I have a Wurlitzer Omni 3000 organ that was given to me. When I turn it on, everything lights up but not getting any sound except in piano mode. With volume turned to maximum, you can very faintly hear the piano notes. Haven't been able to locate any technician in this area. Are there any troubleshooting publications available for this organ? What would you suggest?
  • adamzrib Nov 12, 2008
    The organ lights up when turned on but has no volume. When I vacumned the living room floor, I accidently turned the bench over, it hit the big pedal and after that it had no volume. I called a technician and he said the organs were built to play out after i5 years. I do not believe this organ is made so c heaply because Wurlitzer has such a good name. Marylou Rosener I can be reached at marylourosener@charter.net Any help will be appreciated.
    New Friend:
  • 6 Answers
I found one at the dump today at first it had no sound, then i found the switch that turns the speaker on and off it on the underside of the keyboard
Posted on Mar 31, 2011
You might have disengaged the " Big Pedal" called the expression pedal either the leakage or the wiring. Have someone check that out it where I would start.
Eli
Posted on Oct 22, 2009
Hello!
I had several friends over the years who've had Wurlizer organs and they always "swear" by them. Guess they would be somewhat like Maytag products.
Anyway, I called one of them and she said she finally was able to get a partial solution from a friend of hers.
However crazy this sounds, she assures me that this procedure helped:
Look on the middle of the back of the organ, equidistant from corner to corner. There should be a knob of sorts which is kind of gold or bronze color. If the numbers haven't worn off, they should be around this knob. She said it works like this: turn the knob three times to the right, then four times to the left, and then push up. This supposedly resets the mechanism inside the organ that was loosened when your bench contacted the big pedal.
It's certainly worth a try, isn't it?
Posted on Nov 12, 2008
We just got a used Wurlitzer piano. Model 2760 serial No. 1547966, trying to find out what year it was made
Your piano was manufactured between 1976 and 1980. Source: http://www.total-piano-care.com/wurlitzer-pianos.html
Dec 29, 2016 | Wurlitzer Music
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
What is the age of my Wurlitzer piano serial number 192157?
Free Piano Age Research Look here. It looks like it was built between 1939 and 1940. Go down the page til you find Wurlitzer; after 1937: The year built is found by finding the serial number 192157, which would be between 180000 and 195000. That would make it having been built between 1939 and 1940. Hopefully, that's correct.
Jan 30, 2015 | Music
How much is my Wurlitzer upright piano serial #641 157 worth?
You generally could not get a qualified answer to such a "collectibles/antiques" question on a Q&A forum; and if you did, how reliable would it be, unless answerer had the catalog to quote to you from. Because your item is relatively scarce and becoming more so, you should seek out a catalog or perhaps a Wurlitzer owners Website where someone is more apt to have a catalog. It will also help to have more details about your piano and its current tuning and sound quality and any damage and such. A piano repair facility also might be better able to steer you to a source for valuation. This answer assumes that you have already checked for comparables on classified and auction sites.
Oct 28, 2014 | Audio Players & Recorders
Looking for the age of a wurlitzer piano with serial number 912242
WURLITZER
Apollo-De Kalb-Julius Bauer-Melville Clark-Farney
Kingston-Kurtzman-Merrium-Schaff Bros.-Underwood
1901- 480 1910-11600 1919-36000 1928-85000
1902-1430 1911-13000 1920-40000 1929-93000
1903-1910 1912-14000 1921-45000 1930-112000
1904-3000 1913-15000 1922-49000 1931-118000
1905-4500 1914-19000 1923-53000 1932-126500
1906-6000 1915-22000 1924-58000 1933-130300
1907-7500 1916-25000 1925-63000 1934-133300
1908-9000 1917-28000 1926-77000 1935-136000
1909-10300 1918-32000 1927-80000 1936-138700
After 1937:
1937-150000 1952-444000 1969-106500 1981-1645000
1938-175000 1953-474451 1970-1105000 1982-1700000
1939-180000 1955-537000 1971-1145000 1983-1725000
1940-195000 1960-657000 1972-1175000 1984-1775000
1941-210000 1961-715000 1973-1205000 1985-1825000
1942-225000 1962-760000 1974-1235000 1986-1850000
1946-330000 1963-815000 1975-1266000 1987-1900000
1947-333000 1964-860000 1976-1296000 1988-2020000
1948-340000 1965-905000 1977-1385000 1989-2055000
1949-370000 1966-945000 1978-1495000 1990-2080000
1950-400000 1967-985000 1979-1550000 1991-2115000
1951-419000 1968-1025000 1980-1595000 1992-2145000
http://www.bluebookofpianos.com/serial1.htm#WURLITZER
Dec 23, 2013 | Computers & Internet
Shure beta 57A ..low recording volume from acoustic piano ...Directly to laptop no mixer used
are you using an interface?
Your level will be always be lower if you are going straight in.
Your interface and mixer will help you get the correct level in to your system before recording and also shaping the sound after the recording.You just need to get more gain up in there
Feb 04, 2013 | Shure Beta 57A Professional Microphone
I have a Casio WK 3000 musical keyboard but no manual. When I try to layer a sound-- like putting strings with piano--the keyboard goes into drawbar organ mode and won't let me use anything else for the...
I don't know if you already fixed your problem, but I just figured out something that worked for me.
I had the same problem, and I used a System Reset to fix it. Here's how you do it:
Press Transpose/Function
Press down until you see Init
Press right until you see InitSys
Press yes twice
Wait until it's ready
Fixed! :)
Mar 28, 2011 | Computers & Internet
Highest 13 keys on top and on bottom boards do not function
Those notes are likely scanned along with all the others. The strobe selection lines for those are likely failed... this might be only two wires.
IF you have ribbon style cables in the unit, this is often caused when people pull the cables by the edges to remove from connectors.
Look for this and a connector that might have one end lifted where a couple wires aren't quite connecting. THIS IS not ANY ISSUE OF FUSES.
Jan 13, 2010 | Music
662 people viewed this question
 Grubhead
Grubhead
