My oneforall rf remote won't operate my dvd player
Is there a dvd player that comes wih an rf remote on the market?
Posted on Sep 27, 2008
Do you have the oneforall remote codes for a coby DVD player
I found the code I needed by putting in the search bar my the model of my oneforall remote and they had many code for many brands of DVD players listed
Dec 17, 2011 | Coby Televison & Video
I need to find the codes for the sony dvd player on the urc-3021B00 remote
Try the codes: 0533 1533 0864 1033 for a Sony DVD player.
The code list for the URC-3021 is available from One For All here: http://www.oneforall-na.com/remote.php?type=URC%203021 . The manual and the code list is available here: http://www.oneforall.com/uploads/support/00a1e876ce84e35c2c0351a407218d66.pdf .
Please note that the codes available in a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your DVD player is newer than your remote, you may need a new remote. The first URC-3021 was released in 2004.
I hope this helps.
Oct 19, 2011 | Televison & Video
Need code for rca dvd on a urc3220 oneforall remote
Try the codes 0522 0571 0717 for an RCA DVD player.
The code list for the URC3220 is available here: http://voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/URC3220codes.pdf .
Please note that if your remote is older than your dvd player you may need a new remote. The codes are usually limited to those for devices released 6 months or more before the remote was programmed.
I hope this helps.
Oct 13, 2011 | One For All Remote Control
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Need codes: OneforAll remote URC 4021B00 to TEAC or Toshiba
Ask http://manualfox.com - they can get it for you.
Jun 05, 2009 | Televison & Video
Universal remote code for Magnavox MWD7006
try 0503,or 0675 won of these two will work for sure,can,t remember which one i used though. got it from the the manual that came with my cox tv universal remote
Jun 02, 2009 | Philips Magnavox MWD7006 DVD Player
Need DVD remote control code.
This would be the place to go:
http://www.oneforall.com/webwizard/index.htm
or
Welcome to Remote Central: Universal Remote Control Reviews & More!
They both have loads (more than I ever want to know) about universal and learning remotes.
tom
Dec 14, 2008 | LG DR787T DVD Recorder
I have a oneforall universal remote, I need a remote control code for an emerson dvd player. can you help me ?
You can download the manual and codes from
this website. Just chose the model of your remote and get the code
Good Luck
http://www.oneforall-na.com/advanced_search.php?action=dosearch
Dec 14, 2008 | Televison & Video
Remote code for go video model# dv2140 dvd/vcr combo
I have a universal remote from ComCast cabel and was able to get code 0591 to work for the Go Video DV2140. It's one of the same codes as the Zenith DVD player.
Dec 14, 2007 | GoVideo DV2140 DVD Player/VCR
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
