Question about Logitech X-530 Computer Speakers
X-530 no power comes to speakers at all. plugged in right on multiple computers. just wont turn
  • Woozie Apr 15, 2008
    The green LED light doesn't turn on when I press the button on the right speaker to indicate it's getting power. I can hear electricity getting to the subwoofer though
  • Anonymous Apr 15, 2008
    I have problem in the speakers, I just verified to the logitech service engineers in chennai they said that the board has to be replaced .
    can any one guide the proper place to change the board in chennai.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Have you switched off your built-in speakers? Go to control panel, click on sound, turn off your built-ins if they are on, and select the configuraion of your speakers--that might do it. If not, check device manager to see if any checks are present, which will identify where the problem is.
Posted on Apr 06, 2008
6ya staff
SOURCE:
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
X-530 : Just installed it and no sound coming out. Power is on and control is lighted up. Thanks for any advice you can give me.
if you where having sound before then its the way you connected it make sure the green cable for audio is in the green slot on your sound card in the back. when you click your volume control is it up all the way and trying to register sound? or is it muted
May 17, 2011 | Logitech X-530 Computer Speakers
Speakers not working
Check the easy stuff first: make sure the volume is at a reasonable level and play sounds from multiple sources like pandora, youtube, a local mp3 etc to make sure issue is consistent.
Next make sure the one or more wires are plugged into the correct ports. Or at the very least the green wire is plugged into the green plug on the computer (unless they're USB speakers?).
You could always look at the sound settings of Windows and see (if your sound card has multiple plugs) if the plugs and assigned different functions (base speaker versus microphone/headphone etc.). Hope this helps!
Jun 03, 2010 | Logitech X-530 Computer Speakers
I am gettting sound through my headphones but not my speakers why?
Normally when you plug in the headphones, the plug turns off the speakers.
Power for the speakers come from the amp to the plug ... there is a switch that opens when you insert the plug. Makes sense in 99% of the cases if you think about it. Why do you need the spakers if you have headphones on?
May 16, 2010 | Logitech X-530 Computer Speakers
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
NO SPEAKERS SOUND
Ok, there is a plug that looks green on the back of the unit. Match the color coding on the back of the unit and on the sound card. Make suire its plugged in the right hole because you got LINE IN- MIC and SPEAKER.. if its a 7.1 sound card then you probably got CENTER- RIGHT AND LEFT and so on.. check your cabling..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 21, 2009 | Dell Inspiron 530 Desktop Computer
Old speakers will not work with new Dell Inspiron 530
Speakers are pretty much universal. Plug them in, and connect the audio cable to the green receptacle on the computer.
Apr 05, 2009 | Dell Inspiron 530s Desktop Computer...
Speakers won't turn on
Have you checked the fuse in your plug. If the fuse has blown it won't work in any wall socket. Change the fuse for a new one anyway, then try again.
Sep 21, 2008 | Logitech X-530 Computer Speakers
Logitech X-530 Computer Speakers Logo
74 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
