Question about Samsung RS2630SH Side by Side Refrigerator
Samsung rs2630hs i purchased a refigerator for 2.5 years, but the partition that divide freezer and refigerator is real hot, ot to the ponit that you can't not touch, any body have any idea how to fix it thank you
  • ktb9780 Apr 19, 2008
    Bouht my side by side in Jan 2005 an now havin xact sam poblem. Th stp betwn h oor sis so hot it will litrally bur you. Also my ice maker hs ottn o slow i is bay tunin out 20 cudes a day anymore???????
Ice maker is not making ice.
Posted on Feb 06, 2009
Well, it sounds like your condenser fan motor has seized up and needs to be replaced. I had the same problem and additionally it woudl onhly produce about twenty cubes of ice a day. Best Buy repair guy came replaced the fan motor and within 10 minutes the heat was dissapated from the strip and it started churning out ice agin.
Posted on Apr 22, 2008
SOURCE:
How to replace the fan in a rf610a
Which fan? Fridge fan or freezer fan?
Fridge fan
1. Disconnect the refrigerator from the power supply.
2. Remove all PC shelving.
3. Remove the duct grill in the PC.
4. Remove the PC duct cover and polystyrene insulation.
5. Using 2 fingers, withdraw the fan motor upwards. It is mounted horizontally in the divider partition.
6. With the motor out, this will expose a small multi plug and socket connection to the fan motor and wiring
harness. Unplug.
7. To refit back together, fit the wiring harness multi plug first into the pocket of the divider partition.
8. Using your 2 fingers, slip the motor back into the divider partition to fit horizontally.
NOTE: The back of the fan motor faces upwards.
9. Refit the duct covers and test.
To test the fan(s),
Testing a PC or FC fan motor with a multi meter is not possible, due to the electronics contained within the motor. The simple way to test a fan motor is to apply a DC voltage with a 9-volt battery.
May 07, 2016 | Fisher and Paykel Refrigerators
HOT SPOT IN FRONT DIVIDER BETWEEN FRIDGE AND FREEZER
Greg,
That is usually a heating element that is used to prevent condensation from developing in that area. It should cycle on and off and be slightly warm, but not get real hot. Check around your controls and see if there is a switch for something like Energy control or something like that, the exact term is escaping my memory, and you might be able to turn it off. Hope this helps!
Jul 12, 2015 | Admiral Refrigerators
I have a 15 year old side by side ge profile refigerator. The floor of the freezer constanly freezes order and leak under the freezer side, What is the cause?
LOOK IN SIDE THE FRZ ON BUTTEM BACK WAY LOW BACK THER A DRAIND AND IS PLUG UP OR FROZER NEED TO UN PLUG TRY TO USE HOT WAER AR A HOT STEMER TO UNPLUG DRAIN.
Feb 21, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
The center strip that divides the fridge and the freezer is hot to the touch -- so hot it will burn my hand. How can I fix, and is there any fire danger?
Sir,
Sounds like there is a problem in the sealed system. Remove the rear lower cover and tell me if the condenser fan is turning. While there, is the Compressor hot to the touch?
Pull the unit away from the wall and then remove the rear bottom cover. Is the condenser fan running? If it's real dirty there, unplug the unit and clean real well. In the freezer section...look on the rear wall and tell me if you see any frost building up.
Thanks Good Luck
Aug 14, 2009 | Jenn-Air Refrigerators
I recently purchased lenevo ideapad laptop. in that total hdd space is divided into 2 drives .if i want 2 divide into more drives ,wht can i have 2 do? i have vista os.
you can create additional drive partitions by right clicking on my computer, select manage, and open the computer management snapin console, once there you should go storage-disk management, select the drive you wish to partition from there
Mar 24, 2009 | Microsoft Windows Vista Ultimate Edition
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Aug 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
252 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
