Question about Refrigerators
Ice Maker Does Not Cycle
Kenmore 106.56676500 side by side with ice maker on top and storage bin in the door. There is ice in the tray but it does not dump out and fill the bin. I was getting two blinks from the LED on the receiver before I started troubleshooting. Verified LED receiver cover "switch" is on.
When I hold up my cellphone camera to the infrared emitter, I can see it blinking when I close the spring-loaded switch. I read that the electronic package self test verifies the emitter and receiver are both good if after cycling power to the refrigerator the LED is on for 5 seconds. That is what I saw. Subsequently, the receiver LEDs have been off. What does this mean?
How do I manually initiate a dump cycle?
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
peyton32034
  • 410 Answers
SOURCE: Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Posted on Dec 17, 2007
  • 1314 Answers
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Posted on Jan 02, 2008
  • 1073 Answers
SOURCE: Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
Posted on May 02, 2008
  • 351 Answers
SOURCE: Ice maker broken
first if you take off that panel there is a circuit board . unlpug the board and put it back to gether if that dont work then replace it... i sometimes get away with both! i can also get you that part pretty cheap... here is my site. grab the number and give me a call thanks.
Posted on Apr 30, 2009
Ice maker stop taking water Kenmore
check plastic tube that runs from rear of the freezer. See if it is pluged with ice. If you find it is change the fill valve at the back of freezer behind the compressor cover. It could be a double valve, as one part.
Oct 13, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Ice maker drip into ice bucket and manual cycle leaks more water
Need to take the ice maker out to measure the amount of water input into the ice tray. In this case the tray was already full (from the leaking valve). The spillage I saw was just the tray overflowing. Time for a new valve.
Apr 28, 2009 | Kenmore Refrigerators
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Ice maker problems
the heater on the ice maker has gone bad the easiest way to fix is to replace ice maker.the heater is on the bottom of the maker and heats tray up to harvest ice if it dont the ice will stick.But try taking maker out and cleaning it real good with a light spongee (Scrubee)
let it dry then spray some a light coat of pam (or similar) into ice bins and try that ahrd water will eat the coating off the bins
Dec 29, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
