Hello I in need of
Hello
I in need of the code for a LG HD 1080P TV
FOR A PANNISONIC SAPT750 Home theater system
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi bartleby
    Are you looking for a code for the remote belonging to the TV to work the Panasonic???
  • 1,512 Answers
Any luck??
Posted on Apr 10, 2008
Yes I have a sony home theaterand I'm trying to hook The insignia remote to it
Remote Control Codes for Home Audio - Page 35 ...
community.insigniaproducts.com/t5/Home.../Remote...for-Home.../35
Jun 29, 2012 - Re: NSR2000 remote codes for Comcast Universal Remote .... I havetried to program my Direct TV remote (RC64R) using the codes on ... I'm hoping you guys have the code for the sony remote so that I can just use a ... Insignia Device: NS-H2002B Insignia 200W 5.1-Ch. Home Theater ... Connect With Us:.
BDP-S3200 issue not able to control TV with remote - Sony's ...
www.community.sony.com/t5/Blu-Ray.../BDP...remote/.../357272
May 25, 2014 - Televisions & Home Theater .... how to connect blu-ray BDP-S790 and Xbox into 1 HD. .... Have you already tried the programming instructions on page 43 of the manual? .... My problem is the same as the BDP-S3200 but my tv is an INSIGNIAmade fot LG. i .... So is this a 'Guess I'm out of luck' situation?
Sony Home Theater System DAV-TZ140- Gaming console ...
https://community.sony.com/.../Home-Theater.../Sony-Home-Theater...h...
Dec 19, 2015 | Sony Audio Players & Recorders
I AM UNABLE TO CONNECT USB ON MY SAMSUNG LCD TV MODEL NO.LA40D503F7R
you need to switch the input to USB from antenna or cable probably
Sep 14, 2015 | Samsung LA40D503F7R 40 Full HD 1080P...
SLOW UNFOCUSING AND BLURY PICTURES ON MY HISENSE TV AND LG HOME THEATER
Single speed between new tv and old player may be causing latency. Double check specs on the newest component and make sure they are upward compatible.
Dec 30, 2014 | LG Audio Players & Recorders
My TV has a faulty audio input so DVDs have no sound Does the Samsung 1080P Home Theater System use its own speakers INSTEAD of the TV seakers ?
All Home Theater Systems (HTS) have/use their own speakers. If it didn't have speakers it wouldn't be an HTS . . . it would simply be a DVD player ;)
I can't give you any specific information about the Samsung HTS as you didn't supply a model number. 1080P is the output resolution, i.e 1080 lines, Progressive scan (= HD), not the model number.
Hope this helps.
Regards, BElectric
Jul 03, 2011 | Samsung Audio Players & Recorders
How to unblock region code block of sony bdv-e770w?
It's already Region Free when purchased.
  • A+B+C Multi Zone Region Code Free Blu Ray Player DVD Region 123456 PAL/NTSC
  • PAL or MULTI-SYSTEM TV is required to watch PAL DVDs. If your TV was purchased in North America (NTSC) you will also need a Video Scaler Full HD 1080p.
    May 07, 2011 | Sony BDV-E770W 3D Blu-ray Theater System...
    Need to reset its on 1080p and i have no picture so i cant see the setup screen
    run a composit cable from the unit to your tv change inputs to that and you shoud be able to see the setup
    Apr 25, 2010 | LG LHT854 Theater System
    I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
    OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
    Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
    1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
    2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
    3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
    Hope this helps!
    Scott C.
    Feb 01, 2010 | LG LHB953 Theater System
    I purchased aRCA 250W DVD Home Theater System with
    do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
    Dec 03, 2009 | Televison & Video
    Cant get my viera linked panasonic to play through surround sound
    I had the same problem, so i contacted panasonic, I am including the email they sent me.
    For connections of audio, so that you can hear all tv audio through the
    surround system, connect either an optical audio cable or red & white
    analog audio cables from the tv to the home theater. If you are using
    optical audio, there is a plug on back of tv labeled for digital audio
    output and an input on the surround sound system. If you plan on using
    analog red and white, use the PROG OUT red and white output jacks on the
    back of the tv to the AUX input on the home theater.
    For video connections, to get HD you will need to be using either HDMI or
    Component cables. HDMI is the cable that will provided 1080p signal (the
    best HD signal), but if the source does not output 1080p, then your tv
    will not display 1080p. Most cable boxes output at 1080i or 720p when on
    HD stations. This signal still provides great picture quality, but HDMI is
    not needed to get these HD signals. You can use component cables for your
    cable box and the DVD player output to the tv for video. HDMI might give
    you a slightly better picture quality but the signal will be the same.
    To make the connection, you will want to connect from the cable box to the
    tv (component or hdmi). Also from the home theater system to the tv using
    hdmi or the video cables from component (red, blue, & green cables).
    We hope this information is helpful to you.
    Thank You,
    Panasonic Consumer
    Dec 16, 2008 | Panasonic Home Theater System System
    I want to connect the Audio from tv to Surrounding audio system
    Thank You,
    Panasonic Consumer
    35 people viewed this question
     Grubhead
    Grubhead
