Washer make a loud squeak when the spinning stops
Hi I have a Maytag Atlantis Washer MAV7200 AWW and it makes a loud squeak when the spinning stops.
  • alloway_1999 Jan 28, 2009
    Similar issue with Maytag Atlantis. Fine shavings of rubber from belt below main pulley. Took off front panel and cleaned up motor / transmission unit. Drive motor seems to jump around as it should but when it's done spinning - instant stop and squeak!~ No slow release just a crashing grit and knashing of teeth. Still washes just fine but impending dooms lies ahead. It's future is bleak. Sounds like this is a somewhat common issue. Anyone know the cause and preferably the solution. I imagine this will just end up giving me a good reason to go with a hi efficiency unit before I waste too much time and effort.
  • 23 Answers
This is a very com. prob. with this unit. its is expensive to fix and will come right back when humid out best thing to do is just put up with it.
Posted on Apr 07, 2008
How to remove front panel on Maytag MAV7200 AWW - Washer?
Have a look at this link. You can get all informations about your washer/
http://www.appliance-repair-it.com/Maytag-washer.html
Thanks
Jul 16, 2011 | Kitchen Ranges
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Re Your solution for my washer
its the spin brake making noise at the end of spin. once it gets humid out it will start all over again. its very comm. with this unit.
Apr 08, 2008 | Washing Machines
its the brake, just as long as it stops, dont worry about it, made a web page that has pics on how to replace the spin bearing on the maytag atlantis washer, after searching the net on how to, finding the manual, not explanatory, i decided to make this a simple 1 page web site, with lots of pictures, i hope this can help someone else in doing this job. since it would cost too much money for a repairman to do the job, better to buy a new one instead, i tackled the job. since it basically takes apart the whole machine, it might help others even if they dont have the spin bearing problem but other parts to replace,
http://www.geocities.com/maytagrepairwasher/
Apr 06, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Dead mav6000
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it http://maytagwasherrepair.googlepages.com/index.html
Mar 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV7200 Washer......needs seal and bearing kit
I HAD TO REPLACE THE SPIN BEARING ON MY MAYTAG ATLANTIS WASHER MAV9750,
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
Feb 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV7600 AWW
Normal brake sound in dry locations. Do you live in Arizona?
Feb 08, 2007 | Maytag LAT3600A Top Load Washer
Loud noise during spin cycle
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
363 people viewed this question
Top Washing Machines Experts
