You can add a Hand held Scannerbar with your Casio Tk -7000 Hand held bar code scanner(HHS-15) *
Essential functions for the scanning environment such as Not Found PLU(NFP),PLU batch maintenance file,bottle link and Mix & Match functions are available on the TK-7000 model.
You can attach a Voyager Scanner with your TK-7000 model.
How to add in Casio Cash Register: 1. connection to cash register - unscrew and screw back in. 2. connection to scanner, unplug using paper clip into hole and push back in again. 3. rescan default sheet given whe nyou purchased the machine. 4. clean head of scanner. 5. check for cracks on scanner, ie. loss of vacuum.
If you don't know about calculator electroncs, you don't have own means to repair it so take it to a repair technician, ask a diagnosis and evaluate if it's worth to repair your calculatoe or dispose of it.
The drum is supported by springs. Maybe one of them broke. You might have to open it up to visually inspect it. You can find videos on YouTube on how to do it. Good luck!
The water pump system is not primed properly. Remove the water tank while the pump is running and put back a couple of times. If not working, when the power is off, using a straw, blow air through and try to **** through the water port at the bottom of Keurig. Plug the water tank again in and start the system. It will take some time to prime, keep trying. There is nothing wrong with the machine, but the water pump circuit.
Hi, The red symbol means lubricant/oil is less than normal level. Better check the level of your oil and add some until it reaches the maximum level. Next time you put on some petrol/gasoline, ask the station attendant to check your oil level and ask him to add some oil. Hope that helps!
I have a similar printer. Sometimes the bottom paper tray gets stuck or caught. Make sure the printer is on a flat surface.
1. Turn off the printer. 2. Pull the paper tray all the way out. 3. Take out all the paper and then place the tray back in. 4. Turn the machine on and let it try to print without paper. 5. When the light comes on add paper hit the button and you should be good to go.
Toner add system is clogged. These machines take toner from the bottle and dumps it into a chamber. This chamber has a level sensor that tells the machine to rotate the bottle in oder to add toner. This is why you can see a spiral "flute" going around the toner bottle. Toner is added to the Imaging Unit from the toner chamber when needed by an auger running from the chamber thru 2 90 degree turns. If the machine runs trying to add toner you normally can hear the small motor and auger spinning. It makes sort of like a reer reer noise. When the bottle rotates it will make a thump thump noise. I know this all sounds funny but this is what is happening when the machine is adding toner. Now if you are hearing the reer reer noise at least that means it is trying to add toner. Don't put a lot of emphasis on it, just letting you know what is suppose to happen. If you hear both noises together and the machine runs for a few minutes before shutting down then it is not getting toner out of the bottle.
The long and short of it is that if you have the correct toner in the machine, and the seal was removed properly from the bottle then it should get toner unless there is a clog somewhere.
