Question about GE WSXH208A Front Load Washer
Washer machine problem
Does everything it's suppose to except the final spin cycle, do you think it's the clutch.
GE Model #WJSR2080T6WW
  • Mortona Apr 11, 2008
    Inner door housing seems to be loose, loud nose and a snap at the end of a spin cycle. we stoped the washer and are looking to find out how to remove the inner tub housing.
The problem was two out of three broken spider arms. Shame shame on GE for using Frigidare parts and using aluminum for a washer part in the fist place, also not listing the matinance needed to clean the filter in their manual. So they can come clean it for you, at a cost of $69.00? Seems so. And refushing to sell the broken part separate from the drum. Though the part itself was under warranty we had to pay for the labor of a poorly manufactured part that is a well known issue. See (Why Kenmore front load washers fail) on You Tube. There is a nice video of the spider arm SCAM!!!!!! We need to speak out together or the problem will continue.
Posted on May 09, 2008
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
GE washer WHSR2070VWB about 9 years old does not spin dry clothes. All of the cycle works except the final expulsion of water
If the cycle stops when it is supposed toi drain , that means that there is a problem with the drain pump.
Oct 12, 2008 | GE Washing Machines
GE front loading washer, WJSR2080T6WW, agitates, drains, wont's spin
might be a transmissin problem, ive seen the brake get too tight on these units to allow spin
Jul 07, 2009 | GE Profile WPRE6100G Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Ge washer model#wjsr2080t6ww
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
Apr 07, 2008 | Washing Machines
Final spin cycle problem
Sounds like maybe the clutch is worn?? Ge has several versions of this washer out some use a clutch and some dont Does yours have a clutch attached to motor or is it a solid pulley? Also GE uses the slow speed to start the spin and then kicks into high one or 2 mins into final spin. Is this noticable or does it sound like it starts slow and then never shifts???
Jan 20, 2008 | GE WBSE3120B Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Washing machine wont spin
Try and help it to spin in the spin mode.. if it moves.. sounds like a clutch problem ..IF NOT... you may have something like nail, screw ect... binding the spin tub from moving.. get a flash lite do some close checking inside the spin tub
Aug 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
GE WSXH208A Front Load Washer Logo
219 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
