Question about Dryers
Kenmore drier model 110.96591440 will not cut off in either drying cycle
  • Anonymous Apr 08, 2008
    The timer motor was bad. I replaced it in about 20 minutes. I figured that one of the cams were broken and I was right.
I replaced the timer motor and everything is working fine.
Posted on Apr 08, 2008
    Novelist:
  • 184 Answers
DO YOU MEAN IT WON'T SHUT OFF? DOES THE TIMER ADVANCE? IF IT STAYS IN THE SAME PLACE, AND YOU ARE ON AN "AUTO DRY" CYCLE, THE TIMER WON'T ADVANCE IF THERE IS A RESTRICTION IN THE EXHAUST.
DISCONNECT THE DRYER EXHAUST FROM THE BACK OF THE DRYER AND TRY ONE LOAD OF LAUNDRY. IF IT WORKS O.K., THERE IS A PROBLEM WITH YOUR DRYER DUCT WORK. HAVE IT CLEANED OUT AND TRY IT AGAIN.
3 Suggested Answers
SOURCE:
mastatech
  • 478 Answers
SOURCE: I have a kenmore gas dryer model#110 76512695 it
You probably have a bad heat element. If you hold the door switch closed while you start the dryer, you should see it heating up glowing red,if not , thats it. The part isn't to tough to change just remove the back its to the right. Just three screws and pull it off. Be sure to have it unpluged while working on it. Good luck, rate me so I can improve my service.
Posted on Jul 29, 2010
docjohn174
  • 943 Answers
SOURCE: Kenmore gas drier does not heat up
HI .Thanks for the question. the problem you have is with a thermal fuse, located at the ,of the dryer. pull away from the .remove the back panel. clean all the lint in the dryer. and the vent to the outside. the thermal fuse is located on the air duct. on the left bottom. of air vent a small plastic piece with 2 small blue wires. replace this part. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 07, 2008
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
Drier Shut off, won't restart. Is there a reset button?
What brand is the dryer and the model number off the machine would help greatly
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 21, 2012 | Dryers
My dryer does not completly dry clothes in one cycle
there may be lint trapped in the vent tube or the heater part in the drier is on it way out.you can find replacement parts home depo or sears it really not that hard to replace a broke part if you know what it isBut way your options cost of part someone else to install it of buy a new drier with a warranty.
Mar 20, 2011 | Kenmore Dryers
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Long drying times model #11062712100
Try this and let me know what happens.
TIP OF THE DAY
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
:?) DRRXR
Feb 07, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer
this promblem is about always a vent promblem or not cleaning the drier filter if your using the plastic vent check if its mashed behind the drier you must have 4inch of vent all the way throuch if its mashed or folded over its cut down to 2inches if it hangs under your house then comes up to the outside vent housing it can fill with water if the outside hood door isnt oping that will do it too its in your vent some where what i tell cust to do is run 4inch pvc from out side hood up through floor then run short metel vent to pvg attach with clamp to confirm vent restriction take vent loose for one load and see if it dries in right amount of time
Dec 28, 2007 | Dryers
White knight 767 tumble drier
If the rug was very heavy you could have burnt up the motor. If it will restart after it cools off, replace the motor and clean out the vent system.
Good luck.
Dec 08, 2007 | Dryers
Dryers Logo
162 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
