Question about Olympus Camedia C-765 Digital Camera
Zoom Lens doesn't Zoom
When I turn it on the lens zooms all the way out. When I try to zoom now, I see a change but the lens stays fixed in the long position. However when I turn the camera off, the lens does retract so that I can put on the lens cap
  • 247 Answers
Check you haven't accidentally got the camera into some fixed-zoom mode ("Super-Macro" is a favourite for this on Olympus cameras).
A.
Posted on Apr 06, 2008
  • 11967 Answers
SOURCE: i733 Panasonic Camera doesn't stay on. Zoom lens wont retract
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 22, 2009
jackboy
  • 2985 Answers
SOURCE: Zoom lens won't retract
The motor mechanism has failed electrically or through damage- taking a knock. Either way nothing for you to do- unless you are a watch maker or good with fine tools. A repair will cost much as a new camera. Try both -a self repair and a new camera. You may get lucky and have two cameras
Posted on Aug 28, 2007
SOURCE: Zoom lens/flashlight don't retract.
replace zoom lens strip and please do let me know where it is available I too have the same problem
Posted on Apr 16, 2008
  • 11967 Answers
SOURCE: Finepix 6900 Zoom is saying zoom error and lens
Posted on Feb 25, 2010
Ranglo
  • 1194 Answers
SOURCE: zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Posted on Mar 03, 2010
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
EF 24-70 lens droop...
The zoom creep is an easy fix for Canon. I really do not recommend trying to tighten it yourself, since that would void your warranty.
It is usually free to tighten the zoom ring.
/Chris
Dec 13, 2008 | Canon EF 24-70mm f/2.8L USM Lens
Won't zoom out
This seems to be a common issue.
Mine was stuck at what seemed like max optical zoom.
When i would look in the lens I could not see the zoom lens. If you can not see your zoom lens and the optical zoom seems stuck I bet your camera has the same STUPID issue that mine has.
It was out of warranty and I figured I had nothing to loose so I took it apart to see if I could fix it, turns out I was able to fix it just by taking it apart and putting it back together!
Taking it apart is simple enough for the average handy man, if you do not have confidence that you can take it apart then do not attempt this repair.
Take off the bottom cover.
Take off the Hard drive cover
Now remove the three screws under the hard drive that hold the drive's plastic housing in.
Remove the screw that is right under the record button, now the drive house should be loose.
Disconnect drive cable from board and remove drive and housing.
Take off the plastic piece that has the zoom button, be sure to gently disconnect the wire.
Remove rear piece.
That screw marked with an arrow on the bottom, do not remove it!
Now remove the thin metal piece to expose the flat cable.
disconnect flat cable from board
gently flex it out of the way so you can disconnect the cable behind it.
Once you have both disconnected remove the circuit board.
unplug the flat cable on the back side.
Now remove the front piece.
At this point you are nearly there!
Now remove the metal housing that holds the lens assembly.
Once removed remove the lens assembly by removing the three screws.
If you thought that was bad, this next part will scare you.
Make sure you are in a very clean room with no fans blowing.
Remove the CCD from the rear of the lens assembly by removing the two screws on the back that hold it in place.
Remove the foam and square lens piece that were behind the CCD.
On the side of the assembly is a screw that holds the top cover in, remove it and gently pry off the top cover.
looking inside you will find the following:
on the CCD side is the focus lens.
in the middle is the shutter
On the side farthest from the CCD is a zoom lens.
On mine the zoom lens was not close to the shutter
If your zoom lens is not close to the shutter then you likely have the same problem as I had and you can fix yours!
If not, you likely have some other issue :-(
To fix mine I turned it over and I loosened the screws that held the motor and shaft for the zoom lens.
Then I slid the zoom lens as far back as it would go towards the shutter.
Then tightened the zoom lens motor and shaft mount.
Put it all back together, installed battery and bingo it's working again!
Why did this fix the problem?
Well there is a little sensor that tells the camera that the zoom lens is near the shutter.
Each time you turn off the camera it always puts the lens in that "home" position.
If the camera is turned on when the zoom lens is not in this "home" position then the camera seems to assume the zoom is broken and you end up with the infamous JVC stuck zoom issue.
My guess is this problem is caused by any of the following:
1. Removing the battery while the camera is turned on
2. Dropping the camera while it is on or off
3. Battery going dead while camera is in use
Final thoughts before you get started:
1. If you are not good at working with tiny parts or electronics, I wish you luck because you will need it. Might be better off printing these instructions and taking them with you to a repair facility and paying someone more familiar with this sort of work to fix it for you.
2. The ribbon cables are removed easily. Each one has a clamp that rotates to release the ribbon. Some rotate towards the ribbon to release, others work the opposite. It is quite obvious looking at them which ones go what way.
--e100
Sep 03, 2008 | JVC Everio GZ-MG21 Camcorder
Zoom won't go in or out canon power shot sd870
zoom will not work in movei mode.
operate zoom before shooting in movei mode.
Apr 09, 2008 | Cameras
Lens stays zoomed out, no error messages
i'm sure it's broken(the camera) take it to a service and get it fixed....
Mar 26, 2008 | Canon PowerShot A460 Digital Camera
Sanyo vpc-e760 camera lens error 41
dudeee. totally have the same problem cept mine stays fully zoomed then when i try to zoom more it says lens error 41 and turns off and the lens doesnt go in
Mar 04, 2008 | Cameras
Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
Jan 20, 2008 | Fuji FinePix F470 Digital Camera
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Dropped Camera Zoom Problem
Afraid not a novice or even an expert can fix this one. It will have to be a repair of the zoom mechanism. It will almost certainly be costly. Check your Olympus support site to see what your local repair options are.
Aug 30, 2007 | Olympus Camedia C-765 Digital Camera
Olympus Camedia C-765 Digital Camera Logo
125 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
