Epson stylist cx3200 scanner not working - Office Equipment & Supplies
  • 1 more comment
  • lil_joker_15 Feb 14, 2009
    my scanner wont let me scan!! help!
  • Anonymous Apr 29, 2009
    Very time I hit scan on my Lexmark X6170 printer, it doesn't do anything. It says starting to scan, then it stops without notice. Can anyone help me plz?
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 11, 2010
    What operating system are you using? are you getting an error message whenever you attempt to scan? what is the exact error message?
No device detected it says
Posted on Feb 04, 2009
  • gobbiestman Feb 04, 2009
    yes if i press the colour button it works but cant scan it still says device not detected do i need to update drivers as im running vista now not xp
    can not scan when using my epson stylus cx3200 it says no device detected im now running vista where as before i was using xp what do i need to do to get my scanner working
    Genius:
  • 1,447 Answers
Try to do a stand alone copy, by putting a document on the glass and press color button. If that work, uppdate me
Posted on Apr 17, 2008
Epson Stylus CX3200 Error
Possible scanner failure.
Turn off your printer. Disconnect it from your computer. Toggle the transportation lock on the scanner unit if there is any. It has to be in the unlock position. Turn the printer back on.
If your unit is not yet a year old, please contact epson for your warranty options.
To help you find an epson certified servicer near to your area, please log on to epson.com.
Apr 28, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My scanner
Open the scanner lid and slide the transportation lock back to the hw_translock_1.gif unlock position.
I will appreciate a Fixya rating if I were able to resolve your concern.
Oct 22, 2008 | Epson Stylus CX3200 All-In-One InkJet...
CX3200 SANNER
Can you make a copy? If not then:
1) Turn off the printer.
2) Lift the scanner cover.
3) Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4) Turn on the printer, and the error should be cleared.
If you can make a copy, you need to go to your all programs, and select Epson Scan
Aug 18, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scanner error see your docmentation and call service if necessary
Please follow the steps below to resolve your issue.
Jul 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Nazir
There is an error with the scanner section.
Feb 08, 2008 | Epson Stylus CX3200 All-In-One InkJet...
334 people viewed this question
jasbo
jasbo
