Question about Kenmore Washing Machines
How to remove the back panel to get to the inlet valve?
Here you go - this link worked for me on our kenmore. Go to number 9,the slide show for back panel removal. Worked liked like a charm!
http://www.applianceaid.com/procedures.html
Posted on Dec 19, 2008
What does F20 on the washer mean?
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
I have a kenmore elite and the code f20 error keeps coming on and it will not get warm
Nov 04, 2012 | Washing Machines
The water trickles out very slow when it is filling the machine. I have a Fisher and Paykel GW712 washing machine.
The two things you need to look at is the screens on the inlet of the washer, thes can get plugged with sediment and block water flow, take the hoses off the machine and look for the screens, either in the hose or water inlet connection. Second is the inlet valve, AI will include a couple of pictures of this. If you have an ohm meter all you have to do is check for continuity across the valve, if there is none the valve is bad and needs replaced.
The control panel lifts off by removing two phillips screws on the back of the control panel. The panel then flips over. The picture below shows what it looks like with the control panel removeddcramer531_29.jpg The inlet valve is on the left.
Not shown above are Power Control and Pressure Sensing Module, which plugs into the water inlet valve nipple, and the tech sheet, which you'll find folded up to the left of the water inlet valve. The tech sheet gives detailed instructions for entering diagnostic mode and interpreting the binary diagnostic code generated by the LED display on the control panel touch pad. anew inlet will look like this.dcramer531_30.jpg or very similar, depending on the model.
Dec 16, 2010 | Fisher Paykel EcoSmart GWL15
Im trying to replace the fill valve on a Kenmore washer model # 110.28812790 serial # CG4186264. I am having trouble getting the back off to get to the valve. Do you know how to do this? Thanks
I just replaced the fill valve on my front load Kenmore Elite HE4T it is actually a very easy fix.
1. Turn off the hot/cold water supply to the washer. 2. Remove the top cover of the washer by removing the three screws located at the top of the back panel. 3. Lift up the rear of the top cover about 1" and pull toward the rear of the washer. The top cover should pop off. 4. Remove the water supply hoses if they are not marked "H" and "C" mark them so that when you reconnect they are not reversed. 5. On the back - left side of the inlet valve is a spring clamp holding the black water supply hose to the inlet valve. Using a pair of pliers loosen and slide the clamp an inch away from the hose end. 6. Using your fingers and a flat tip screwdriver pry the inlet hose off of the inlet valve. 7. Place the new valve near the defective valve and remove the wires attached to the "H" and "C" inlet relays (they are two square blocks with two wire terminals on each). As you remove each wire attach it to the corresponding terminal on the replacement valve. I found it was best to pry off the plastic connectors with a screwdriver from the top while pulling them off. 8. There is one screw holding the valve to the back panel of the washer, remove it and remove the defective valve. 9. Attach the water black water supply hose to the new valve and slide the spring clamp back over the nipple of the inlet valve making sure it is near the end of the hose, but not over the edge. 10. Install the new valve by lining up the single screw hole and reinstalling the screw. 11. Reconnect the "H" and "C" supply hose paying attention that the "H" is connected to the inside and the "C" is connected to the outside inlet. 12. Turn on the water supply and run the washer through a fill cycle checking for leaks at the supply hose connections and the black hose at the outlet of the fill valve. 13. If everything is still dry reinstall the top cover by putting it in place and sliding it forward. Replace the three screws that hold the top panel.
The entire repair should take you less than 30 minutes. If you have enough room between the back of the washer and the wall you really don't even need to move the washer.
Jul 04, 2010 | Washing Machines
I have a kenmore washing machine and the wash temp. does not work on cold or warm anymore, just hot even when it is on the warm setting.
The problem is the cold water solenoid on the water inlet valve. Replace your valve and the problem will go away. This is a very simple and inexpensive repair.
To replace the water inlet valve, follow these steps:
1. UNPLUG the washer.
2. Turn off the water source and disconnect the fill hoses from the back of the washer.
3. Remove the toppanel of the washer by locating and removing the screws that hold the panel in place in the rear. With the screws removed, the panel will slide back, then lift off.
4. With the top panel removed, disconnect the dispenser hose(s) and electrical connections to the inlet valve.
5. Remove any mounting screws holding the valve in place and reinstall with a replacement valve.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare. The first three sites on the list also include helpful exploded view diagrams of your washer to help with locating parts and assembly.
NOTE: Before you begin, check the sediment screens on the water inlet valve by turning off the water and disconnecting the fill hoses from the back of the washer. There are small screens in the hoses (sometimes) and the inlet valve. If you live in an area that has hard water, or uses well water, sediment, rust and scale and clog these screens. Sometimes a good cleaning with some distilled vinegar helps.
If you have any questions, please let me know. I hope this helps you.
Feb 14, 2010 | Kenmore HE2 Plus Front Load Washer
The electronic cold water inlet valves at the top of the machine are leaking. My manual does not list the part and i need to replace it. I dont know the correct part name or number
Water Inlet Valve Replacement Procedure
Cold water inlet valve assembly: Part # 5221ER1003A
Hot water inlet valve: Part # 5220FR2006H
  1. Safety first. Unplug the machine.
  2. Close the water supply valve.
  3. Remove the cold water fill hose and drain the residual water into a pan or bucket.
  4. Remove the two screws on the back of the top panel securing it to the cabinet.
  5. Slide the top panel to the back of the machine and lift it off the cabinet.
  6. Disconnect the wiring harness connectors from the valves. Mark the connectors to make sure you reconnect them to the right valve.
  7. Unscrew the valve assembly from the cabinet and pull it out.
  8. Loosen the hose clamps and remove the hoses from valve assembly.
  9. Connect the hoses to the new valve assembly. Reinstall the valve assembly and the top panel in reverse of the steps above.
  10. Reconnect the fill hose and open the water supply valve.
Jan 26, 2010 | LG WM-2277HW Front Load Washer
HOW DO YOU REMOVE AND REPLACE WATER INLET VALVE ON FRIGIDAIRE LTF2140FS1
remove the screws holding the top panel on, they are located on the back at the top. Standing at the front of the washer, push top panel towards rear, then lift up and remove. Notice the water inlet valves on the rear left while facing the washer front. Unplug washer, then remove the mounting screws holding valve assy onto machine, on some fridg's there are 2 screws holding an inlet valve assy onto the dispenser underneath the valve assy, they are very hard to get to. Remove valve assy from washer and replace. Remember to mark wiring locations as needed.
Jul 01, 2009 | Frigidaire ATF6000ES Front Load Washer
I have the valve for the water now how do i change it
If you are talking about replacing the water inlet valve, follow these steps:
1. UNPLUG washer and turn off water supply.
2. Disconnect water inlet hoses from the back of the washer.
3. Remove the washer top panel by removing the three screws in the back of the washer. With the screws removed, the panel will slide back, then lift off.
4. The inlet valve will be located in the left-rear of the washer (as viewed from the front). Remove the dispenser hose and electrical connections from the water inlet valve, followed by the mounting screw(s). The valve should easily come out of the washer. NOTE: Accessing the valve from the rear or left side of the washer access easier.
5. Install new valve in the reverse order of the steps I provided. Make sure you get the dispenser hose connected correctly so it does not leak AND make sure the electrical connections are not crossed (they should be marked HOT or COLD - if not, label them BEFORE removing.)
6. Connect water supply lines making sure they are not crossed. If you have the original manufacturer's hoses, they will be marked RED for hot and BLUE for COLD. It's also printed on the back of the washer.
Read through the instructions and let me know if you have any questions. I hope this answers your question.
Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Replacing water inlet valve
First of all, UNPLUG the washer before attempting any repairs, and follow these steps:
1. You will need to remove the washer top panel by loosening the three screws in the back. With the screws removed, the panel slides back, then off.
2. Turn off the water supply valves and disconnect the water inlet hoses.
3. The inlet valve should be very simple to replace at this point. Disconnect the electrical connections and the hose(s) leading from the valve to the dispenser.
4. There should be a a mounting screw holding the inlet valve to the back panel. Remove the old inlet valve and install the new valve in the reverse order of the steps I just provided.
This is should be a fairly straight forward repair that anyone can accomplish without the assistance of a repairman. If you get confused along the way, please post back and let me know. i hope this answers your questions.
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
106 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
