Question about LG WM-0532HW Front Load Washer
Too much soap?
What kind of damage is caused to a machine like LG WM-0532HW if too much soap is used. Our machine is having trouble turning. We can put less and less into it at one time without the machine stopping with water in it. If we put a fitted bottom sheet in it, the smaller artlicles bunch up inside of it. The machine stops until we untangle and start over again. Could this problem be caused by too much soap? Can it be repaired?
  • 66 Answers
If the washer is draining ok if not you will need to ck the drain pump. i hope you useing the he sope if not you need to switch to he sope . try to do the above . and get back with me thanks.
Posted on Apr 08, 2008
I have an LG washer that is about 10 years old. Never had a problem with it until today. Several minutes into the wash cycle, the drum tries to turn but can't. It makes a high pitched sound and tries to...
Your guess seems right as the damaged zipper could be stuck within the drum or movement and could cause friction to the movement. You can remove power and try to check on the free movement of the drum, if not the drum assembly must be removed and reset.
Sep 27, 2013 | LG WM-0532HW Front Load Washer
Lg front loader washer WM 0532HW doesn't spray water anymore
u could try running a cycle or two with a mixture of 1 part vinagar to 3 parts water and see if it cleans out use hot water
Feb 26, 2013 | LG WM-0532HW Front Load Washer
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
How to replace the Bearing Ball on A front load LG Washer? The Bearing Ball on My Front Load LG Washer is Leaking Water and also the tank makes a loud noise while its running. I would like to know how to...
main drum bearing is pressed into the rear outer drum 1/2. you will need to replace that part. hopefully, the motor isn't damaged by the leaking water.
Jul 04, 2010 | LG WM-0532HW Front Load Washer
Just ran a load of laundry and "LE" came up on screen and I cant
Been doing a lot of clothes today?
Do you use more than a teaspoon of HE soap?
Washer been growling like a grizzly?
Those are signs of a overheated hall sensor.
These machines only use a gallon of water.
Any overage of soap will cause a suds lock.
The motor will try and FIX it by dumping extra water in and doing more work. Till finally an LE error will be declared.
If you are confident you are not overdoing the soap thing then you need to take a look at the wiring between the control and motor. It is a strong possibility the harness connection has vibrated lose OR you have a broken wire between the control and motor. If you want a service manual let me know.
Jun 08, 2010 | LG WM-0532HW Front Load Washer
OE for LG WM-0532HW
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jan 31, 2010 | LG WM-0532HW Front Load Washer
Moldy smelling clothes
First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
Jul 01, 2009 | LG WM-0532HW Front Load Washer
Washing Machines Logo
149 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
