Question about GE 27GT616 27" TV
What is value of this tv if i bought it
Whats the value of tv if i bought it from someone
    Genius:
  • 1,694 Answers
20.00 with remote.............................T.
Posted on Apr 06, 2008
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
Hello I bought a Samsung tv about 2-3 years ago and I have the serial #, model # and I am trying to find the value of the tv bc it had been damaged by the shipping company
It will be based on current value of the same size or comparable TV made now. The TV's usually cost less now then they did a few years ago and yet usually do more. Their insurance company will set a value and in the mean time price new sets with basically the same features
Jul 29, 2011 | Samsung Televison & Video
What are they wprth still in perfect condition 4 years old
The value wopuld have reduced to almost less than half of the presetn value of a new set( incidentely the value of TV's are dropping except when they are launched).Also the second hand buyers are limited buyers so you cannot expecct much out unless someone gets crazy.
otherwise keep it on use till it serves you well
Sep 26, 2010 | Panasonic PT-47WX49 47" Rear Projection...
We have rca tv model 52950 need year made
I have the same television and bought it brand new late 2001 and was delivered to my home January of 2002.
May 26, 2009 | RCA P52960 52" Rear Projection Television
Trutech TV PLV16320 - Power Supply Caapacitor Values
I take it you didn't save the capacitors?Or you just don't know what hole they came out of?I have someone that is supose to be sending me their power board from the same model TV.When I get it,if I do,I will let you know what they are.I did replace the bad ones on a 26" Trutech,and to me,they appeared to have the same board.If you wanted to take the chance,and replace the ones I did,here is what they were.Mine had three different diameters as well,but two had different voltages,and height.The measurements read diameter,and then height.(2) 35V 1000UF 13MM X 22MM (1) 25V 680UF 10MM X 16MM (1) 35V 680UF 10MM X 20MM (4) 10V 1000UF 8MM X 14mm When you do go to replace them,you can get ones with a higher value on both specs,but not lower.For example,if there is a 10V 1000UF,and a 16V 1000 UF,you can replace them both with 16V 1000UF,and it will work perfect.You can also use different heights as well,as long as there is enough room.How is the big black 450V 150UF,and the 400V 10UF capacitors?You have to check the bottoms of them as well.I had fixed one that these were the only two that were bad.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Oct 17, 2008 | TruTech PLV16320 Television
Philips tv
I have a 32 inch phillips tv that I bought from someone else and it has a child lock code on certain channels. How do I get this code off.
Jul 14, 2008 | Philips 21PT4475 TV
Value
25 to 30 dollars without a box or warranty...
Nov 14, 2007 | Orion TVDVD092 9 in. TV/DVD Combo
Samsung HCP4752W
You can not change a value in 480p or 1080i unless that is the incomming signal type. Unless you really understand these setting I would be careful of changing any.
Apr 13, 2007 | Samsung HC-P4752W 47" Rear Projection...
Interferance on tv
What is happening on this set, like others (not necessarily this make and model), is sometimes there are decoupler capacitors in the power supply and the secondary voltage supply from the flyback area that start to go opened in value. This allows some high frequency ripple to get back in to the video processing and CRT drive circuits. You will visualy see this as waves or interference in the picture no matter what you do. The solution is to have the set properly serviced.
You will not be able to fix this set yourself. Proper troubleshooting is required to find and replace the defective parts. There are high voltages in many of the areas where this fault can be occuring. I would suggest to take the set to an experienced service tech to properly fix the fault. Most of the cost will be the labour to do the work.
Considering that this is not a high quality set, you are probably better off to get a new set. I would suggest to stay with the big brand names. You will pay more, but you will get better value and performance for the money spent.
Jerry G.
Dec 24, 2006 | Polaroid TTM-2401 TV
Televison & Video Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
