Question about Intel Motherboard
Mobo and graphics card compatibility
Will a msi k9a2 platinium mobo and a nx 8800gt graphics card or any 8800gt graphics card run on xp
    Scholar:
  • 50 Answers
They both should work fine on XP.
Go here for the drivers for your motherboard..
And, here is the most recent driver for the 8800gt straight from Nvidia.
Posted on Apr 09, 2008
6ya staff
SOURCE:
What compatible video card for msi g41tm-p33 mobo
any pci-e 2 or 3.0 card should be fine. ATI, Nvidia, it doesnt matter, but that age of computer will barely utilize a modern mid-level card like an nvidia gtx 950
Dec 05, 2015 | MSI Computers & Internet
Powering Issues
Unplug the computer power,
Take a close look at the motherboard, find the cmos battery..usually looks like a big shiny nickel, carefully remove
Let the computer sit for 5 minutes.
Put the new hard drive back, if it works great. If not repeat with the old drive.
Let me know what happens.
Nov 23, 2009 | MSI K9A2 Platinum Motherboard - AMD790FX,...
I would like advice on upgrading my Graphics card
Unfortunatly your still running low end CPU power and low end agp graphics. Your going to pay 150-200 just for a fair PCIe/AGP HD/3D VC. If $200 doesnt hurt (and this is the lowest price best option), then might I suggest Mobo/CPU/RAM for around $200 that would do the trick and allow for future upgrades. You might also need a power supply. I just built one less than 3 weeks ago for a friend and it fairs against my own gaming comp.
MY PC...
AMD ATHLON 64 X2 DCP 6000+ 3.01GHz
NFORCE6M-A V:2.0
8GB PATRIOT
XFX 8800GT AD 512MB
500W PS
NEW PC....
Gigabyte GA-MA785GMT-UD2 MB $90+/-
AMD Athlon™ II X2 250 BOX 3.0GHz (CAME W/FAN)$70+/-
AND 4GB OF DDR3 1066 RAM COMPATIBLE WITH MOBO $40+/-
THE ONBOARD VIDEO IS CAPABLE OF USING 700MB
OF RAM...RGB/DVI OUT.
HOPE THIS HELPS.
Sep 12, 2009 | Asrock K7VT2 Motherboard
POST problems or XP Stop 0x8E
run memtest 86, test each ram stick, if it shows both as bat, then your mobo;'s memory controller is bad. if neither is bad, then it is your graphix card
Apr 13, 2009 | MSI PM8M-V Motherboard
Driver for xpx64bit
go to driver geneus it will find your driver automatically
Apr 06, 2009 | MSI NX8400GS-TD512EH, PCI Express Video...
No signal possible compatibility issue
Thats some nice items you have there M8!:) your machine gona rock when you done whit it!:)
And yes, the card is compatible whit your MoBo!
On your mobo you have 7 slots, 2 blue ones, they are PCI Express gen2 x16 slots , 2 white ones (the smal ones), they are 3 PCI Express gen2 x1 slots and 2 white ones (the large ones), they are 2 PCI slot, support 3.3V/ 5V PCI bus Interface.
The card you have you connect in the forst blue one, the second is if you waht to use 2 cards and drive them as crossfire.
So connect the card in the fist blue slot!
BTW, here is the link to MSI for your card
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=170&cat3_no=&prod_no=1696
Dec 06, 2008 | Nvidia GeForce 9600 GT,, PCI Express...
How big of a power supply you think is needed???????
500 watts is enough but make it sure that the power supply is dual fan to avoid over heating.
Apr 23, 2008 | Intel Motherboard
Need to know where the black yellow speaker wire gets plugged into a msi k9a2 platinum
Audio Ports
These audio connectors are used for audio devices. You can differentiate the color
of the audio jacks for different audio sound effects.
Line-In (Blue) - Line In, is used for external CD player, tapeplayer or other
audio devices.
Line-Out (Green) - Line Out, is a connector for speakers or headphones.
Mic (Pink) - Mic, is a connector for microphones.
RS-Out (Black) - Rear-Surround Out in 4/ 5.1/ 7.1 channel mode.
CS-Out (Orange or Yellow) - Center/ Subwoofer Out in 5.1/ 7.1 channel mode.
SS-Out (Gray) - Side-Surround Out 7.1 channel mode.
MSI 8800GT freeze
i think the 8800 might have been overclocked either in factory or by you personally. this leads to freezing occasionally. other than that is temperature (check fan settings). finally if your still having problems try exchanging the card for another, it'll probably have been because of hardware defects. it happens.
hopefully that helps.
Dec 19, 2007 | Computers & Internet
MSI K9N4 SLI-F / Vid Card question
Hi, for the best graphics always go for dual graphic cards. This is the best way to obtain realistic 3D effects. The onboard audio chips is every bit as good as stated, MSI systems are equal to the best but at a lower price. The only change I can see that you need to make is to install a better power supply. A minimum 500w is needed with your system and if your budget allows then anthing up to 600w. Have fun with your games. Regards mistyman
Sep 21, 2007 | Intel Motherboard
Intel Motherboard Logo
126 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
