Question about GE GSS20IEP Side by Side Refrigerator
Ge gss201epa side by side
Fridge- top half not keeping cold enough freezer-not freezing above ice maker and ice maker not making ice, is getting water in maker and door dispencer have cleaned dust from motor area, and manually defrosted got a little cooler, but not enough ,still no ice can u help
  • 1073 Answers
SOURCE: GE TPG24BF Not Defrosting
replace the white sensor located on the top of the evaperator coil
Posted on May 10, 2008
SOURCE: Freezer and fridge suddenly got warmer
I had a similar problem and had to replace my mother board and pump motor.
Posted on Mar 19, 2009
  • 1136 Answers
SOURCE: water dispencer in fridge not working nut ice
Hi. Activate the water dispenser and listen for the inlet valve to buz. If you hear the inlet valve and do not get water through the dispenser, there is a chance the reservor in the fresh food sections has frozen to block the water.
If the inlet valve does not buz when activated, remove the rear panel and remove the inlet valve. The 5/16" diameter hose will be attached to the solenoid you will need to test. Insert the leads of a voltage meter into the connection on the valve and activate the water dispenser. You should see a reading of 120V to the valve.
If there is voltage and the inlet valve does not respond, you will need to change the valve.
I hope this helps you. Please let me know if I can assist you further.
Posted on Jul 10, 2009
SOURCE: Our GE PSC25PSTA fridge drips water from the icemaker
I have this model also for just over 3 years and it developed the same problem. The issue turned out to be the unit was in defrost mode too long caused by a failing control circuit board (found in the back under a panel cover). The board controls all refrig functions. This was replaced and the unit works normally now. The board costs around $200 plus the service call ... still cheaper than a new refig.
Posted on Apr 29, 2010
SOURCE: my tfx20 fridge, keeps icing up in the freezer.
If the frost builds up on the evaporator coil, sounds like the defrost heater may be out. Check continuity.
If the frost buildup anywhere else - there must be an air leak somwhere. Usually it's the gasket or the ice dispenser flap stuck open.
First Choice Appliance
Posted on Jun 02, 2010
Hi , you probably need a repairman to check the freon level and test the thermostat
Jun 19, 2015 | GE Refrigerators
GE ice maker
If the freezer is cold enough to freeze food hard, look for a problem in the water line, water inlet solenoid valve, or possible ice build up on the ice maker itself that does not the allow the ice maker to complete it eject cycle and start a new ice making cycle.
Jul 14, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Side by Side (model GSL22JFRJBS) and am having several problems and I'm not sure if they are connected or if I just have bad luck. 1st: the freezer and fridge are not staying cold. The freezer...
HI change the main board its about $150-200. Will fix all your problems except the lightbulb would be a lightsocket problem or the bulb you put in is bad, or door switch.
Mar 30, 2011 | GE GSL22JFPBS Side by Side Refrigerator
Fridge and freezer doesnt seem cold enough. Things are cool but not cold. Ice cream is not as hard as usual (soft but not melted). Ice maker not making ice. Adjusting thermostat doesn't seem to make a...
Please check the timer the thermostat and the heater for the auto defrosting to work. Switch off the fridge and after all the frost has gone off switch on to see if the sooling returns . If so you can be sure that the timerr does not work and so reduces cooling on frosting. If there is still no cooling then you will need to check onthe compressor and the gas pressure. Get help to confirm and take an estimate before attempting, get an warranty assurance for work. Hope you try out and see first.Good day
Aug 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker doe's not fill up with water to make ice
just bought a brand new side by side with ice and water dispenser i have water coming out of the door dispenser but the ice maker tray is not filling up with water can someone help me
Jan 01, 2009 | LG LRSC26940ST 36" Side-by-Side...
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Fan is Running
Your refrigerator isn't defrosting. When you melted the ice on the coils in the freezer you might have noticed a glass tube with a wire going into each end this is your defrost element that is probably bad. If it tests out good then your problem is either in the defrost thermostat, or the motherboard that tells your fridge when to defrost.
Nov 14, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
376 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
