Question about Nokia 6288 Cellular Phone
6288 soundless Helo! My Nokia 6288 became absolutely soundless, though I've not activated any soundless mode in Settings. I checked all settings, then I tried: Setting/Profile/General/activate. Nothing helps.
  • 1 more comment
  • Anonymous Apr 07, 2008
    my nokia 62288 became soundless. would only work if the headset is plugged in
  • Anonymous Apr 16, 2008
    i have the same problem. i restored to factory settings and changed profiles to outdoor as was suggested on MY3 web site and foned using a land line and my 6288 is still soundless.
  • Lackeyband Apr 27, 2008
    Same problem exactly. Tried remove and replace battery, changing settings, outdoor and back, meeting and back, silent and back and entering code (type it in and save ?. Still silent. It will vibrate, and vibrates differently for each tone tested, but no audio.
I had the same problem, I just turned it off took out the battery, put it back in and when I turned it on again it worked fine.
Posted on Apr 27, 2008
Same here but setting it to meeting profile works.
Posted on Apr 23, 2008
    President:
  • 1,017 Answers
Try this code *#4720# . It might or might not work. It's a deactivated low sound volume to save battery.
Posted on Apr 09, 2008
SOURCE:
Activation of the internet in mobile phone nokia 6288
If you have a problem with activation then only thing you could do is to call the service provider and ask to activate & to send configurations.
Or if your having a problem with connecting edit internet configurations manually. Go to menu>settings>configurations and set the access point & other configurations(which you can ask from service provider).
Aug 09, 2011 | Nokia 6288 Cellular Phone
Nimbuzz application in Nokia N72
check the settings by pressing the middle button and then -->application settings ---> configuration settings .
also check settings-->configuration -->default config settings-->select ur service provider and also check "activate defaults in all application"
Feb 12, 2010 | Nokia Cell Phones
Format the phone nokia 6288
how do i get my 6275 back to factory settings? security codes, configurations, etc.?
Oct 01, 2008 | Nokia 6288 Cellular Phone
Helo!
Go to Settings > time & date > select
Supriyo DG
Jun 09, 2008 | Nokia 6600
Nokia 6288
Try to insert this code: *#7780#
This restore factory settings
May 26, 2008 | Nokia 6288 Cellular Phone
How di remove call barring from nokia 5500d
Call barring
Call barring (network service) allows you to restrict the
calls that you make and receive with your phone. To
change the settings, you need the barring password from
your service provider.
1 Select Menu > Tools > Settings > Call barring.
2 Scroll to the desired barring option, and to request the
network to set call restriction on, select Options >
Activate. To set the selected call restriction off, select
Cancel. To check whether the calls are barred, select
Check status. To change the barring password, select
Edit barrings passw.. To cancel all active call barrings,
select Cancel all barrings.
Call barring and call diverting cannot be active at the same
time.
When calls are barred, calls still may be possible to certain
official emergency numbers.
Apr 09, 2008 | Nokia 6288 Cellular Phone
How to format
its you...
*#3730# to reset to default settings...then reformat card.
check your celphones website if there is a new firmware update.
Apr 02, 2008 | Nokia 6288 Cellular Phone
Dear Sunny1985,
How do you flash a nokia 6288 or 6280?
I have a virus (claimed by a technician) which is contantly making my internet connection online even though I have disabled it manually. Still does not work and a shop technician tried but could not solve the problem!
Could you please guide me as to how I can restore it to it's original settings.
Thanks
Jan 11, 2008 | Nokia 6288 Cellular Phone
My 6288 has a huge prob!!
Hi the best solution is to send the phone of to the company and they will repair it. it might cost a small fee but not to sure about it.
Jan 10, 2008 | Nokia 6288 Cellular Phone
Nokia 6288
check your GPRS Setting! or call your providing network to assist you!
Sep 09, 2007 | Nokia 6288 Cellular Phone
Nokia 6288 Cellular Phone Logo
55 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
