Question about Refrigerators
THE FREEZER IS OK BUT THE TOP PART IS NOT COLD
Have you got a fan inside the freezer and is it working?
Russ
Posted on Apr 06, 2008
2 Suggested Answers
  • 1218 Answers
SOURCE: not cold in the fridge part top freezer seem ok.
Good day,
One of 2 problems.
1. The fan motor in the freezer compartment is not running. While the machine is running, open the freezer door. You should hear the fan motor running.
If not, then remove the rear panel in the freezer section, and inspect and replace the motor if needed.
2. The defrost system failed.
When opening the freezer door, look at the rear panel. If you see the beginning of a frost build up on the panel, the defrost system has failed.
The defrost system is made up of 3 parts. The main heater, which is located behind the rear panel in the freezer panel.
The defrost thermostat which is a small round device clipped to the top of the evaporator coil, and once again, is located behind the rear freezer panel.
The timer, which is located in the fresh food compartment on the top underneath and behind control panel.
You will need an ohm meter to test the main heater for continuity, and the defrost thermostat as well.
The timer can be checked by using a small screw driver and turning the advance shaft clockwise until the machine shuts off.
Wait 35 minutes. If the machine turns itself back on, the timer is good. If not, it is bad, and needs replaced.
Here is an excellent tutorial to explain the system.
http://www.appliance411.com/faq/howdefrostworks.shtml
Posted on Dec 07, 2009
Testimonial: "looks to be the defrost system failed,noticed frost on the panel.what do you recomend,check the timer 1st then the main heater and the thermostst"
Freezer not cold but refrigerator still cool
HI JULIE.TRY DEFROSTING ALL FIRST 24/48 HOURS.(USE ALTERNATIVES FOR FASTER DEFROSTING.ie;hair dryer;steamer;boiling water bowls etc.)if ok after that great.if same again then 1-defrost timer 2-defrost heater 3- t/stat.good luckALI
Jun 30, 2012 | Maytag MBB1954G Bottom Freezer...
I just got a G E refrigerator from home depot model # gbscohcxarww. And the freeZer on the bottom works but the ref rig on top doesn't get cold
set dials to middle setting, max cold makes cold freezer, not reefer box!! if freezer makes ice its ok just set to cold which starves reefer box of air. add 2-3 gallons of water to the freezer and or reefer box, if empty it wont cool much.
Nov 01, 2010 | GE Refrigerators
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
The refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
May 21, 2009 | Frigidaire FRS3R5EMB Side by Side...
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
May 13, 2009 | Refrigerators
Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Apr 28, 2009 | Frigidaire FRT17G4B Top Freezer...
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Warm frigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jun 14, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
