Question about Apple iMac G4 Desktop
I need a new inkjet printer
The printer needs to have drivers for classic nine and 10.3.9.  I would also like if I could print on CD's & DVD's.  My email is: [email protected] Thank-you Robert Mitchell
  • idocker Apr 07, 2008
    I don't care what brand as long as it is compatable with my Mac and is an inkjet of good quality.
  • idocker Apr 10, 2008
    I have taken the time to read the comments made from people who have purchased the R800. There were alot who were very disapointed in the amount of ink it used, it became quite costly. Maybe you can suggest something other than the R800 to look at. Also a little less money if you can.
    Thank-you,
    Robert Mitchell
  • 3,037 Answers
What kind of printer is it?
Posted on Apr 07, 2008
SOURCE:
I keep getting the message"the
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Mar 11, 2011 | Epson RX595 Photo All-In-One Printer
The printer gives an error message saying 'No CD/DVD detected. Please put in a CD/DVD and try again' I am doing the same thing I always did. Putting a normal blank CD for printing and somehow it is not...
First, be sure you did not insert the CD upside down and it's properly fitted not the drive. Also, you may need to swap out the CD to be sure it's not damaged.
Dec 13, 2017 | EZ Dupe Magic DVD/CD Thermal & Cartridges...
Trying to print CD label and error message "CD/DVD guide open" will not print CD . . . but it will print on paper.
to cure fault on r300
press and hold 3 buttons
stop, power &
Maintenance (the one with red light over)
for 10 seconds
a message will come on screen
counter is reset and turn off
turn back on
if this dose not help your problem try to download the latest firmware and drivers from below link.
Click Here to download the firmware and drivers.
Please let me know if you have any further questions or concerns.
Thanks.
May 02, 2010 | Epson Stylus Photo R300 InkJet Printer
Printing Direct to CD using Roxio EMC10 and HP All in One C5280
Solved by trial and error.
I went through every type of paper and printer combination listed in the Printer Preferences and eventually found a system compatible with Roxio EMC 10.
This by setting "Commercial Paper" and Neato 3-Disc Paper.
Whilst this is probably the incorrect way to do it, it has solved the problem and I can now print directly onto CD via my HP C5280 All in One Printer.
Tip. If you set Print preview before printing you can determine what the finished article will look like without having to wast numerous Discs trying.
Aug 28, 2009 | Roxio Easy CD & DVD Creator 6...
The epson printer driver dealing with cd printing is not installed
is there an ok button on that error message? if so just click on OK button and click on a button says manual.
It will let you check on the settings on the printer. paper size should be A4.
on print settings it should let you select on cd/dvd
Note: this only works if you have installed the epson easy print from the epson.com website of your printer model
Feb 07, 2009 | Epson Stylus Photo R200 InkJet Printer
Mac OS 10.5 Leopard
As per someone elses post here:
* Source: Manual
* Size: A4
# Click Properties.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Mac OS 10.5 Leopard
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After you click ok on the message, you will get another window where you will find a "manual print" button. Click on this manual print button and this will take you to the next window where you have to select "A4 as the paper size" and "CD/DVD as the paper type and paper path" . After this, click print... it should start to print! This is just a workaround until epson gets a patch for leopard for print cd........hopefully
Nov 09, 2007 | Epson Stylus Photo R1800 InkJet Printer
Unable to print on DVD/CD
The latest R800 driver for Windows
epson12379.exe
(which is probably required for Vista as well as XP) has a hardware interface problem.
When you try to print on a CD, the power button should blink slowly and the paper feed button should turn red until the media (CD) is readied by holding the paper feed button down for a second. However, with the driver above, the paper feed button instead blinks very fast (the printer is being "probed" by the PC in a tight loop I would guess) and so the CD cannot be readied.
The previous version of the driver,
epson11222.exe
does not have this problem. But I doubt it will work under Vista.
If you would like this driver e-mailed to you, send me an e-mail to my "junkmail" account asking for it (include this documentation so I know what you want) and I will send it.
My junkmail account is jim3 underline porter6 at fastmail dot fm
(underline, at and dot are not words but single characters)
Sep 04, 2007 | Epson Stylus Photo R800 InkJet Printer
Open Questions:
See all Apple iMac G4 Desktop Questions
Apple iMac G4 Desktop Logo
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
