Question about D-Link AirPlus DI-524 Wireless Router
DI-524 Intermittent Loss of Wireless Capability after Power Outage
On Thursday, March 3, there was a power outage, and ever since, our router has been failing every few hours. However, it only seems to affect the wireless capability of the router, as our computer physically connected to the router retains network and internet access. Whenever this happens, I must reboot the router to return the wireless network to normal.
This is not the first time this has happened (we have had a few power outages in the last year, and each time the router was similarly afflicted). Each other time, though, within a few days the router was back to full functionality. I am worried that this is not the case this time.
    Novelist:
  • 125 Answers
Try upgrading the firmware through the Routers Web Interface , and see if this will fix the problem otherwise the only other way around it is to do what you are currently doing and unplug and plug it back in, perhaps the AP was damaged as a result of a power surge , if the problem persists best bet is to buy a new one.
Posted on Apr 15, 2008
There was a power outage 2 days ago. When the power came back on, the wireless portion of my DI-514 did not work. There was no internet connection to any of the pcs. How do I get it to work?
Try turning off the PC, the router, and the modem. Then restart them in this order waiting about 1 minute between each:
1) modem
2) router
3) PC
Good luck. Bry
Jan 01, 2011 | D-Link DI 514 Wireless Router (DI-514)
After a power outage, I have no wireless connectability.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 13, 2010 | D-Link AirPlus DI-524 Wireless Router
D-link514 wont turn on after storm power outage
The cause is the power-supply "brick" to the DI-514.
It has failed.
So, it's time to buy a "surge-suppressor" (sometimes integrated into a high-end power-bar) and to buy a new router, for less than $80, in total, to be protected and be ready for the "next" storm.
Jul 03, 2010 | D-Link DI 514 Wireless Router (DI-514)
WE HADA A POWER OUTAGE AND NOW THE WIRELESS IS NOT WORKING AND THE LIGHT ON ROUNTER DOES NOT COME ON
Is the router plugged into the same power source (surge protector or power strip) as your computer? Try plugging it into a different outlet -- one that you know works -- and if the router doesn't turn on there then either your router is fried or the AC adapter that powers it is fried.
May 30, 2010 | D-Link DI-634M Wireless Router (DI634M)
The STATUS led on my D-Link DI 524 wireless router
reset you router on factory set and then you can see the satus of lights.
Apr 04, 2010 | D-Link DI 514 Wireless Router (DI-514)
Dlink router is not connecting to the internet
Check the lights on the router to make sure both out going and incoming are on.
Manual link below in case that helps
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
If not both on contact broadband supplier as IP for router may have been "altered" and will need resetting their end.
Not unknown for an outage to be proceeded by a "spike" which can blow unprotected items.
Jan 24, 2010 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
After power outage, router will not connect. Cable modem connected directly to PC works, but why not the router? Is it a setting?
Yes.
It is possible that the router actually got reset in the process.
Dlink setup is 192.168.1.100 I believe. It should say in the manual. If you do go through the setup wizard and it still won't connect, then the power outage may have affected either the firmware or the hardware.
Aug 08, 2009 | D-Link AirPlus DI-524 Wireless Router
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless router not working
may be u had a power outage>try to reboot it like unhook the power and wait 1 min and reconnect the power if its not working may be u need to do factory settings better u need to contact 24/7 which is 1-888-814-2882
dialy 5am to 10pm PST
Nov 19, 2007 | D-Link AirPlus DI-524 Wireless Router
D Link DI 524 Wireless Router
It is possible. If, due to the power outage, you lost your router config, you are going to have to configure it again.
Aug 21, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
229 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
