Question about JBL PB12 Subwoofer
Celestion S8 Has a high pitched squeal with or without input signal, gets loader after warming up.
Voltage regulator output electrolytics (220 uF/16V) heat up and start squealing/making geiger counter noise several minutes after power on. Noise stopped when electrolytics are sprayed with freeze spray. I intend to move the regs to the power amp heat sink (with heat sink greased insulators), add .1 uF tantalum caps to the regs output as close to the regs as possible and replace the 220uF/16V electrolytics with higher voltage units.
Posted on Mar 22, 2009
    Genius:
  • 1,689 Answers
Most likely there are electrolytic capacitors in the power supply and also possibly in the amp sections that are going high in ESR.
It would be best to test all the caps with an ESR meter and then replace the ones that are out of spec. You have an excellent chance that this will fix the unit.
If you are not experienced at doing electronics servicing, you can give the unit out to a service center to have it fixed.
Jerry G.
Posted on Apr 28, 2008
My Roper top load washer is making a squealing sound.. Is it a belt?
Most are belt drive on front loaders and on some top loaders but not all. Other culprit can be a dry bearing. Get into it a take a look. A length of plastic hose makes a good stethoscope to pinpoint the noise.
Oct 02, 2016 | Roper Washing Machines
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
S8 makes a very loud vibrating buzzing noise with only the power lead plugged in
Check for ground loops. Also shut off any CFL or LED lamps inthe vicinity.
You may also have an intermittent connection on the input.
There is a lesser chance that there is an internal failure of a capacitor on the amp power supply, but it is a possibility to look at if all the wiring is in place and soundly connected. The S8 has a high gain amp. It will pick up interference from CCFL or LED ballasting supplies it will also be able to pick up other switch mode power supplies. in vicinity of the input cable.
Jan 07, 2012 | Celestion S8 Subwoofer
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
High Pitch squeal everytime t.v. is turned on. 20min warm-up.
sounds like the switchmode power supply is varrying in frequency ..needs to be checked by qualified tech,,,
Apr 16, 2009 | SNK Magnavox 19MF338B/27 19 in. LCD TV
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
I would check the electroltyc caps in the power supply They general are in the first part of the power supply and there will be two of them . What they do is filter out transformer hum and help stabalize the circuit. I am not saying this is absolutely the problem but the capcitors are relatively inexpensive, Easy to change. And have a habit of going bad after a couple of years in use.
Aug 22, 2006 | Celestion S8 Subwoofer
JBL PB12 Subwoofer Logo
428 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
