Question about Garmin Rino 120 2-Way Radio
Transfer data to PC port
I wolud like to transfer data from my rhino 120 to my pc. The serial port connection from the rhino to my pc does match any configuration on my pc. What is it that I am missing?
  • Garmin Master
  • 638 Answers
You are going to have to get a USB-serial adapter. Most electronics shops carry these.
Posted on Apr 25, 2008
I'm trying to figure out how to connect my Datamax Prodigy Plus Thermal printer to my PC. I have a 25 pin connector on the Printer labeled J2. Also a round plug-in labeled J4. My computer has the same...
If the cable works on the Zebra it should work on the Datamax. It must be a RS232 serial null modem cable.Check the serial port settings and make sure the printer setting match the PC serial port settings. Baud Rate=________? Data Bits=________? Parity=_______?Stop Bits=________? Handshaking=____________?
The typical settings are Baud 9600,8,n,1 Xon/Xoff.
Also make sure of the comm port being used. com1,com2......etc
Jun 09, 2011 | Datamax Prodigy Plus Thermal Printer
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
I have a sony pc 100 dv cam. I am trying to find the right cable to connect it to my mac. I need what ever sony uses one one end and usb on the other.
your camcorder doesnt support usb connection.although it came with a pc serial cable,its the cable used for memory stick picture transfer, along with it comes a serial port adaptor for the memory stick and ac adaptor for serial adaptor. of course even if you lost this accessories you can still transfer pics from the ms using a memory card reader which works basically the same way. for videos on the tape you would just need a firewire or an ilink (ieee1394) cable. almost all mac computers support this connection.it's the dv in/out jack on the camcorder with an i symbol.upper most jack on the camcorder jack's location.check your mac to find out what cable you need.the unit uses a 4pin ilink port so you need a 4pin ilink cable at one end and the other end should match of course, the firewire port on your mac computer.should be a plug and play connection.you can use imovie software for video capturing.hope this helps.thanks :)
Mar 11, 2010 | Sony Handycam DCR-PC100 Mini DV Digital...
How can i connect my samsung rant to my pc
Samsung does not offer a Data Kit software package, for the purpose of transferring data between the handset and a personal computer or for using a Sprint handset as a modem for a personal computer. However, depending on the model, there may be a media card slot located on the side of handset or in the battery compartment that allows information to be transferred to a personal computer with the use of a media card reader.
USB (Universal Serial Bus) is a type of plug-in connection that is used to connect devices, including some handsets, to desktop or laptop PC's. In a handset, USB is useful for quickly transferring files to and from phones, or for synchronizing information with a PC application. The only USB setting needed for data transfer is the Mass Storage Connect to PC setting.
To access the USB setting follow the steps below:
  1. From the standby screen, press the Menu/OK key
  2. Select Tools (0)
  3. Select Mass Storage (6)
  4. Select Connect to PC (1)
  5. Connect the data cable to the PC's USB port and the handset Charger/Accessories jack
Note: No USB driver is needed for Windows 98 or XP. Other operating systems may require a USB driver that can be downloaded from http://www.samsungwireless.com/ usbdownload
Jun 28, 2009 | Samsung Rant Cell Phone
I can't print label from ZM400 PRINTER thru' serial port
There are a number of parameters for the serial port that have to match the pc. i would print out a config page from the printer via the menu, or power on with the cancel key held. then compare it with the settings on the pc. on the config page you should be looking for things like data bits, host control, parity etc.
Jan 19, 2009 | Zebra 170XiIIIPlus Thermal Label Printer
I've bought lg kp110 mobile one week back. only data cable is given inside. i want a sofaware to connect to my pa and download into my mobiles. if any body has drivers ps suit for lg kp110 send it my gmail
u can use the mobile as mass storage mode without pc suit............just connect them and in mobile screen select mass storage then
after in pc tray the device installed and ready to use will appear then u can access them
Jan 07, 2009 | LG CU500 Cellular Phone
I net connect two PC using comm port and transfer data b/w them
communication ports are very difficulkt to connect, so i suggest you lay your complain to google website and search for the details of installing it
Dec 07, 2008 | Computers & Internet
Transfer data
Hello tompkin,
Programming the Garmin Rhino 120 using a PC requires an interface kit and may also require a RS-232 to USB converter cable or a 9-pin to 25-pin serial adapter depending on what interface is available on your computer.
The interface kit and cables are available on the manufacturer’s homepage for the product: www.garmin.com/products/rino120. Click on the “Accessories” tab and scroll down.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 06, 2008 | Garmin Rino 120 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
229 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
