Question about Toshiba PDR-3300 Digital Camera
I put new batteries in my camera and it will turn on and maybe take one picture then the camera says low battery and shut off. I can open and close battery cover and it work again for a few seconds I have exactly the same problem. Brand new lithium batteries make no difference - within seconds the camera says low battery power and shuts off. I've tried cleaning the contact points in the camera but still nothing.
  • John D Anthony Apr 25, 2008
    The problem persists. It has gotten progressively worse over the three years I have had the camera - the first time I used it I could take dozens of pictures. A year ago I could take maybe 15. Now I can't even take one.
    I've bought new Energizer lithium batteries made for digital cameras and new Energizer 2500mAh rechargeable batteries - both from a local camera store - and the result is the same - I turn it on, the battery display shows low power and it shuts off.
    I don't believe the problem has anything to do with batteries.
  • 563 Answers
Hi There
The batteries are just flat. Trust us on this one and buy new batteries or recharge the one's you have ( if they ate Li- Ion )
This will do the trick !
Good luck and thanks for using Fixya.
Posted on Apr 25, 2008
  • Marnus Jacobs
    Marnus Jacobs Apr 25, 2008
    See this is all stuff you should have mentioned.
    That it has been happening eversince you got the camera and that you've tried different types ! Anyhow , there is some kind of short then that pulls the battery power dead.
    You do not want to open this camera yourself to try and investigate - rather take it to a Service Provider to do this for you.
  • Toshiba Master
  • 13,433 Answers
I beleave if the issue is not the batterys then there is a motherboard fault in the camera which is draining the batterys.
if you live in the us, you can get a free repair extimate from here
http://www.advancecamera.com/repair/
if you need anything else, let me know.
  • Ekse Apr 26, 2008
    erebus99
    Please consider my solution
    Thanks.
  • 552 Answers
Have your batteries been charged?
If they are Lithium ion batteries, they may need to be charged even if they are new.
If they are not Lithium ion bet are just lithium, then they cannot be recharged.
The following is a comment from a blogger........
You need to be careful of counterfeit batteries. These counterfeit lithium-ion battery packs and chargers on sale, and in circulation on internet auction websites, being passed off as genuine lithium-ion battery packs and chargers. They can cause an explosion which can lead to severe injury.
Because these counterfeit lithium-ion battery packs and battery chargers are often not equipped with certain protective devices meeting the industry's basic quality standards, using or recharging these counterfeit lithium-ion battery packs could cause your camera to malfunction, or lead these battery packs to overheat, leak liquids, ignite, or explode. In the worst case, this could not only damage your camera or camcorder, but also result in fire, burns and/or injuries (including loss of eyesight). Accordingly, these counterfeit lithium-ion battery packs and/or battery chargers should not be used.
Personally, I would use Ni-MH battery pack.
Posted on Apr 06, 2008
  • 3,037 Answers
I'm assuming that you have had this camera for a while right? Many cameras have experienced this same problem. Most owners just return them and get a different one. I am trying to find out if anyone or if the company has figured out what is causing this and has found the solution. Thank you.
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Apr 06, 2008
    Brand new rechargable lithium batteries usually do not come charged, try charging the battery before using it
  • Benjamin Patri
    Let me know if you need further help and please have a good day
  • Benjamin Patri
    A new TOSHIBA Digital Camera Battery comes in a discharged condition
    and must be charged before use (refer to the devices manual for
    charging instructions). Upon initial use (or after a prolonged storage
    period) the digital camcorder TOSHIBA NP-100 may require three to four
    charge/discharge cycles before achieving maximum capacity. New TOSHIBA
    NP-100 needs to be fully charged and discharged (cycled) a few times
    before it can condition to full capacity. Rechargeable batteries
    undergo self-discharging when left unused. Always store a Digital
    Camera Battery pack in a fully charged staged for storage.When charging
    the TOSHIBA NP-100 for the first time the device may indicate that
    charging is complete after just 10 or 15 minutes. This is a normal
    phenomenon with rechargeable batteries. Remove the camcorder batteries
    from the device, reinsert it and repeat the charging procedure
    It is important to condition (fully discharge and then fully charge)
    the TOSHIBA battery every two to three weeks. Failure to do so may
    significantly shorten the battery's life (this does not apply to Li-ion
    batteries, which do not require conditioning). To discharge, simply run
    the device under the battery's power until it shuts down or until you
    get a low battery warning. Then recharge the battery as instructed in
    the user's manual. If the battery will not be in use for a month or
    longer, it is recommended that TOSHIBA battery be removed from the
    device and stored in a cool, dry, clean place.
  • Benjamin Patri
    Benjamin Patri Apr 26, 2008
    you could possibly have a bad resistor or a connection that has worn down, if you want (what do you have to lose?) you can open up the camera and see if anything looks or smells burnt or out of place
    Genius:
  • 3,422 Answers
The first thing i would say is to remove the batteries off the camera and allow the camera to reset for an hour and then put them back.
If this doesn't help then You need to use 2500 or higher rechargeable batteries - as soon as you switch to this type of battery, it will work fine!
Your camera requires four AA size batteries.There are several factors that contribute to battery life:
NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges).
Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting.
Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed.
Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries.
Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Goodluck,
Please don't forget to rate the solution as fixya..
  • Priya darshan Apr 06, 2008
    Please don't forget to rate the solution no.2 as fixya if my solution has solved out your problem..
    sorry it is solution no.3
  • 4,102 Answers
Hi this is common problem if your sure that these batterys are new and you have used that make and type of battery before than the problem will be on the board of the camera itself.
If these batterys are ones you have not used in your camera before then the chances are these batterys are just not powerfull enough so you can by a recharge pack for your camera ok so let me know if its new batterys and if you have used this type before.
Also insted of using the lcd can you turn the screen of then try taking picture using normal view finder as you would on a none digital cam
It could just be that the batterys you brought are faulty and might be worth trying another set before giving up.
These camera usuall wont switch on with normal batterys so just try another set or if you have let me know.
If the battery says low bat then goes off then these batterys will not work if tryed again but if you can get camera on turn off the screen then try taking picture ok get back to me and let me know ok
  • paul proctor Apr 06, 2008
    You can buy batterys that are made for that camera that you can recharge and would last alot longer than normal batterys would so buying these will solve your problem as even lithium batterys dont really last that long in certain camera's as even the quality of the picture even uses more battery power if it set to best quality.
    But using the lcd screen to view what picture your taking really takes alot out of the batterys.
    So try taking picture with view finder with new batterys just to check the camera functions properly and allows you to view the picture taken.
    Most people who dont use rechargable batterys try and use the lcd screen as little as possible when taking pictures as some batterys wont even let you take one picture, recharge bats give you longer time but will also only give you so many pictures before they need charging so its best to use the lcd screen as little as possible this would give you alot more pictures to take as it uses alot less power with the lcd screen off.
    So its best to use the lcd screen when you only cant use the view to look through like holding camera in the air as even recharge batts wont really last that long and could go flat at annoying times so its best to either buy an extra set of these or just use the lcd as little as poss.
    Hope this is some help to you and let me know if you need further assistance ok
When i put my sd card in my camera wont turn on
The PDR-3300 works with MMC and SD cards. Your new 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the camera. You need to use SD cards, 2GB and smaller.
May 13, 2012 | Toshiba PDR-3300 Digital Camera
Lost memory card
Why can't you use a different card? Just put it in and format the new card in the camera.
Rob
Mar 11, 2009 | Toshiba PDR-3330 Digital Camera
Missing memory card
In all probability the memory card that came with your PDR-3300 was:
SD 8 MB Toshiba Memory Card.
SD cards with a much larger MB can be obtained at any large Drug Store, i.e. Walgreens, CVS, etc.
At the present time, these cards, 32 MB and larger are very inexpensive.
Feb 18, 2009 | Toshiba PDR-3300 Digital Camera
Toshiba PDR-3300 Lens cover message
Hi Judy, thanks for coming to FixYa.
Sorry no one has gotten to you sooner. Your manual mentions this and this is what it says to do:
Turn the camera on and move the lens cover switch to the open. Then your camera should operate normally. Let me know if that helps.
Rob
Feb 16, 2009 | Toshiba PDR-3330 Digital Camera
I press the shutter button a red light flashes in the viewfinder
Your focus or lighting is too low for the picture. Add more light, and hold the button down half way to self adjust to see if it goes away. Change the battery to a lithium battery, which helps the digital cameras work their best.
Let me know if this helps.
Jan 24, 2009 | Toshiba PDR-M700 Digital Camera
Toshiba PDR 3300 Menu Controller
To select you need to press the enter button which is not clearly marked anywhere on the camera or in the manual. It's the toggle button press the center of the toggle button this is the enter button and should solve your problem. It took me a while to figure it out.
Jun 27, 2008 | Toshiba PDR-3300 Digital Camera
Problem with camera writing to memory card
try this first: pull the SD card from the the slot and hold it right side up with the label facing you, there is a short slot on the side with a sliding switch. move it to the other side of the slot and that will unlock the card. (it probably go moved as your were putting the card back into your camera) good luck!
Jun 23, 2008 | Toshiba PDR-3300 Digital Camera
Batteries running out immediately
What kind are the batteries that you are using? You should be using NiMH rechargeable, made for digital cameras. Kodak make some good ones. That is what I use.
If the batteries are NiMH and the camera is still not staying on, then the batteries are not fully charged. Charge them overnight.
Regular alkaline batteries will never work more for more than one or two pictures.
Nov 05, 2007 | Toshiba PDR-3320 Digital Camera
Charging battery
Hi Pat, When charging the battery the light should definitely be red. When it turns green it's charged. I would exchange your camera for another PDR-M5 if you can. I actually had to do the same thing - noticed a big difference with the second one - including fit and finish....think that maybe Toshiba has a quality control issue. I just returned mine (second one) yesterday - was a hard decision - love the features - 3X zoom - video - speed, etc.....but got fed up with the picture quality indoors - too many out of focus - couldn't count on it. Also all pictures - in/out - tended to be dark - drab looking - always had to lighten using the software before printing. This is a $1250 camera in Canada after tax w/extra 16 meg smartmedia which you need at the minimum so there are no excuses. Hope you have better luck with yours!
Sep 15, 2005 | Toshiba PDR-M5 Digital Camera
Battery
there could be few reasons for that: 1. You are using the camera in extremely cold conditions - Put the battery in your pocket or another warm place to heat it and then load it into the cameras just before taking a picture. 2. The terminals are soiled - Wipe the battery terminals with a clean, dry cloth. 3. The battery has reached it's effective life - Load a new fully charged battery.
Sep 15, 2005 | Toshiba PDR-M3 Digital Camera
Toshiba PDR-3300 Digital Camera Logo
105 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
