Rca sound system hooked up to the tv the dvd pictures is black and white
  • bridgelals Apr 09, 2008
    thank you for your assistance it was very helpful.
  • 53 Answers
I see three possible problemos:
1: You are using a composite connection and your tv is downright crappy at displaying a composite feed--I know mine is. Try upgrading to component if your tv supports it. If not use a s-video connection.
2: You are using an s-video connection and there is some connection problem, either in the DVD player, the cable connectors, the cable itself, or the s-video input on your tv. Upgrade to component if your tv supports it, otherwise try the cable and DVD player out on another tv to see if the tv is the problem, or use the cable on a different DVD player to see if the cable is the problem.
3: You are using component input only two of the cables are loose OR you are only using the green-colored cable. Either plug in all three component cables (red, green, blue) or try pressing the cables in while watching to see if that fixes it. You may need a better cable, some of them are crappy at staying in.
Posted on Apr 06, 2008
SOURCE:
Connecting dvd player to a television need a diagram t.u
If you are going to hook up the DVD player to your TV through RCA cords, see the picture below.
Hook up the yellow RCA cord at the Video-in at the back of the TV and the other end at the Video out of the DVD player to get the video.
Hook up the red RCA cord at the Audio-in(right channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Hook up the white/black RCA cord at the Audio-in(left channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Red and white/black RCA cord is for the sound.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 07, 2011 | Televison & Video
All speakers are working good. I even have sound from the DVD, but no picture. It is playing. Also no sound anytime from my Television.
check rca hook-up remember that is ur audio and picture yellow to yellow,red to red , and white to white.
May 02, 2011 | RCA RTD207 System
I am trying to hook up the mvd2016 to a visio tv that is hooked to our cable converter box. I hooked it up, i have the tv but no sound.
your RCA jacks from the DVD player....should be connected to the Vizio a/v 1 in the back of TV (yellow to yellow, red & white to red & white)... now to view using the remote to TV switch to a/v (play a DVD, you should now have a picture and sound)
Dec 19, 2010 | Vizio Televison & Video
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Jul 23, 2010 | RCA F19431 19" TV
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
RCA dvd player, drc200n
DVD optics should be cleaned
Dec 27, 2007 | Televison & Video
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
Problem with RCA P42WED33 picture
If you have the tv on cinerama mode, it is black. If you use the scroll on picture mode it works
Jul 13, 2007 | RCA P42WHD33 42 in. Plasma HDTV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Ekse
