Question about GE 46GW947 46" Rear Projection Television
No program sound - just static
Sound is static, no program sound. Sound level of static responds to volume control. Direct coax feed into TV used.
  • MissEmpress May 24, 2008
    No sound just hissing responding to volume control.
  • Anonymous Jul 06, 2008
    ge 46gw948 model has sound for 15 minutes then it cuts out to static only. After unplugging it for an hour the sound does come back for a while but seems to be getting worse evey week. What part needs to be changed. Thank You
    New Friend:
    Problem Solver:
Picture is great but no sound
Posted on Sep 26, 2010
SOURCE:
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
Sound braking up in windows media
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Volume problems on computers often happen for a variety of reasons. Volume troubleshooting, however, is one of the easiest problems to troubleshoot because there are only a few things that usually cause the problems. Usually the problem isn't even an error but just merely an adjustment that needs to be made. Test your speakers. This is the first thing you should check if you can't hear anything coming out of your computer. First try turning up the volume know and make sure you are in fact turning the volume knob and not a tone or balance knob. Make sure the speakers are completely plugged in to the wall and the computer. Test with another set of speakers or headphones after you have done this. Check the computer volume level. On the taskbar is a volume icon, which usually looks like a small speaker. Click on the icon and turn the volume up. Make sure it has not been muted. Double clicking on the icon will bring up a panel of several volume controls. Try turning up the volume on each slider. Go to Control Panel and choose "Sounds and Audio Devices." Under the volume tab, click speaker volume and turn up the level if needed. Turn up the application volume. Most programs that use sound have an additional volume control just for that program. Find the volume control and turn it up. Usually it is located in the lower right or left corner on the program, but you may have to search for it. Troubleshoot the sound card. Download the latest drivers from your sound card manufacturer's website. Go to Control panel > System > Hardware > Device Manager. Click on "Sound, Video and Game Controllers." Click on your sound card, select the driver tab and then click on "Update Driver." Point to the file where you saved the latest drivers from the website. After this, restart your computer. The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity clean your computer of dust using a can of compressed air or fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer If this doesn't solve your problem, try reseating the sound card into your computer. Hope this helps.
Jan 07, 2013 | Microsoft Windows XP Home Edition
HOW TO VOLUME the speaker even if the volume is 100 already.why is it low?
Test your speakers.
Hop this helps
Nov 11, 2012 | Lenovo Computers & Internet
Volume loss
Laptop or Desktop ?
Try swapping the speakers around to see if the problem is in the speaker itself.
Test your speakers.
Hope this helps
Nov 10, 2012 | Audio Players & Recorders
I was wondering if there's a way to change audio out from variable to fixed cause I want the volume out only from my surround sound not from the tv I heard If I switch from variable to fixed the problem...
No variable audio out means that whatever the volume is at on the TV it will output that level from the TV. So if you have your surround sound on and if you change the volume on your TV it will also make your surround sound louder with out having to turn up that volume on your surround sound, but if you have your volume muted then so will the audio out. So if it is a fixed audio out then no matter what level you have the TV set to it will output the same level. If you just want audio to go to your surround sound then just hook the video cables up to your TV and the audio to your surround sound. I would guess that you are using Red and White cables... If you are that only gives you left and right audio. Not surround sound, so you would want to run optical, HDMI, digital coax, or the analog 6 channel audio cables.
Sep 09, 2010 | Televison & Video
Toshiba CN36X81 television.. NO Sound... Great Picture. Using the TV2 output of a DISH Network HD receiver... TV2 output is std def, coax output. Using a different TV I get picture and sound... but not...
IF coming in via, the "Dish" networked receiver, please check that this volume is turned way up, on the TV. and then control the the Volume, with the Dish Remote, often this is a problem, as one is turned down, and the other cannot turn that up, simply try syncing the Volume controls, UP on TV, control the Audio with dish remote. thats all i can think of. Check by feeding a signal IN from an AV, source, ie: Yellow, Video, & Red& White, Audio. Turn TV UP and check, IF it responds to this all is well. If NOT then you do indeed have a fault, with the TV.
Mar 27, 2010 | Toshiba CN36X81 TV
Remote doesn't control. batteries are good, but there is no apparent connection between the remote and the TV. It is in use with a Comcast turner-DVR, which works fine, but I have to turn on and adjust...
Are you using Comcast remote to control the TV? When you program the Comcast remote to control your TV, it will do two functions: on/off, and Volume control. The Comcast can also be programmed not to control the volume of the TV (TV volume will have to be set at about mid level manually, then the Comcast box will send out variable sound level to the TV), just on/off ONLY.
Oct 27, 2009 | Olevia 227-S11 27 in. LCD TV
Used receiver at different location for 3 months.
Had repair man come. The coax connection going to TV from receiver had went bad in the receiver. The other connectors in box worked but not the coax anymore that is why the box worked on other TV since using video and sound cables. Got new box for signing up for another 18 months with Direct TV. Didn't have to have splitter to just get Satalite so that wasn't the problem at all. Any of the splitters I had would have worked.
Apr 17, 2009 | RCA R10 DIRECTV
32 inch tv goes from normal sound during program to extreme loud
May be a defect but, if you notice the sound changes with different channels or movies or HD or Standard, look for a volume limiter control button in the menu setup under audio control. Sometimes the menu has a control that you can turn on to limit different volume levels during the shows origination.
Mar 12, 2009 | Televison & Video
Audio volume level
Hi, I'm guessing your turning up the volume on the TV box to control the volume of your speakers. By doing this your only controling the audio strength coming out from the TV box.
What you should be doing is turning up the volume on your TV or amp feeding your speakers rather than the direrct TV box. The level of the speakers may have been reduced form last week (other people messing about with your equipment?) which is the reason why you have to turn it up to 30 rather than 10.
Another problem could be a loose audio connection from you direct TV box to your amp or TV. Have you tried a different source such as a DVD player, and does the sound on that seem alot quiter than before? If the volume of this is alot quiter also it could be a problem with your speakers.
Hope this helps.
Nov 01, 2008 | Televison & Video
GE 46GW947 46" Rear Projection Television Logo
254 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
