Question about Acer Aspire L100 PC Desktop
Keyboard / Mouse Not Working
I ran a HD Defrag and went to bed while it was running. Apparently comp shut itself off. Next morning, booted up comp only to notice that it wasn't seeing Keybord / Mouse. Tried 3 different Keyboards / Mice.
It will boot up but I have no way of entering user password to complete boot up. Any suggestions? For time being, I had to rent a computer until this one is fixed or new one purchased (pending tax refund)
  • armywifeb Apr 06, 2008
    Mike:
    Thank You. However, there are no PS2 connections on this particular computer. This computer only has USB connections.
    Thanks
    armywifeb
    President:
  • 2,351 Answers
Hi armywifeb, for a small fee you can go to Wallmart or BestBuy & buy a PS2 to USB cable for your PC This cable is a Y connector which allows you to plug both, you're PS2 mouse & PS2 keyboard into one end of the Y cable, than plug it into a free USB port. This should help you get through tax season. The link below will give you an idea of what your looking for.
(This is the part).
http://www.cablestogo.com/product.asp?cat%5fid=104&sku=27225
After tax season is over, please back up all your personal data to either a CD/DVDRW or a slave drive. You will need to format the drive & re-install windows before thinking of buying a new board.
I also suggest, not using windows to format the drive but the drive's Mfg's software tools to format, test & setup of the hard drive. (Better testing & better tools). Just find the name of the drive (Listed on a white sticker) & go to the web site of the Mfg. Download either software for a bootable floppy disk or the software tools for a bootable CD.
Good Luck & Kind Regards.
If I can be of more service, just ask.
Mike
Posted on Apr 06, 2008
SOURCE:
Hp mini 110-3600sa keyboard stop working
motherboard or keyboard problem , go to your manufacturer's support,
Dec 04, 2012 | Computers & Internet
My Model #PSAA8U-OLK02K had some water damage. After letting it sit for 24 + hours, it booted right up. After shutting it down for the night, I tried to boot up the next morning and it got to the Win
could be moisture can affect a laptop in stages keyboard then motherboard might want open it and tent it(edges on table) and then lightly run a warm hair dryer over ports, keyboard etc you might get lucky
May 17, 2012 | Toshiba Satellite A105-S4094 Notebook
I was using the computer for a short time, just reading news on the internet when it beeped three times and the monitor went blank and the mouse and keyboard also stopped working. I had to do a hard...
hi your cpu fan might be loose or your RAM open pc and make sure cpu fan is secure if its loose a little tighen it or your RAM might have popped out it can get very hot around RAM and sometimes it pops out ...hope this helps be carefull...bonnell
Sep 23, 2010 | Gateway FX7026 PC Desktop
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking. shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8. advance boot up options will appear. select safe mode with networking
try restoring your comp to a previous time when it was working. if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
Good Luck!!
May 19, 2009 | Dell Computers & Internet
After installing hard drive, monitor, keyboard, mouse not working
Have you tried to enter BIOS? Are you able to enter BIOS?? There may be an option you have to hit to enable SATA, and to select the boot device order, which may be messing things up.
Also, remember that STATIC ELECTRICITY is your enemy! Ground yourself when working inside the case.
Dec 30, 2008 | E-Machines eMachines Desktop PC
Left click not working
This problem of yours has a simple solution:just change the left push to on switch.desolder the original one, get a switch from the local electronic market of the same type(if possible OR another one which will b placed correctly on d pcb and which ensures that d click works)
The problem is that the spring in d switch has lost it's physical properties,which is a aging problem.
Solder the new switch,and there u go,click click click,all working fine.
Jun 08, 2008 | Dell 2 Button Mouse 6u226
Mach speed
Unplug the the dsl & any other device except the keyboard & mouse. Double check the video cable at both ends monitor & PC. Boot up system. If the system starts shut down & connect 1 device. Boot the system. OK? continue to do this. On the dsl there is a reset button. With it unpluged from power use a pen & hold in the reset for about ten seconds. Reconnect the power & reconnect the Rj45 to the PC. Boot system.
Jan 26, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
Acer Aspire L100 PC Desktop Logo
89 people viewed this question
Ekse
Alun Cox
