try to clean the print head using the 'clean' function, which may work.
You can also try to get the print head to work by using ammonia and hot water. If the cartridge has its own print head, you can use some hot water on a paper towel and set the print head onto the soaked towel for a few minutes. After it has sat for a while, gently dab it dry with another paper towel, and try to use it. If it works, you're done. If not, you can use ammonia to try to clean the print head using the same tactics as using water. Try water first, then ammonia.
If the print head is fixed in place, you have to remove the whole assembly from the printer, and then try to clean the print head using the same method.
tom
Aug 11, 2010 | HP OfficeJet 4215 All-In-One InkJet...
I have hp 7130 deskjet and i cannot print in color initially i had bad printhead cyan and yellow error but after i cleaned print head all errors are gone but still cannot print color
Cleaning, unfortunately takes up a lot of ink. Check ink levels. If you need to, you may have to put new cartridges in every 100 or 120 pages or so depending on how colorful the documents are.
How much printing have you done with this printer?
Jul 19, 2010 | HP Officejet 7130 All-In-One InkJet...
Have a hp 6310 xi and all lights are blinking. have checked for paper jams, changed cartridges. the only way to shut it off is to unplug
Had a similar problem to this which was caused by a bad flex cable which connects the print head assemble t the main board.
May 12, 2010 | HP Officejet 6310 All-In-One InkJet...
Hp officejet v40. new cartridge but missing blue when printing
Sounds like your cyan print head is clogged. You can try to get it flowing yourself by rubbing the print head with a wet paper towel. If you press the print head on a dry paper towel you should see three distinct lines of color. If you still don't see the cyan, try letting the print head rest on the wet paper towel on a surface that ink can be cleaned up from or one you don't care about staining. If the cyan still won't flow, you should go back to where you purchased it and return it for a new one.
Jan 12, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 7130 WILL NOT PRINT BLACK
hp nokia ce0168 code:059W7P3 imei 1:357802/06/817772/2 imei 2:357802/06/817773/0
Dec 26, 2017 | HP Officejet 7130 All-In-One InkJet...
How do I change the black printhead of an HP Officejet 7130xi?
Yes, you can only replace the black printer head.
Is it saying that you have a bad print head?
If not, try to get a paper towel and fold it to be a little thick and get it humid (not too wet) and let the printer head soaking on top of the paper towel for an hour or so.
If the problem is because the printer head is dry, that usually resolvs the problem.
I had the same problem a while ago and I even did that with the color printer heads.
Good Luck,
Oct 03, 2008 | HP Officejet 7130 All-In-One InkJet...
Clean officejet print head
You can get very good results in reviving the HP Officejet 7100 Series printheads simply by placing them in a shallow plate or dish with about 1/4" of hot water (ideally distilled water). Soak the nozzle face (bottom) for at least 5 minutes before drying and testing; repeat if needed for really clogged heads.
Jan 10, 2008 | HP Officejet 7130 All-In-One InkJet...
HP Officejet 7130 All-In-One InkJet Printer Logo
1,218 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
